October 14, 2025, 09:42:56 pm
Nice! Love these cabaret builds. Is that white melamine you are building it out of?
So is your CP going to be on the same plane as the bezel area around the monitor? Is it all one piece?
I want to make a tully so bad.
Quote from: Le Chuck on March 10, 2019, 08:23:39 pmI want to make a tully so bad.Do it. It's the easiest design. We need more.
Quote from: thomas_surles on March 10, 2019, 08:26:18 pmQuote from: Le Chuck on March 10, 2019, 08:23:39 pmI want to make a tully so bad.Do it. It's the easiest design. We need more.Not until SB is put to bed, you using a 13" in there?
Now the monitor isn't showing picture. I can hear it power on but that's it. Got a little jolt fiddling with it.
Quote from: thomas_surles on March 09, 2019, 01:21:20 pmNow the monitor isn't showing picture. I can hear it power on but that's it. Got a little jolt fiddling with it.What did you end up doing to fix your monitor?
Smoked plexi over the screen?
tap plastics.if you need any photoshop help, LMK
Just stopped in lowes for work and saw this.
Quote from: thomas_surles on March 13, 2019, 09:34:09 amJust stopped in lowes for work and saw this.Might be too dark, what size sheet was it ??
Looking real good. How do you like those classix joystick and button?
That’s not too dark for CRT. Galaga had some dark glass. That smoked plexi should be legit
Probably, unless you do them in vinyl and top mount them. Then nope
