Author Topic: Jungle Hunt Two players and Two controls (How) ?  (Read 2496 times)
Pedro felinni
  • Last login:August 20, 2019, 04:11:35 am
« on: March 12, 2017, 10:09:58 pm »
How can 2 players play the jungle hunt game with 2 different controls?
« Last Edit: March 12, 2017, 10:13:12 pm by Pedro felinni »
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Re: Jungle Hunt Two players and Two controls (How) ?
« Reply #1 on: March 13, 2017, 12:01:43 am »
Set it the way you want in mame under TAB?
Pedro felinni
« Reply #2 on: March 13, 2017, 01:49:55 am »
don't work.
I tried and it didn't work.
Only control #1 works for both players.
yamatetsu
  • Last login:Today at 12:13:45 am
  • Just because.
« Reply #3 on: March 13, 2017, 04:11:10 am »
You can assign multiple inputs to one 'action' in MAME. Basically, you have to change player 1's config so that player 1's controls accept both joysticks. For example: Press TAB, go to 'Input (this Game)', press return to enter the menu.
Go to 'P1 Up', press return. Now press joy 1 up. Press return. Press joy 2 up. Now you should be able to use both joysticks for 'up'.
Rinse and repeat for the rest of the controls.
  • Last login:August 01, 2025, 09:20:08 pm
« Reply #4 on: March 13, 2017, 12:44:19 pm »
what yamatetsu said, but keep in mind each player can ---fudgesicle--- with each other.
Its a 1 player game who's cab only had 1 set of controls. When you died you stepped out of the way and let the other person play, just like Pacman.
  • Last login:July 27, 2025, 08:34:04 pm
« Reply #5 on: March 13, 2017, 03:25:54 pm »
Exactly. There's no need to set it up any other way normally.
  • Last login:August 04, 2025, 08:50:04 am
« Reply #6 on: March 13, 2017, 03:26:33 pm »
Nobody wants to play Jungle Hunt with you ever.
« Reply #7 on: March 13, 2017, 03:29:57 pm »
This.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 12:07:47 am
« Reply #8 on: March 13, 2017, 06:31:42 pm »
don't work.
This is how the original game works.
If you want it to work any other way, you need to modify the original game and add a second separate control for player 2.
OR....
You cant setup both players for controls and tell the second player not to screw with the joystick when it's your turn.
or......
have a common Ground switch and flip that it cutting of the connections for the the other player while the other is playing or be adventures and do it automatically using some relay switches.
I think, stepping out of the way when it's not your turn is the best option.
« Last Edit: March 13, 2017, 06:36:17 pm by Thenasty »
Free VGA Breakout Cable
Pedro felinni
« Reply #9 on: March 14, 2017, 12:07:18 am »
Thanks, I will try that, yamatetsu.
