Author Topic: Power On Button  (Read 9734 times)
renorains
  • Last login:January 11, 2017, 11:10:04 pm
Power On Button
« on: March 02, 2016, 10:49:24 pm »
Good Day Guys
                      Can someone put me on the right track please? I notice the newer computers dont support the "Power On" in the Bios that allow you to turn on your computer via PS2 Mouse or Keyboard.
  So i will like to know, What options are available for me to install an external power button on my cabinet that will turn on a computer
05SRT4
  • Last login:June 02, 2024, 04:10:04 pm
  • Check out my Pow Pow
Re: Power On Button
« Reply #1 on: March 03, 2016, 12:07:13 am »
Most Motherboards have a Front Panel connection that you can hook up to a switch/button Check out this example The Power SW is the power on switch. You wouldn't need the HDD or reset switches, just one for the power. So if you wired that to a push button you would be able to power on the machine that way.
Thats how I do it on all my PC based arcades.
Depending on where I mount the power switch I will also enable the power down on press option in windows. This can be a bad idea though if the power switch is in an area that someone can accidentally press.
Do you know what mother board you are using?
« Last Edit: March 03, 2016, 12:10:36 am by 05SRT4 »
renorains
Re: Power On Button
« Reply #2 on: March 07, 2016, 09:42:54 pm »
thank you
