Author Topic: Leaf-Pro from Groovy Game Gear  (Read 2662 times)
dhansen
  • Last login:August 16, 2025, 01:38:06 am
  • No Quarters Needed
    • Arcade Stupidity
« on: January 08, 2017, 11:23:22 am »
Hey guys, long time no see.  Quick question about the Leaf-pro joysticks from GGG I got a set for a buddy's 60 - 1 cab and noticed the the bolt pattern doesn't match up.  I build an adapter plate for them but was wondering how folks were mounting them since I'm not able to remove the stick from the base without unscrewing a plate on top of the base.  Any help is appreciated.
Any old timers still here?
Doug
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=65&products_id=365
..as his cold lifeless fingers lie motionless on the garage floor, all he could hear in his head was...I JUST WANTED TO PLAY A GAME OF DONKEY KONG!!
  • Last login:September 13, 2025, 07:15:22 pm
Re: Leaf-Pro from Groovy Game Gear
« Reply #1 on: January 08, 2017, 11:38:23 am »
The adapter plate is the way to go.
If you would have asked before you bought, I would have recommended buying the Pac Pro joysticks instead.
dhansen
    • Arcade Stupidity
« Reply #2 on: January 08, 2017, 09:23:33 pm »
Thanks for the advice but does anyone know if the stick can be removed from the base without unscrewing the restrictor plate?  I'm seems strange I would have to feed the ball through the hole in the control panel.
Thanks again!
dhansen
    • Arcade Stupidity
« Reply #3 on: January 08, 2017, 09:54:17 pm »
SOLVED... the washer between the two restrictor plates was removable but not without an extreme amount of force!
Thanks again!
« Last Edit: January 09, 2017, 01:55:05 pm by dhansen »
esmoger
  • Last login:August 08, 2018, 11:17:39 am
« Reply #4 on: January 14, 2017, 11:25:20 pm »
Thanks again!
EDIT: nevermind! the post above clued me in. I had the washer in the wrong place. Should have paid more attention when i first took it apart. thanks anyway!
Hey dhansen(or anyone who knows this joystick), I see you just posted this the other day.. can you tell me what the order of all your pieces on the Leaf-Pro are?
I bought one a few weeks back and in the process of putting everything together I'm not entirely sure I have it all together correctly(may have misremembered the original order). Unfortunately I can't find a diagram or anything for it. It plays *ok* but it seems VERY stiff (and if i pull up(as in up away from the control panel) on the stick it feels smoother and looser, but of course it won't stay in that position)
What I have is, from top to bottom: ball top, shaft, -control panel- diamond restrictor(4-way option), circle restrictor, joystick base, washer, spring, actuator
based on your post that i quoted, i think i have the washer in the wrong place? i'm not sure how it could go between the 2 restrictors though, unless you meant that it goes above the base instead of below it, which i think would leave it sitting in about the same vertical space as the restrictor plates.
Any helps is much appreciated!
« Last Edit: January 15, 2017, 12:44:46 am by esmoger »
  • Last login:July 11, 2025, 09:17:44 am
« Reply #5 on: January 17, 2017, 11:24:35 am »
+1, I made the exact same mistake when I ordered my leaf joys.  Luckily, RandyT was cool and let me exchange it for the proper Pac Pro joystick.  Great customer service goes a long way...  I've bought 4 Pac Pros since then for various projects.  Great joystick!
DeL
