Author Topic: First Cabinet Build: I have no idea what I'm doing  (Read 110499 times)
  • Last login:Today at 09:32:19 am
Re: First Cabinet Build: I have no idea what I'm doing
« Reply #120 on: May 21, 2018, 08:19:31 am »
Jumping on Malenko is a mistake. He has been doing this a long time. He has offered you advice based on direct experience. If you don't like his advice just say thank you and then do what you want. Your crazy attacks just discourage people from trying to help you. I am pretty much the only person that has told you that you don't have the skill set to pull this off. You can make all of the silly comments you want to me. These other people are actually trying to help you build this steaming turd.
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
« Reply #121 on: May 21, 2018, 11:56:49 am »
I haven't projected anything, you're just being butthurt about what I typed for some reason.
That last line is just utter horseshit.
Ok. Thanks for your input.
jennifer
« Reply #122 on: May 21, 2018, 12:35:38 pm »
Hey MikeA....You may as well just tell him he's got no friends, and then go buy himself a welder.
obizues
« Reply #123 on: May 21, 2018, 12:53:57 pm »
I did what now?
luizw81
  • Last login:December 05, 2022, 12:39:36 pm
  • I love the Power Glove. It's so bad.
« Reply #124 on: May 21, 2018, 01:01:36 pm »
This thread has turned into something epic! Lol
I'm over here like...
Sent from my SM-J320R4 using Tapatalk
luizw81
« Reply #125 on: May 21, 2018, 01:03:21 pm »
Seriously though, that CP is gonna be way big without bolting that baby to the floor!
obizues
« Reply #126 on: May 21, 2018, 01:04:55 pm »
obizues
« Reply #127 on: May 21, 2018, 01:05:45 pm »
Well I took 190mm out yesterday.  I am going to see what else is realistic.
yamatetsu
  • Last login:Today at 08:13:35 am
  • Just because.
« Reply #128 on: May 21, 2018, 02:45:11 pm »
Don't angle the whole CP box. This kinda looks like the CP has sagged down under it's own weight. The CP box should be mounted at 90 degree angle (like in your first design draft), only the top of the CP should have that extra angle.
You also REALLY should consider building some kind of support under the CP to keep it from tipping over. My second cab has a CP overhang of 15 cm, the cab is 68 cm deep. Originally I had it standing on 4 wheels but I had to add leg levellers because I could tip the cab over if I wanted to. Now imagine a cab with a huge CP overhang like yours and 4 people leaning on it whilst having a heated multiplayer battle...
obizues
« Reply #129 on: May 21, 2018, 02:51:42 pm »
Good call.  Thanks!
I will be if I don't come up with another solution that allows me to support it.  I will most likely be extending the cab forward a big to support it either way.
yamatetsu
  • Just because.
« Reply #130 on: May 21, 2018, 03:02:04 pm »
Perhaps add a sort of "pillar" that has the CP shape?
obizues
« Reply #131 on: May 24, 2018, 08:15:42 pm »
Haven't had much time with my new job, but here goes with a cut down size of a CP, and moving it further into the machine..
I'll have to see how I need to change the profile cut to have things match up, and I'll probably take the advice I got and trim off those little small wings.
I also changed the CP tilt to only 5 degrees, so everyone can woosa!  :cheers:
  • Last login:June 13, 2024, 01:28:24 pm
« Reply #132 on: May 24, 2018, 08:41:44 pm »
Better.
obizues
« Reply #133 on: May 24, 2018, 10:09:55 pm »
I have almost no room for 2p and 4p, and even 3p is a little close.
Does anyone have any suggestions how to expand room without make my CP super wide again?
Pictures:
2p:
3p:
4p:
« Last Edit: May 24, 2018, 10:13:34 pm by obizues »
  • Last login:May 25, 2024, 06:17:23 pm
« Reply #134 on: May 24, 2018, 10:21:05 pm »
Congrats on surviving the gauntlet obizues. Some of these guys are ...ahem... passionate  ::)
obizues
« Reply #135 on: May 24, 2018, 10:23:26 pm »
Meh, aren’t we all?   :dunno
Any clue how to solve my space problem without turning around and making this thing huge again?
« Reply #136 on: May 24, 2018, 11:01:49 pm »
« Reply #137 on: May 25, 2018, 12:37:29 am »
I didn't realize you had an issue. What you said was:
To me, it sounded like the control panel was cozy, but do-able.
A lot of us have learned with 4 player arcade games some lessons:
  • Frequency: How often do you think you'll play 4 player games? For many of us, it's less than we thought and when we did play, being comfortable for the few minutes the game lasts didn't justify a large control panel for the rest of the time
  • Arcade Games: The quality of arcade games leave a lot to be desired for quality multi-player fun. Most of them are quarter sinkers that suffer when credits are free.
  • Space: having comfy space isn't as big of a deal as we though during the planning phase.
Check out some of the classic 4 player games and the control panels that go with them. NBA Jam, Gauntlet, Simpsons, etc. The only reason I could justify a larger CP is to ensure that the controls are lined up so you can play dual 8 way games like Smash TV and Total Carnage.
krangbrain
  • Last login:June 22, 2020, 05:36:57 pm
« Reply #138 on: May 25, 2018, 01:23:49 am »
Hey obizues, what I did on my panel to save space is reduce the distance between the joystick and buttons. The holes for the joystick and closest corresponding buttons are 3 freedom... er 3”... ehem... about 76mm apart on center.  ;)  (About 20mm shorter in distance than slagcoin.) It doesn’t feel any different to me, and although my cab is new, others haven’t noticed anything either.
Good luck on the build! I like the latest revision!
« Last Edit: May 25, 2018, 01:25:42 am by krangbrain »
jennifer
« Reply #139 on: May 25, 2018, 02:57:34 am »
A base 10 system is dumb? 1 foot is cut into 12 inches... 1 inch is broken into half, fourths, eighths, sixteenths, thirtyseconds, sixtyfourths, etc... Clearly imperial is the practical way to go (thick sarcasm for those who never catch it)... And even the OP posted in hundredths of a "freedom unit" while all his measurements on this printout are in millimeters... ::)
You do realize that not only is that all divisible by 2, But that is how America was built, nuts, bolts cars, houses bridges, war planes, ....So Ya that sarcasm flew over my head by the mile, not the kilos.
Drnick
  • Last login:May 06, 2023, 01:19:48 pm
  • Plodding Through Life
« Reply #140 on: May 25, 2018, 03:31:45 am »
Sure base 10 sucks, but it is simple to understand and does match the amount of fingers we have :)
I'm still cheesed off that English money stopped being base 12 before I was born :)   I want my Beer in a Pint glass although that pint glass will also show (568.3ml) on the side,  I want to buy my baggies by the ounce,  I want to do my measuring by the inch, I want to know my speed in miles not kilometres, I want to know my own weight in st and lb not kg.
But I am very happy to buy my fruit by the Kilogram and my soft drinks by the Litre.
« Reply #141 on: May 25, 2018, 07:27:31 am »
Cozy is definitely doable.  This is great advice.
Buick455
  • Last login:April 03, 2024, 03:24:29 pm
  • I MUSTA WRECKED IT!
« Reply #142 on: May 25, 2018, 08:59:09 am »
I would ditch the trackball to take back some space. A trackball in a 2 player/6 button panel is barely do-able unless its wide. The ball ends up too close to the buttons/sticks/bezel to spin it fast. My 2cents..
obizues
« Reply #143 on: May 25, 2018, 09:36:54 am »
Me and my friends enjoy Golden Tee, so that is something that is considered untouchable for me.
What 4-player games use 4 buttons?  I've been trying to look, and I've seen ninja turtles, simpsons, etc, and I might be able to take back a button on each side and make it only 3 buttons.
I still need to come up with a solution to player 2's button hand "falling off" the side.  I may just go with a rectangular look like these MAME remakes:
obizues
« Reply #144 on: May 25, 2018, 09:38:59 am »
My 2p is very uncomfortable so that I do need a solution for it.  3p and 4p are less used and probably doable.
I haven't admitted defeat on 4-player games yet since I love those button mashers and I would love to be able to have them for my family events.
  • Last login:June 12, 2024, 10:26:20 pm
« Reply #145 on: May 25, 2018, 09:45:02 am »
I'd have to agree.  The other thing you can do is "angle the player" more; raise the stick up on the left most player and drop the buttons down  and bring them in a little it makes the player stand a little more to the left. Do the opposite for the right most player. I see you posted a pic of a Blitz cab, so that should give you a better understanding of how 4 players can be at a cab at the same time.
As for Lew's "Arcade games" point, you can always limit credits. It doesn't really apply to sports games, which are super fun 4 player.  To be honest I really thought my 4 player cab would get more playtime but the sad truth is, it just didn't.   4 player games with 4 buttons...... I think that's just the 2 D&D CPS2 games but I could be wrong.
Buick455
« Reply #146 on: May 25, 2018, 12:32:46 pm »
I get it, I really do cause I did it.
My first panel was a monster:
2-8way Joy, 8 buttons each + p1, p2, p1 coin, p2 coin, trackball w/ 2 buttons, dedicated 4way ball-top & admin buttons.
My current:
1-Servostick, 2 buttons + p1, p2, (+ p1 coin, p2 coin, pause and exit are hidden off the panel)
And all the extra crap from the first is in a box somewhere, lol
For Golden Tee you need so much room around the ball to smack it. I would want 9" minimum between the ball and P2 and about the same to the bezel. If you have the space for a second cab build a dedicated machine for trackball games.. Golden Tees are up on craigslist constantly here in FL, sometimes really cheap if they aren't working. I would buy one if they weren't like 6' deep.
obizues
« Reply #147 on: May 25, 2018, 01:39:51 pm »
Thanks for insight
obizues
« Reply #148 on: May 25, 2018, 01:42:24 pm »
I'm starting to come to terms with I need to either make a 2p with Golden Tee or 4p without it..  :hissy:
obizues
« Reply #149 on: May 26, 2018, 06:06:44 pm »
Revamped CP without trackball, and made it rectangular.
Does the spacing seem off to anyone else?
« Reply #150 on: May 26, 2018, 06:23:23 pm »
Pretty safe layout.
I would move all the joysticks so they are inline (see pic). This would allow you to play SmashTV and Total Carnage.
obizues
« Reply #151 on: May 26, 2018, 06:53:15 pm »
Pretty safe layout.
I was thinking about that, but got stuck with where to put 3p’s buttons.
I understand why you did what you did, but it seems really uncomfortable to play.
« Reply #152 on: May 26, 2018, 08:23:01 pm »
Pretty safe layout.
I'd play it. It's how many arcade games were setup.
obizues
« Reply #153 on: May 26, 2018, 09:33:10 pm »
Do you have an example?
I may just line them all up straight forward...
Here's a mock of my newest cabinet version:
obizues
« Reply #154 on: May 26, 2018, 09:59:40 pm »
Has anyone had a similar issue I’m showing where even though it’s spaced “evenly” it looks like the 3p is extra cramped since the joystick is at the end of the CP?
Would it make sense to shift the other players over, or to move 2p, 3p, and 4p a little closer together?  Or will that also screw up the view / spacing for those players? :dunno
jennifer
« Reply #155 on: May 26, 2018, 10:38:13 pm »
I like that rounded C/p better, But possibly with just 2 players and a trackball And some recessed light diffusers. That thing could look pretty cool.....Getting 4 on a machine all at once seems challenging and like it might not happen as much as one might think.
  • Last login:Yesterday at 11:36:46 pm
« Reply #156 on: May 27, 2018, 12:35:10 am »
Looking much better (and stable), my friend!
« Reply #157 on: May 27, 2018, 11:31:54 am »
Looks much better!  If you can't line up all 4 sticks and least get the middle 2 ; then you can still play single player karate champ,  smash tv , etc
« Reply #158 on: May 27, 2018, 11:40:39 am »
Well look at that. The big mean bullies were right about everything. You can apologize and thank us any time. ;)
Your design is much better now. Not everyone can swallow their pride and make major changes to their original idea. Kudos to you.
obizues
« Reply #159 on: May 27, 2018, 11:43:32 am »
I can’t come up with a good 3p solution to line them all up.
