November 30, 2025, 05:53:52 am
SOLVED... the washer between the two restrictor plates was removable but not without an extreme amount of force!Thanks again!
The adapter plate is the way to go.If you would have asked before you bought, I would have recommended buying the Pac Pro joysticks instead.
