Ok I ran the DemulShooter_Gui debug file with option -v and this is what the debug file says:
Thanks.
I don't know how long it will take but we can continue to search that way....here another debug release for you to test with the -v
Well I appreciate any and all help you're willing to give me!
ok so after running the new files you gave me, I got a little farther. Program looks like it's trying to open and then it has an error message (I hope attached file shows up).
And in the details of the error box it says the following:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at DemulShooter_GUI.Wnd_DemulShooterGui.ProcessRawInputMessage(IntPtr RawInputHandle)
at DemulShooter_GUI.Wnd_DemulShooterGui.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.9151 (WinRelRS6.050727-9100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
DemulShooter_GUI
Win32 Version: 2.0.0.0
CodeBase: file:///C:/DemulShooter/DemulShooter_GUI.exe
Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.9147 (WinRelRS6.050727-9100)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
DsCore
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/DemulShooter/DsCore.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Debug file
21:09:34.050597 :
21:09:34.054618 : ---------------- Program Start -- DemulShooter_GUI v2.0.0.0 ----------------
21:09:34.065904 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_D209&PID_1601&MI_00#7&130a4ff8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.070299 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_046D&PID_C534&MI_01&Col05#9&3aa8e19a&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.074288 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_046D&PID_C534&MI_01&Col04#9&3aa8e19a&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.079231 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_046D&PID_C534&MI_01&Col02#9&3aa8e19a&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.084867 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_D209&PID_1602&MI_00#7&17eaf324&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.087915 : Error: Impossible to get Value Capabilities for device \\?\HID#10251229#6&2ca06beb&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.091872 : Error: Impossible to get Button Capabilities for device \\?\HID#ELAN0504&Col02#5&28f3ccea&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.097285 : Error: Impossible to get Button Capabilities for device \\?\HID#VID_3938&PID_1032&MI_01&Col05#9&333c1fed&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.102297 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_3938&PID_1032&MI_01&Col04#9&333c1fed&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.107261 : Error: Impossible to get Value Capabilities for device \\?\HID#VID_3938&PID_1032&MI_01&Col02#9&333c1fed&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.118042 : Found 22 available RawInput devices
21:09:34.126024 : Error reading C:\DemulShooter\config.ini : Could not find file 'C:\DemulShooter\config.ini'.
21:09:34.130012 : Initializing GUI [Players] pages...
21:09:34.154946 : Initializing Player1 devices:
21:09:34.159932 : Adding \\?\HID#VID_D209&PID_1601&MI_02#7&6f69e7b&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
21:09:34.162948 : Adding \\?\HID#VID_D209&PID_1601&MI_01#7&2acddc3d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.165940 : Adding \\?\HID#VID_D209&PID_1601&MI_00#7&130a4ff8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.169905 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col05#9&3aa8e19a&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.172897 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col04#9&3aa8e19a&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.176886 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col02#9&3aa8e19a&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.179878 : Adding \\?\HID#VID_D209&PID_1602&MI_00#7&17eaf324&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.183867 : ERROR : Object reference not set to an instance of an object.
21:09:34.190849 : Adding PlayerData to the list...
21:09:34.194838 : Adding Player tab to the GUI...
21:09:34.202817 : Initializing Player2 devices:
21:09:34.207805 : Adding \\?\HID#VID_D209&PID_1601&MI_02#7&6f69e7b&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
21:09:34.211794 : Adding \\?\HID#VID_D209&PID_1601&MI_01#7&2acddc3d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.215783 : Adding \\?\HID#VID_D209&PID_1601&MI_00#7&130a4ff8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.219772 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col05#9&3aa8e19a&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.223761 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col04#9&3aa8e19a&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.226753 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col02#9&3aa8e19a&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.230743 : Adding \\?\HID#VID_D209&PID_1602&MI_00#7&17eaf324&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.233767 : ERROR : Object reference not set to an instance of an object.
21:09:34.237726 : Adding PlayerData to the list...
21:09:34.241715 : Adding Player tab to the GUI...
21:09:34.250689 : Initializing Player3 devices:
21:09:34.257672 : Adding \\?\HID#VID_D209&PID_1601&MI_02#7&6f69e7b&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
21:09:34.261693 : Adding \\?\HID#VID_D209&PID_1601&MI_01#7&2acddc3d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.265682 : Adding \\?\HID#VID_D209&PID_1601&MI_00#7&130a4ff8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.268666 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col05#9&3aa8e19a&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.271633 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col04#9&3aa8e19a&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.275623 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col02#9&3aa8e19a&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.279612 : Adding \\?\HID#VID_D209&PID_1602&MI_00#7&17eaf324&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.282637 : ERROR : Object reference not set to an instance of an object.
21:09:34.285628 : Adding PlayerData to the list...
21:09:34.289586 : Adding Player tab to the GUI...
21:09:34.297638 : Initializing Player4 devices:
21:09:34.301659 : Adding \\?\HID#VID_D209&PID_1601&MI_02#7&6f69e7b&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd}
21:09:34.305617 : Adding \\?\HID#VID_D209&PID_1601&MI_01#7&2acddc3d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.309608 : Adding \\?\HID#VID_D209&PID_1601&MI_00#7&130a4ff8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.312639 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col05#9&3aa8e19a&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.315626 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col04#9&3aa8e19a&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.319579 : Adding \\?\HID#VID_046D&PID_C534&MI_01&Col02#9&3aa8e19a&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.322604 : Adding \\?\HID#VID_D209&PID_1602&MI_00#7&17eaf324&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
21:09:34.325595 : ERROR : Object reference not set to an instance of an object.
21:09:34.329587 : Adding PlayerData to the list...
21:09:34.332578 : Adding Player tab to the GUI...
21:09:34.336536 : Initializing GUI [Act Lab] page...
21:09:34.340558 : Initializing GUI [Silent Hill] pages...
21:09:34.344513 : Initializing GUI [Gundam] pages...
21:09:34.347537 : Initializing GUI [Heavy Fire Afghanistan] pages...
21:09:34.350529 : Initializing GUI [Heavy Fire S.S] pages...
21:09:34.354519 : Initializing GUI [Output] pages...
21:09:34.357479 : Registering to RawInput service...
21:09:34.367723 : Installing Low-Level Keyboard Hook...
