Author Topic: Arcade Cabinet Website www.classicarcadecabinets.com  (Read 21961 times)
bdn103
  • Last login:September 05, 2023, 09:29:59 pm
    • Classic Arcade Cabinets - FREE arcade cabinet build plans, printable PDFs and CNC plans
« on: July 20, 2015, 07:21:59 am »
Hello,
I have been a long time "lurker"... but this is my first post here.  A few months back I started a website where I have been posting cabinet measurements.  I strongly believe that this information needs to preserved, much like the artwork. The website if fairly crude, short on information, and I am sure it is riddled with spelling and grammatical errors.... but it is a start. I hope to continue to grow it over the next few year. If anyone has any feedback or suggestions (or even drawings), please let me know.
A liittle background...
I have been in the arcade collecting hobby is 1995. About 2 years ago I built a CNC machine for hobbyist purposes.... and I have cut a few cabinets since then. The CNC is a hobby for me that I use in my limited spare time.
Brian
vwalbridge
Re: Arcade Cabinet Website www.classicarcadecabinets.com
« Reply #1 on: July 20, 2015, 10:26:38 am »
I'm sure you have heard of jakobud.com  The cabinet plans on his page seem pretty good. Someone with more knowledge than me could comment on how accurate they are. (I have personally used his DK and Q*bert plans and have been happy) However, it sounds like you are going for 100% accuracy and easy transition to a wood CNC machine so that is nice.  :cheers:
I checked out your site and I'd like to offer a suggestion:
Make the plans available in pdf and/or jpg. Most common average Joes are not going to be able (or even want) to deal with .dxf or .crv file.
Good collection so far, hope it keeps growing.  :applaud:
bdn103
« Reply #2 on: July 21, 2015, 10:42:54 pm »
This week, plans were added for Gravitar, Black Widow, and Space Duel.
Next up is a Quantum build with custom drawings and tracing a   Rockola cab (Nibbler).
dmckean
« Reply #3 on: July 22, 2015, 12:02:10 am »
+1
mgb
  • North East, US
« Reply #4 on: July 22, 2015, 08:18:45 am »
Hello and welcome.
Thanks for your contribution to the hobby.
Another source of measurements and all that is helpful.
I also agree that having the plans in PDF would be even more helpful.
Keep up the good work and if there is anyway that this community can help in that effort, don't hesitate to ask.
bdn103
« Reply #5 on: July 22, 2015, 08:56:14 am »
Are the PDFs desired because they contain the vectors, or are PDFs desired to have measurements listed?
The concern is that while many of the machines have a lot of straight lines, many of the transitions are very gradual and difficult to document with curve and arc measurements as you would see on an engineering diagram.  Can you point me towards an example of what would be good? I am assuming you are referencing similar to jakobud's drawings.
dmckean
« Reply #6 on: July 31, 2015, 01:13:35 pm »
We want them for measurements and we understand all this. The way most people cut cabs here is using circular saw or table saw for the rough cuts, then using a jigsaw to get things close and then using a file and sander to get the angles the best they can. Then the second panel is cut using the first as a template with a router and a flush trim bit. We really don't need nearest millimeter accuracy, just something that's close enough. PDF is a great format because everyone can open them and read them.
vwalbridge
« Reply #7 on: July 31, 2015, 01:28:22 pm »
+1   I don't even need a drawing for a cab that has square corners and straight lines. Just measurements are fine. Angles don't even matter because I can just measure from each edge to a center point and connect the dots.
As for cabinets that have long sweeping curves (like DK) most guys are just having a 1:1 drawing printed at Staples or Kinkos. Then cut out the drawing and trace it on the wood.
bdn103
« Reply #8 on: September 01, 2015, 08:42:39 pm »
I have added 1:1 PDFs for all of the cabinet side panels. I have also added PDFs for some of the more difficult parts to cut as well. Hope this helps.
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #9 on: September 02, 2015, 07:26:36 am »
Great website!  Thanks for putting in the effort to get some detailed plans.  This should help a lot of people.  The CNC files are particulary helpful and hard to find online, so thanks again. :)
bdn103
« Reply #10 on: October 13, 2015, 11:51:24 am »
Recently added Taito slanted top cabinet plans (Jungle Hunt style) and Reactor plans.
bdn103
« Reply #11 on: November 04, 2015, 12:29:12 pm »
Added plans for Killer Instinct /KI2 to include control panels.
« Last Edit: November 04, 2015, 12:30:59 pm by bdn103 »
menace
« Reply #12 on: November 07, 2015, 07:20:48 am »
Missile command--Its not 100% and the distances are measured to sharp corners so you would have to radius them yourself--but it gets you in the very near ball park..I'm so going to start building these--I love this shape...
Nice job on the website and thanks for making the plans available--I have a dynamo HS-5 somewhere too..
« Last Edit: November 07, 2015, 07:23:42 am by menace »
bdn103
« Reply #13 on: December 08, 2015, 03:03:45 pm »
I added plans for Crystal Castles and Agent X. Also added so reference pictures of the cabinet to help with assembly.
Menace, I have a set Missile Command plans that I have started on. Hope to add them to the site soon.
Brian
Www.classicarcadecabinets.com
ChanceKJ
« Reply #14 on: December 08, 2015, 05:46:41 pm »
« Last Edit: March 19, 2021, 03:27:45 am by ChanceKJ »
bdn103
« Reply #15 on: December 09, 2015, 04:25:04 pm »
Thanks for all of the Nintendo cab information. I have updated the website with the new information for the additional Nintendo cabinets.
Brian
ChanceKJ
« Reply #16 on: December 09, 2015, 04:39:30 pm »
« Last Edit: March 19, 2021, 03:27:21 am by ChanceKJ »
  • Last login:December 19, 2025, 10:05:55 am
« Reply #17 on: December 13, 2015, 04:58:10 pm »
-1
A lot of people are interested in DXF files, as they are more easily able to have a professional CNC shop recreate the actual dimensions, with little issue. There are a lot of great local shops, if you look hard enough, and not everybody who wants a near-perfect recreation wants to deal with making mistakes with manual tools. (I know on my original project, I had to recreate numerous parts many, many times over, whenever I made mistakes, or when I had an issue with the quality of the product after the fact.)
I really like the site, and would recommend if you are planning on providing PDF's, please do not stop providing DXF files as well.
bdn103
« Reply #18 on: December 17, 2015, 02:49:50 pm »
-1
I have been adding printable drawings of all of the side panels and difficult to cut components. I have tried to do some dimensioning of the cabinets, but it takes a lot of time and get confusing / difficult to put measurements on a curve that translates well to wood working tools.
In celebration for the weekend, I posted plans for  the Star Wars / Empire Strikes Back uprights.
Thank you
Brian
bdn103
« Reply #19 on: December 28, 2015, 02:57:29 pm »
Added plans for a Ms. Pac cabaret and Robotron 2084 (which shares the cabinet with the straight front version of Joust).
Brian
bdn103
« Reply #20 on: January 05, 2016, 11:22:27 pm »
Plans were added for the straight top Taito "classic" cabinet. It was used for a bunch of games to include Polaris and Stratovox.
Brian
Www..classicarcadecabinets.com
bdn103
« Reply #21 on: January 23, 2016, 06:04:50 pm »
Added plans for a Mario Bros. Widebody cabinet. Taito trimline plans were added a few days ago as well.
Brian
bdn103
« Reply #22 on: January 24, 2016, 12:47:48 am »
Also added plans for TMNT and other  4 player Konami cabs with updated control panels / control boxes.
Brian
bdn103
« Reply #23 on: February 11, 2016, 08:10:31 am »
Plans added for Dragon's Lair.
Brian
vwalbridge
« Reply #24 on: February 11, 2016, 10:33:57 am »
I'm very impressed. You have a great collection going! Very generous of you to share your work with the community.  :cheers:
bdn103
« Reply #25 on: February 11, 2016, 08:38:17 pm »
Thank you. The site hasn't been up a full year yet and I am amazed at how much progress has been made.  I was hoping for 6-10 plans by now.
Brian
Slippyblade
« Reply #26 on: February 11, 2016, 09:06:20 pm »
I'm feeling stupid.  I can't figure out how to actually get anything from the website.  I see a list of "Recent Updates" but that's pretty much it.  Nothing is clickable, I can't figure out how to DL any of the plans...
acme64
  • Last login:September 14, 2016, 12:36:26 am
« Reply #27 on: February 11, 2016, 09:15:13 pm »
the layout caught me too at first. Hover over the grey menu at the top of the page, a drop down with all the options will appear
Slippyblade
« Reply #28 on: February 11, 2016, 09:19:47 pm »
Got it!  The hover isn't working when viewed through PHProxy, which I use when at work.  Checked it through my tablet and wow - tons of good info there!  Thanks for pointing it out.
acme64
« Reply #29 on: February 16, 2016, 09:34:31 pm »
small layout suggestion. you should probably move the Key image lower down the page, or swap it with the model photo when available. everytime i click a cab i look at that and think...that's not it...
bdn103
« Reply #30 on: February 17, 2016, 05:06:36 pm »
I agree the site needs a re-work. It is the plan over the next few weeks to get things cleaned up and a little more presentable (including the content and all of the spelling / grammar).  It has grown a lot more then I had expected this first year, so many of the areas that I said were "good enough" to get things started never got revisited and fixed.  I am not happy with how the menu system works and menus moving off screen... so like I said, it needs some work.   I am a little embarrassed of the site, but I honestly don't have patience for additional IT stuff when I get home from work, so unfortunately the site will continue to be "quick and dirty" and not a polished gem that it could be.... but the content will continue to grow.
Brian
ChanceKJ
« Reply #31 on: February 17, 2016, 06:18:20 pm »
« Last Edit: March 19, 2021, 03:01:31 am by ChanceKJ »
vwalbridge
« Reply #32 on: February 17, 2016, 06:26:51 pm »
Pre-Classic Nintendo cab
Speaking of Nintendo cabs, this would be a cool one to have plans for:
(Note how upright that vertical monitor is)
*Photo courtesy of mikehoss1414 on KLOV.
His FS thread
« Last Edit: February 17, 2016, 06:28:29 pm by vwalbridge »
bdn103
« Reply #33 on: February 17, 2016, 07:27:56 pm »
Thanks Chance. I've never seen a Sheriff before...definitely a rare opportunity.
Vwalbridge- I have already reached out to Mike Hoss and he was kind enough to take a pile of pictures and measurements of the cabinet. I should have it updated shortly.
On the Nintendo theme, I have someone local allowing me to trace their DK cabaret when the pick up their freshly cut Taito cabinet.
Brian
ChanceKJ
« Reply #34 on: February 18, 2016, 07:09:10 am »
« Last Edit: March 19, 2021, 03:01:19 am by ChanceKJ »
snakezone
  • Last login:April 09, 2021, 04:46:47 pm
« Reply #35 on: February 18, 2016, 07:35:07 am »
Brian
Hi Brian, The site looks very nice, if you need any help, send me a pm, i work as web developer
Enviado desde mi XT1032 mediante Tapatalk
bdn103
« Reply #36 on: February 18, 2016, 12:31:34 pm »
Thanks snakezone for the offer... I may reach out eventually.
I updated the plans for the Radar Scope flat front and the Heli Fire. I am not sure really sure how I should judge these.  The plans are basically a standard Nintendo cabinet with the correct measurements for the side panels and other components. Thanks to KLOVer MikeHoss1414 for taking the measurements. With that said, the internal structure for mounting the "TV" is not represented in the drawings. There is a line representing the approximate placement on the front edge of the TV cabinet / monitor shroud.    I am not sure how relevant this placement is outside of authenticity.
I believe the drawings will allow for the creation of a Nintendo cabinet that will allow for the marquee, control panel, etc... to fit, and the cabinet will look authentic, but the individual components would not be interchangeable between the drawing below and an original cabinet e.g. is the coin door hole the same between this cabinet and a classic Nintendo (DK style) cabinet... not a clue.  I am not sure I would call it a tribute cab, since the original measurements were referenced.
I also have a set of plans I am trying to get verified for a Gauntlet at the moment. I also have a set of plans to verify for a tapper. If I can get these verified, I will get them posted shortly.
Brian
ChanceKJ
« Reply #37 on: February 18, 2016, 05:50:38 pm »
« Last Edit: March 19, 2021, 03:01:09 am by ChanceKJ »
Slippyblade
« Reply #38 on: February 18, 2016, 05:59:29 pm »
I've been looking for Pac-Man cabaret plans for ages  Every time someone asks about that cab, they get linked to the Ms Pac cabaret...  which is a totally different cab.  The Pac-Man cabaret is the same as Rally-X.
johnrt
« Reply #39 on: February 18, 2016, 06:04:49 pm »
I will KILL for a nintendo cabaret.
...Get those plans up and we'll make a small series of videos for it on the youtube channel.
+1
I have actually been thinking about building one. Gimme those plans!!!!!!  :lol
« Last Edit: March 04, 2016, 09:39:57 pm by johnrt »
