Author Topic: Trackball ps2 to usb conversion?  (Read 1600 times)
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
« on: September 24, 2015, 10:36:42 am »
im working on a older cp and it has a trackball installed but with a PS2 plug. I'm running a minipac which does have input wire plugs for a spinner and I believe a trackball.. I don't believe I'll be able to splice the cable into anything to use those inputs so my next bet is just using a ps2
To usb converter. I want to stop by microcenter and grab one. I'm on my phone so research is a little tedious but I've found active and non active, as well as other things I don't know much about. Also, I don't know if any adaptor will read properly for accurate gaming, or if I need to look for something specific. . So, what am I looking for to go ps2 trackball to usb? Thank you for help and sorry I can't do as much research as I'd like.. I'd like to stop and get it on the way home
« Last Edit: September 24, 2015, 10:39:50 am by aldub516 »
geeteoh
  • Last login:May 30, 2017, 09:28:59 pm
  • Connecting with the 80s
    • forum.arcadecontrols.com/index.php/topic,146453.0.html
Re: Trackball ps2 to usb conversion?
« Reply #1 on: September 24, 2015, 01:06:31 pm »
I had issues finding one for my trackball. Maybe this will help.
http://forum.arcadecontrols.com/index.php/topic,146993.0.html
aldub516
« Reply #2 on: September 24, 2015, 02:06:08 pm »
that does help. My only problem now it seems is how to figure out if the adapter is active or passive in the store. Looking online to find a local store, it seems non of them specify if they are active or passive..
eds1275
  • Last login:July 21, 2025, 05:34:15 pm
  • Rock and Roll!
« Reply #3 on: September 24, 2015, 02:31:58 pm »
http://www.amazon.com/SANOXY%C2%AE-USB-Active-Adapter-Electronics/dp/B000I97N1M
I would say go to a computer store and ask for an active one. If they give you one they claim is active but doesn't specify on the packaging, make sure they have a return policy, and let them know you'll be back swinging if they were lying to you!
aldub516
« Reply #4 on: September 24, 2015, 02:33:33 pm »
 I am on my way to Micro Center I'm sure I'll be able to find what I need. My main concern was specifics such as the active or passive element which I was not aware of. I can go ahead and consider this resolved thank you for all the replies.
