Author Topic: Upright Star Wars Cabinet dimensions  (Read 1403 times)
valiant
  • Last login:March 05, 2022, 02:49:23 pm
  • One of three lions...
« on: January 07, 2015, 02:51:38 pm »
Quick query I hope someone can help with?
On the Upright original Star Wars cabinet for those members who have one, what is the offset between the front of the coin door panel and the front / leading edge of the side panels please?
Does the same offset appear at the back of cabinet as well?
Many thanks in advance - trying to get a cabinet CNC cut and this is the dimension I am missing!
Re: Upright Star Wars Cabinet dimensions
« Reply #1 on: January 07, 2015, 03:33:23 pm »
I can check when I get home.  You're talking about how far the front panel is recessed from the edge of the sides correct?  IIRC it's a 1/4" but I'll measure for you.
valiant
« Reply #2 on: January 07, 2015, 04:50:18 pm »
Le Chuck - that's right. Wasn't quite sure how to word it!
Finished the CNC AutoCAD drawings but this is the only dimension I don't have.  If you could also check if there is a recess at the back and top, that would be helpful.
Scant few of these cabs left in the UK!
Many thanks - Nick
  • Last login:July 27, 2025, 08:34:04 pm
« Reply #3 on: January 07, 2015, 05:00:58 pm »
Here's some photos I have...
valiant
« Reply #4 on: January 07, 2015, 05:30:56 pm »
Yotsuya - thanks for those.  If I read the markings on the tape correctly, that's 1/2" recess, correct?
« Reply #5 on: January 07, 2015, 05:34:32 pm »
Yes sir- a half-inch from the front
valiant
« Reply #6 on: January 07, 2015, 05:40:24 pm »
« Reply #7 on: January 07, 2015, 06:08:21 pm »
BTW, there isn't any offset on the very back. And the first photo is the amount that needs to be routed on the front panel for the control panel.
« Reply #8 on: January 07, 2015, 06:18:03 pm »
Yup, I remembered wrong!  It's a half.
Generic Eric
« Reply #9 on: January 08, 2015, 09:21:31 am »
When you finish, and you have everything dimensioned, consider posting it here:
http://newwiki.arcadecontrols.com/index.php?title=Cabinet_Plans
Generic Eric
« Reply #10 on: January 08, 2015, 12:56:24 pm »
Valiant
I look forward to your project.  Is Valiant chosen from Clone Wars?  Or is that a coincidence?  Do you plan an alternate side art?
What is the turn around time when you send the files and for them to be cut and delivered?
