Author Topic: Gold Leaf Button Question  (Read 1969 times)
JRChristenson
  • Last login:August 28, 2020, 05:29:39 pm
« on: March 02, 2019, 11:42:32 am »
If anyone has an Ultimarc gold leaf button handy I was wondering what the measurement is from the bottom of the actual button to the bottom of the entire thing. For example on this Happ button that measurement is 2 1/4". Thanks.
JDFan
Re: Gold Leaf Button Question
« Reply #1 on: March 02, 2019, 12:04:37 pm »
IF measuring for a reason like the bottom of the cab being there - you might want to redo your Happ measurement - On them the Microswitch adds more depth than your 2 1/4" measure shows - ( I know cause I had to cut out part of the bottom panel of my build when it would not fit with the microswitch in place !!   :banghead: )
« Last Edit: March 02, 2019, 12:38:50 pm by JDFan »
JRChristenson
« Reply #2 on: March 02, 2019, 12:10:54 pm »
Yeah I know but the gold leaf buttons have the microswitch integrated.
Drnick
  • Plodding Through Life
« Reply #3 on: March 02, 2019, 12:54:35 pm »
https://www.arcadeworlduk.com/products/awuk-gold-leaf-style-convex-arcade-button.html  (Says same as Goldleaf but with convex buttons) only other goldleaf are the ultimarc gold leaf on there that I saw.
  • Last login:Today at 01:37:51 am
« Reply #4 on: March 02, 2019, 01:09:58 pm »
Bottom of bezel to bottom of button body is 1.318". (33.44mm)
Regular QDs will extend below the button body.
IL and Goldleaf buttons installed on 3/4" MDF:
