Author Topic: Vertical cab. Do i need 2 or 3 buttons?  (Read 1763 times)
markc74
  • Last login:Today at 02:36:40 am
  • Flipping out
« on: June 12, 2017, 02:26:35 pm »
Hi guys,
Hoping someone with 'the knowledge' can help. I'm building a vertical cab and not sure whether to go for 2 or 3 buttons. Mostly I'll be playing the classics but don't want to rule out any modern shooters as it's a genre I'm slowly starting to appreciate. I'll be using a servostik so will be 4 and 8 way games.
I know gunsmoke uses 3 but are there any must-have vertical games that use 3 or will 2 do for 99% of the good stuff?
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 12:07:47 am
Re: Vertical cab. Do i need 2 or 3 buttons?
« Reply #1 on: June 12, 2017, 02:58:34 pm »
is it a 1 player CP only or 2 players ?
There are lots of vertical games that can be played by 2 players at the same time.
name a few:
Scramble Spirits
R-Shark
there a lot of more.....
I say if you the room for a third button, got for it. or you can always add it later on.
« Last Edit: June 12, 2017, 03:02:33 pm by Thenasty »
Free VGA Breakout Cable
markc74
  • Flipping out
« Reply #2 on: June 12, 2017, 03:01:21 pm »
Cheers thenasty. It's a single player cab
lilshawn
  • Last login:August 03, 2025, 07:02:41 pm
« Reply #3 on: June 12, 2017, 03:02:50 pm »
If you are pressed for space you can do 2. gunsmoke can be changed via a dipswitch setting for the game to enable single button mode.
Thenasty
« Reply #4 on: June 12, 2017, 03:04:09 pm »
you can still add this Simultaneous Players games in a single layout CP.
Just have a single coin in and single player 1 start button.
