Author Topic: Trying to fix a ticking WG 25K5109 Standard/Medium Resolution (switchable) U5000  (Read 2069 times)
Anton
  • Last login:March 05, 2022, 03:31:15 pm
  • Motorcycle pinball arcade outboards neon jukebox
Hello all,
Trying to fix a ticking WG 25K5109. I suppose this is a U5000 chassis since it is Standard/Medium Resolution (switchable)
Recapped the chassis. still ticking.
Hooked up a 120v lightbulb to the unsoldered w159 jumper to check the powersupply. Result: faint pulsing glow in the bulb.
Read in posts to check C117. Problem: the schematic drawing shows 22uF 63v but the parts lists shows 10uF 50v.
What value should I take? Any other recomendations?
Anton
SirPeale
  • Green Mountain Man
Is it otherwise working? Or, is it dead other than the ticking?
If it's the latter, it's going into shutdown.
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
possible shorted D106 /a/b
did you replace ALL the caps, or just some?
bad or backwards C115 C120 if one is backwards, replace it... don't just flip it around.
