Edit:
The incorrectly detected desktop resolution got me thinking. I disabled the high DPI scaling on DemulShooter.exe and now it works! The resolution is still detected incorrectly, but now I have the full target area!
I was wrong on one point, I didn't remember but testing my config at home (old plain Win7), I had in fact modified my m2emulator to run on 1920x1080 on my screen and never had any issue with it (everything is detected correctly)
So yes the wrong desktop resolution detection is indeed the cause of the problem but I still don't know why it's reacting like this on some computers....
And I'm affraid each new Windows will be harder to support than it's predecessor.
But your DPI scalling hint might be very usefull for this matter ! for sure !
Still the same... Only Wiimote 2 does anything. It moves the red (p1) cursor and the blue (p2) cursor ever so slightly. The blue cursor is stuck in the top left of the screen. Wiimote 1 does nothing.
Edit:
When only playing with one Wiimote, it works as expected.
Edit 2:
The file you posted above is timestamped the 3rd of July. Are you sure you uploaded the correct one?
Yeah it was the right one, access time are tricky with windows, between last acces, creation date and so on...
But you really made me doubt, because when I tested back the uploaded file, I was unable to control the Player2 just like you explained !!
I spent 1 hour not beeing able to do anything with a Joystick or even my Aimtraks, I started the emulator a bunch of times...and suddently it worked back as perfectly as it was before.
I've joined a newer build, just a small change on it to test if the screen resolution is detected correctly with model2.
I really don't know for the P2 bug..... I had a lot of trouble with the memory location for this emulator and it may not be as done as I thought.....
Right now, the only advice I can give is "try again and it may work sometimes".....but I'll seriously get back on it later, as I'm currently into adding support for Far Cry (for Aimtrak, you can directly play it with your XInput device, you lucky man
! ) and removing the crosshair of this game
Edit : You wanted to play demul too, have you tested ? Is everything working well with this emulator ? (you'll have BIG crosshair on GAME TEST MENU when checking for gun calibration in hod2 for example)
