Author Topic: CRT Emudriver 2.0 - Emulator compatibility list  (Read 234865 times)
s8n187
  • Last login:October 10, 2025, 12:50:25 pm
Re: CRT Emudriver 2.0 - Emulator compatibility list
« Reply #160 on: November 16, 2018, 05:42:32 am »
has anyone got Game Loader All RH ( Taito Nesica / Ringwide / Ringedge) working with CRT Emudriver ?.  I can't get it going i get the below message
Yardley
  • Last login:July 22, 2025, 11:36:15 pm
« Reply #161 on: November 19, 2018, 07:39:10 am »
Hi guys, is anyone here emulating Playstation 2 through PCSX2 and CRT Emudriver? I am getting really bad ghosting/motion blur even though the game runs at 100% speed. I'm using a Radeon R7 250 graphics card. Can someone post their settings please or any suggestions?
s8n187
« Reply #162 on: November 19, 2018, 08:23:09 pm »
hi Yardley ,  do you have V-Sync on in PCSX2 ?
s8n187
« Reply #163 on: November 22, 2018, 08:47:39 am »
got it working people ,  i had to install some missing Visual C++ Redistributable Packages.
« Last Edit: November 22, 2018, 08:52:41 pm by s8n187 »
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #164 on: February 18, 2019, 03:33:02 pm »
I use d3do overrider with vsync and triple buffer activated. Fine with a weak hd 6450 OpenGL.
Salut!
Professor Jones
  • Last login:February 09, 2021, 02:24:19 pm
  • Ain't nothing like the real thing
« Reply #165 on: March 30, 2019, 01:34:00 pm »
Hey,
I'm having a problem with retroarch : it seems to have trouble switching resolutions. The first game I launch runs on the correct, low res, but if I close it and launch antoher game with a different resolution, I get  a squashed interlaced resolution. If I close retroarch and launch the exact same game, it runs fine. Here's a video showing the problem :
https://photos.app.goo.gl/euRoXLo98ukUXG5D9
DT
  • Last login:May 15, 2021, 07:28:28 am
  • 240p4Life
« Reply #166 on: May 07, 2019, 09:24:02 am »
Hey,
Same problem here and i have no idea what to do about it.  :-[
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #167 on: May 09, 2019, 04:13:25 am »
Are you using RA's builtin switchres ?
DT
  • 240p4Life
« Reply #168 on: May 09, 2019, 05:35:49 am »
Yes.
Substring
« Reply #169 on: May 09, 2019, 05:06:17 pm »
Yes.
Well, then you should join their discord or open an issue on RA's github, the "switchres" feature is much different than how groovymame does it, afaik
DT
  • 240p4Life
« Reply #170 on: May 11, 2019, 02:43:01 pm »
Yes.
Well, i thought this is the emulator compatibility list topic, not the Groovymame support.  >:D
Overkill
  • Last login:August 04, 2025, 06:32:19 pm
« Reply #171 on: June 19, 2019, 08:24:01 pm »
test system: Windows 7 64 bit, Radeon HD5700 series, CRT emudrivers 2.0, Sony PAL TV 15kHZ
Sega Megadrive/Geneis                    Kega Fusion 3.64    320x240 PERFECT
Sega CD (Mega CD)                           Kega Fusion 3.64   320x240 PERFECT
People who are  having this results with Kega Fusion on Windows 7 x64 can give a resume help on how to achieve?
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
« Reply #172 on: June 20, 2019, 09:22:34 am »
@Overkill
The reason I switched to Retroarch was Kega Fusion not working properly on Windows 7 x64. Now being on Retroarch I never look back. Its that good. and pixel perfect. Plus it has a run-ahead feature to remove input lag. plus it has a rewind action replay feature. :D
Overkill
« Reply #173 on: June 20, 2019, 05:28:31 pm »
Great, going to give it a try. It's just for some Mega-CD, and 32X games. MD games on Mame are ok.
Thanks R-Typer!
harry_sack
  • Last login:July 31, 2019, 08:47:40 am
« Reply #174 on: July 05, 2019, 09:23:06 am »
anyone got FCEUX 2.2.3 to work?
I read here in this thread somewhere that it works perfectly.
I changed my desktop resolution to 256x240, changed the resolution of the emulator, but when I enter fullscreen the screen turns black for 1-2 seconds and then reverts back to windowed mode :(
I'm on windows 10 and use a Radeon HD 4570
Overkill
« Reply #175 on: July 06, 2019, 08:29:51 pm »
Retroarch is running well, using rgui. But I have some screen tearing on the top image scrolling of the MD, 32X, MCD games. Don't know what I'm missing in the configuration:
crt_switch_resolution 2560 15khz
crt_switch_center_adjust = "0"
crt_switch_resolution = "1"
crt_switch_resolution_super = "2560"
crt_switch_resolution_use_custom_refresh_rate = "true"
custom_viewport_height = "240"
custom_viewport_width = "2560"
custom_viewport_x = "0"
custom_viewport_y = "0"
video_aspect_ratio = "8.000000"
video_driver = "d3d11"
video_frame_delay = "0"
video_fullscreen = "true"
video_fullscreen_x = "0"
video_fullscreen_y = "0"
Professor Jones
« Reply #176 on: August 31, 2019, 04:06:16 am »
I might have the exact same problem. I posted a topic about this in the libretro forums but I still don't know how to resolve it.
https://forums.libretro.com/t/retroarch-crtemudriver-vsync-problem/23759
pixel69
  • Last login:July 21, 2023, 01:52:35 pm
  • I want to go back to the future
« Reply #177 on: August 31, 2019, 08:09:45 am »
Hello,
if you are using the genesis gx plus core, try to set borders to top/bottom in the options of the core
For master system I prefer to set borders to full
« Last Edit: August 31, 2019, 08:14:33 am by pixel69 »
fuchi_jeg
  • Last login:December 02, 2025, 10:21:02 am
« Reply #178 on: November 01, 2019, 02:01:44 pm »
I would like to thank Calamity for all of your hard work! I have been building my system for a few years, and am finally getting my cabinet close to completion.
  I am running several emulators that aren't represented on this list, and I would like to let you guys know that these are working perfectly on a crt emudriver/arcade monitor setup with windows 7 64 in either native resolution or in a few cases, super resolution. GPU is r9 380x.
Standard version of nestopia, 1.40 native resolution.
SNES9X 1.56.2 flawless in super resolutions.
kega fusion version 3.51 with calamity's direct draw files. Switching resolutions perfectly in hyperspin. I have tried other versions of fusion and cannot duplicate this. only 3.51 works for me.
supermodel is also switching resolutions just fine. version .02A
Yabusa 0.9.14 was working for all saturn emulation, but hangs on launch since installing r9 380x.  will have to revisit the emulator and edit the post. EDIT: *yabausa was defaulting to 800x600 resolution. after correcting the resolution yabausa launches and shuts down correctly.*
Xebra. version 19/6/25 The biggest success, and I feel the best PS1 emulator. Looks stunning using super resolutions. Dithering is intact, debatable whether that's a plus or minus, but I love it.
Dolphin 5.0. I understand it isn't a "240P" emulator, but it is also works very well using super resolutions.
Please let me know if you have any questions on the settings for these emulators. Sometimes it takes a lot of messing around to get them to work, especially Xebra because the info is mostly in Japanese.
« Last Edit: November 08, 2019, 07:36:30 am by fuchi_jeg »
NYI
  • Last login:January 13, 2020, 11:01:09 pm
« Reply #179 on: January 05, 2020, 03:20:23 pm »
Thank you for the information regarding compatibility. I want to piggyback off this post and ask to anyone who might know - does an emulator need to have been built explicitly with super resolution compatibility in mind? I've used groovymame and emu4crt, the awesome fork of mednafen by silmalik, and they work great with super resolutions, but haven't tried with other emulators. Like Xebra - I'm fairly sure that author wouldn't have had super resolutions in mind when he developed it.
fuchi_jeg
« Reply #180 on: January 09, 2020, 06:17:22 pm »
As long as the emulator can stretch the image width independent of   the height it should work. For most emulators that means choosing 2560x240 resolution, choosing stretch, and hoping that the emulator is capable of changing from interlaced resolutions to progressive on launch.
formula409
  • Last login:January 03, 2021, 02:13:17 pm
« Reply #181 on: August 19, 2020, 02:12:44 am »
The PC version of Final Fight works with CRT Emudriver with super resolutions. You set the width and height to 2560x224.
0zzy
  • Last login:March 09, 2021, 04:14:17 pm
« Reply #182 on: August 31, 2020, 05:02:22 pm »
win10 x64 1909, demul v0.7 180428 wip, crtemudriver catalyst 12.6 for HD 6750 -> demul crash when i try to run any naomi2 games, windows logs report an error about atidxx32.dll
win10 x64 1909, demul v0.7 180428 wip, crtemudriver crimson 16.2.1 for HD 6750 -> i can run naomi2 games but when i run EmulationStation (by jrassa) video card stop working @15 Khz,  it return @31Khz until i quit Emulationstation , look at this video:
https://photos.app.goo.gl/dfh9FAHZJ1gPo6zK7
Someone can help me solve one of these problem?
trev1976
  • Last login:July 13, 2025, 07:24:36 am
« Reply #183 on: September 18, 2020, 04:33:39 pm »
Hi
Whats my best option these days for running taito type x games via the crt emudrivers ?
psakhis
« Reply #184 on: September 19, 2020, 03:16:03 am »
Hi
It depends on the game, most of them with "game loader all rh" works really well, another ones with "typex_loader".
For Nesica games best with "RFIDGod_inject"
trev1976
« Reply #185 on: September 19, 2020, 03:42:24 am »
Hi , I'm mainly interested in the vertical Shooters and 2d Fighters on taito type x one system.
Chaos Breaker (2004)
Giga Wing Generations (2004)
Goketsuji Ichizoku: Matsuri Senzo Kuyou (2009)
Homura (2005)
Raiden III (2005)
Raiden IV (2007)
Shikigami no Shiro III (2006)
Tetris The Grand Master 3: Terror Instinct (2005)
Trouble Witches AC (2009)
« Last Edit: September 19, 2020, 03:57:35 am by trev1976 »
psakhis
« Reply #186 on: September 21, 2020, 11:55:17 am »
No problems with these games...test it with gameloader rh all
Mauroxp
  • Last login:November 22, 2020, 11:03:33 am
« Reply #187 on: November 10, 2020, 07:34:38 am »
Hi .. wich one ?? I installed aio runtimes but still nesica not work
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #188 on: February 05, 2021, 09:49:10 am »
I tested many Taito Type X/X2 games and most of them works. Some required wide resolutions which by default are not installed.
Nesica games but required for example HD or Full resolutions. I'm going to revisit many old system since it changes a lot during last two years in VMamker/groovymame.
feltz
  • Last login:September 25, 2023, 10:57:59 pm
« Reply #189 on: January 27, 2022, 05:02:42 pm »
Anyone have recommended settings for Supermodel emulator with a NTSC setup? Seems the command line args for resolution are for progressive resolutions, as if i specify 640x480 it goes out of range for me
So far the only thing I have ran to get a clear image has been in a windowed mode..
punkfungus
  • Last login:March 16, 2023, 01:09:35 pm
« Reply #190 on: February 06, 2022, 04:08:56 pm »
Hi, I would like know if the N64 emulator Mupen64Plus is compatible with EmuDriver? When I go full screen I get out of sync image.
I got the same issue on some other emulator that was set on OpenGL but I could change for Direct3d but not on Mupen64Plus.
I tried changing many options but without succes. It's the last system I try to setup on my Cabinet all the other are working.
Any info would be be appreciated.
than kyou.
psakhis
« Reply #191 on: February 07, 2022, 12:14:43 pm »
than kyou.
Hi, with Vulkan didn't worked for me. Only with glide. Check this core options:
mupen64plus-rdp-plugin = "gliden64"
mupen64plus-rsp-plugin = "hle"
mupen64plus-rspmode = "HLE"
punkfungus
« Reply #192 on: February 08, 2022, 10:30:05 pm »
Thank for the tips but no succes with it.
I finally tried Project64 and it worked with a video plugins.
cosmartin76
  • Last login:April 27, 2023, 02:24:52 pm
  • I Love Arcade Games!
« Reply #193 on: April 15, 2022, 04:45:35 am »
Hello, I would like to know if CRT emudriver and GM are compatible with Windows 7 Starter lite. Thanks in advance
Monitor CRT Videocolor A59ECY13X01 15KHz
J-PAC Ultimarc
Sapphire Radeon HD 5450 512mb DDR3
GroovyMAME 0.243
CRT Emudriver & CRT Tools 2.0 beta 15 (Crimson 16.2.1  non-GCN cards)
Windows 10 64-bit
Intel Core i3-4150K @ 3.50GHz
GIGABYTE GA-H81M-DS2V Motherboard
RAM 8GB DDR3
psakhis
« Reply #194 on: April 15, 2022, 08:59:24 am »
Yes, i have this configuration.
Moksi
  • Last login:March 17, 2025, 08:13:58 am
« Reply #195 on: May 16, 2022, 12:31:11 pm »
Hello everyone i tried to run Yaba sanshiro  latest emulator i think this is the best emu for Saturn.
The emulator doesnt launch for me unfortunately, Win 10 64bit   , AMD Radeon R9 380  Crt emudriver 2.0 win10
Desktop res 640 x 480 60i    ,  tried to play around with emu settings fullscreen res set to 640 x 480 .
Hope this emu will run with crt emudriver , emu is still progress being worked on.
(with dolphin the video plugin set to opengl results in crt being distorted -> i set it to directx 11 for now)  it doesnt like opengl
psakhis
« Reply #196 on: May 16, 2022, 04:18:06 pm »
Forget that emulator and use emu4crt https://github.com/psakhis/emu4crt
Best Saturn emulator is Mednafen and not his libretro core...
Moksi
« Reply #197 on: June 15, 2022, 05:35:30 am »
Yuzu doesnt run for me , after installing crt emudriver  i get a message
An error occurred initializing the video core.
yuzu has encountered an error while running the video core. This is usually caused by outdated GPU drivers, including integrated ones. Please see the log for more details. For more information on accessing the log, please see the following page: <a href='https://yuzu-emu.org/help/reference/log-files/'>How to Upload the Log File</a>.
OK
faxesystem
  • Last login:January 14, 2024, 07:42:21 am
« Reply #198 on: September 27, 2022, 01:56:25 pm »
I have an Issue with Retroarch 1.10.3 and the Mesen and Mesen-S cores. When I start a game switchres is switching to the correct super resolution. When exiting the game it is not switching back to the default desktop resolution. Other cores like SNES9X and bsnes switch back correctly. The strange thing is, that everything was working before with Mesen and Mesen-S. Maybe a core update broke something?
psakhis
« Reply #199 on: September 28, 2022, 08:04:14 am »
Which backend? It's fine here with opengl.
