Author Topic: Kaboom! - A tribute. || Atari theme - Circus game addition, just for fun.  (Read 32805 times)
jdbailey1206
Re: Kaboom! - A tribute. || Atari theme - Final Control Panel Design
« Reply #80 on: January 23, 2015, 08:28:47 am »
Looks snazzy.  I feel like the CP is at too sharp of an angle.  It, to me, would feel awkward using the spinner at that angle.  I'm digging the fake atari look though.  The cartridge was a nice touch.
Louis Tully
« Reply #81 on: January 23, 2015, 08:42:08 am »
« Last Edit: February 12, 2015, 07:03:01 pm by Louis Tully »
Locke141
  • Never grow up.
« Reply #82 on: January 23, 2015, 08:53:14 am »
Would love a copy of your skech up or any any thought about how it could be modified for 2-4' foot tall people. I'll pm to sort the best way to share it, google drive?
This is looking great. Is  your dad's plug and play like Atari going to make it into the build? It would wouldn't take away from the look if the CP was on a hinge and the remote and an av switch were underneath. Even if you never play the all in one it may be nice to have something of your dads incorporated in to this build.
« Last Edit: January 23, 2015, 08:59:22 am by Locke141 »
Louis Tully
« Reply #83 on: January 23, 2015, 08:58:08 am »
« Last Edit: February 12, 2015, 07:03:06 pm by Louis Tully »
Locke141
  • Never grow up.
« Reply #84 on: January 23, 2015, 09:02:39 am »
That probaly the right call with the plug and play. Looking forward to playing with you skechup file.
« Reply #85 on: January 23, 2015, 10:59:26 am »
Will those toggles do anything?
Louis Tully
« Reply #86 on: January 23, 2015, 11:17:46 am »
« Last Edit: February 12, 2015, 07:03:17 pm by Louis Tully »
« Reply #87 on: January 23, 2015, 11:37:11 am »
Alright, Yasiin Bey was exactly the answer I was hoping to hear.  ;D
AzureKnight
« Reply #88 on: January 23, 2015, 02:44:29 pm »
LT I think that looks perfect!
Superfrog
    • My YouTube Channel
« Reply #89 on: January 24, 2015, 05:12:38 am »
Louis,
This is the best conversion of a classic feel in a modern jacket.
I think Atari will  :banghead: :banghead: that they didn't came up with this great idea  :cheers:
Let the building process starts  :notworthy:
Louis Tully
« Reply #90 on: January 25, 2015, 05:45:34 am »
« Last Edit: February 12, 2015, 07:03:36 pm by Louis Tully »
jaharr01
Re: Kaboom! - A tribute. || Atari theme - Marquee and Control Panel v1
« Reply #91 on: January 25, 2015, 08:26:19 am »
Jelly of your sketchup skills.  I need some damn practice.
Thanks, JD. I've still got a long way to go. Some folks can recreate each individual piece, like the threads on a pushbutton and ---steaming pile of meadow muffin--- like that.  :dizzy: I'm still working with cylinders.
dremel and assorted Bic pens to make an appearance.
^^None of this^^
Anyway...
Awww, damnit!  :-\
How about just the Dremel part?
Atari cabinet version. I keep repeating the KISS principle in my head.
Not as complicated or time consuming as a brick pattern but I'm digging the Atari console feel. Dealing with the dust and whatnot that'll gather in those grooves will be annoying.
My attempt to stain the Asteroids cab didn't go well. I want another shot.
Hey L.T that looks awesome. You said you messed up staining what did you do? How did you do it?
Did you use that good finished plywood or veneer it, or did you use plain plywood?
I've done a lot of staining over the years and there are a few things you have to do to make it look good.
1. Really sand good to get all the and marks out.You have to go down to prob 220 sandpaper
2. Get every bit of oil off the area by taking  alcohol or acetone and clean the areas.It will make light and dark spots if you don't
3. when you put the stain on go with the grain of the wood with a brush, a little goes a long way.always wipe off excess
4. if it looks bad sand it with 220 and do it again.
5. If you have small areas that are really light you can lightly stain those areas leave it till it dries and lightly rub.
6. each type of wood takes stain differently and looks different it' something to remember.
6. When you stain you always need to clear because it looks like --I'm attempting to get by the auto-censor and should be beaten after I re-read the rules-- if you don't.
7. I used minwax dark walnut on that last one I did.
8. Also make sure to scrape any signs of wood glue or stain won't stick in that area
Stain is tough it's not very forgiving, it will show every F'up and sand mark
Jay
jaharr01
« Reply #92 on: January 25, 2015, 08:35:26 am »
how did you mess it up it looks fine?
Louis Tully
« Reply #93 on: January 25, 2015, 12:44:57 pm »
« Last Edit: February 12, 2015, 07:03:52 pm by Louis Tully »
Louis Tully
Kaboom! - A tribute. || Atari theme - Lever Switch Design
« Reply #94 on: January 27, 2015, 05:52:45 am »
« Last Edit: February 12, 2015, 07:04:02 pm by Louis Tully »
jdbailey1206
Re: Kaboom! - A tribute. || Atari theme - Lever Switch Design
« Reply #95 on: January 27, 2015, 06:30:12 am »
Busy citizen of Tinkertown.
Psssh.  Friggin' Mayor... :)
Louis Tully
« Reply #96 on: January 27, 2015, 09:47:54 am »
« Last Edit: February 12, 2015, 07:04:09 pm by Louis Tully »
« Reply #97 on: January 27, 2015, 11:37:58 am »
Are they all going to be a momentary switches then? You will need some other stuff going on in there for toggles.
Generic Eric
« Reply #98 on: January 27, 2015, 11:51:17 am »
Would it be easier to find a functional replica, recess it, then find the 1/4 metal shaft to extend it?
Louis Tully
« Reply #99 on: January 27, 2015, 12:12:39 pm »
« Last Edit: February 12, 2015, 07:04:16 pm by Louis Tully »
  • Last login:Yesterday at 08:32:45 pm
« Reply #100 on: January 27, 2015, 12:52:57 pm »
Technically, the Atari switches slid up and down. They didn't pivot.  >:D
Louis Tully
« Reply #101 on: January 27, 2015, 01:14:29 pm »
« Last Edit: February 12, 2015, 07:04:22 pm by Louis Tully »
jdbailey1206
« Reply #102 on: January 27, 2015, 01:43:59 pm »
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XAtari+2600+non+working&_nkw=Atari+2600+non+working&_sacat=0
Here is just a quick ebay search.  You could pilfer the switches from the Atari and nuke the rest.   And thats just from a non working search.  I'm sure more would pop up doing a search for Atari 2600.
« Last Edit: January 27, 2015, 01:51:07 pm by jdbailey1206 »
ChanceKJ
« Reply #103 on: January 27, 2015, 04:48:27 pm »
Yeah...  What...  HE, ... Said...  ::)
 :P
:applaud: I agree with the Atari look. Maybe try and gutt an old Atari for the switches and put them right below the display glass?
Best Electronics carries the "Atari 2600 / 2600A Momentary  Reset / Select Switch CO10388".
  • Last login:Today at 04:51:34 am
« Reply #104 on: January 27, 2015, 05:04:16 pm »
To be fair, I forgot to mention the minimum credit card purchase from Best is $20 according to this page.   :embarassed:
The switches in question are only $2.50 each.
« Reply #105 on: January 27, 2015, 05:09:53 pm »
You gut a working Atari, I'll gut you ---maternal-smurfs---.
Louis Tully
« Reply #106 on: January 27, 2015, 05:21:02 pm »
« Last Edit: February 12, 2015, 07:04:29 pm by Louis Tully »
« Reply #107 on: January 27, 2015, 05:25:15 pm »
You gut a working Atari, I'll gut you ---maternal-saint's minions---.
Not a chance, dude. I'm making my own levers.
No love for the build your own 'round here.
I wasn't talking to you, bro.  :cheers:  :notworthy:
jdbailey1206
« Reply #108 on: January 27, 2015, 07:35:02 pm »
Damn.  Try to give an opinion and get ostresized.    :P
« Reply #109 on: January 27, 2015, 07:39:12 pm »
I think you meant disemboweled.
« Reply #110 on: January 27, 2015, 07:47:27 pm »
I thought he meant Oster-ized.   >:D
jdbailey1206
« Reply #111 on: January 27, 2015, 08:31:17 pm »
No.  I meant both of you can ---display unending love for my bottom---.   >:D
  • Last login:November 19, 2025, 06:13:57 pm
« Reply #112 on: January 27, 2015, 09:45:07 pm »
Cool project LT!
About those switch levers, you could always make them out of aluminum round stock. Easy to shape with a sander, bore a hole in the side for the pivot, and would probably look better, JMO.
But hey, it's your project so do what you want. Im sure it will look great, based on your other projects.
Louis Tully
« Reply #113 on: January 28, 2015, 06:55:47 am »
« Last Edit: February 12, 2015, 07:04:46 pm by Louis Tully »
« Reply #114 on: January 28, 2015, 12:07:57 pm »
Good call.
Just remember not to use a "regular" grinder stone on that aluminum.
Aluminum melts while being ground and can flow into the stone's crevices, leaving aluminum in the stone.
When the aluminum cools, (expands from heating during the next grinder use), it expands and can crack the stone, causing it to possibly fly apart at a later time. Not a good thing especially if its a bench grinder and you are standing in front of it when it blows.
But aluminum is a soft metal and can be easily and safely shaped with a sander. (Just have plenty of spare belt or pad media for the sander.)
« Last Edit: January 28, 2015, 01:21:25 pm by DaOld Man »
Superfrog
« Reply #115 on: January 28, 2015, 12:21:05 pm »
And this way building the aluminium sliders?
Just like the Power switch http://forum.arcadecontrols.com/index.php/topic,135301.120.html
Looks easy to me  :cheers:
Good Luck Louis
« Reply #116 on: January 28, 2015, 02:12:57 pm »
Good Luck Louis
I was thinking the same thing. Instead of a wooden "knob" just drill a hole in the sliding piece, insert and glue the aluminum round stock piece. (After you have sanded a rounded edge on the exposed end of the stock.)
Does the original Atari power switch stay in the up position or spring return?
Louis Tully
« Reply #117 on: January 28, 2015, 03:23:54 pm »
« Last Edit: February 12, 2015, 07:05:00 pm by Louis Tully »
  • Last login:November 18, 2025, 03:43:09 pm
« Reply #118 on: January 28, 2015, 05:09:01 pm »
Again, watching intently. The quality of the builders on this forum consistently amazes me.
« Reply #119 on: January 29, 2015, 11:51:20 am »
Good call.
Very informative.  :notworthy:  Don't you work with aluminum for a living?
I knew I did something for a living, just couldn't remember what. LOL.
