Author Topic: Opto Couplers used for?  (Read 2612 times)
vanwatson
  • Last login:January 02, 2015, 09:21:39 pm
« on: December 27, 2014, 04:27:19 pm »
What are arcade opto couplers used for?
I see opto couplers used for joysticks, guns, rollers, track balls etc.
But why did they use opto couplers?
Anywhere else in arcade games they use opto couplers?
  • Last login:August 23, 2025, 09:14:19 pm
Re: Opto Couplers used for?
« Reply #1 on: December 27, 2014, 07:57:09 pm »
Im no expert but I think it is for a backup, just in case the plasma coupling fails.
« Reply #2 on: December 27, 2014, 08:03:16 pm »
Mostly to communicate with optopuses... or is it optopi?  I always get those confused.
SavannahLion
« Reply #3 on: December 27, 2014, 10:27:19 pm »
Wait... it's not used in conjunction with the Flux Capacitor?
No wonder I keep ending up in 1985!
« Reply #4 on: December 27, 2014, 10:46:43 pm »
It used to be used with the flux capacitor, but that's copyrighted now so they had to quit. I think it utilizes the new pentode vacuum tube now.
vanwatson
« Reply #5 on: December 30, 2014, 10:35:00 pm »
why do joysticks and guns have to use opto couplers?
ed12
« Reply #6 on: December 30, 2014, 11:21:48 pm »
the short answer is they replace switch's
as they are the same basicly
ed
vanwatson
« Reply #7 on: December 31, 2014, 12:41:42 am »
opto couplers replaced the leaf switches?
ed12
« Reply #8 on: December 31, 2014, 12:49:40 am »
the term explains its-self
opto-coupler
which mean's it couple's 1 singal to another "with-out-contact"
so a light beam is sent from 1 led to a ird reciever
this is a colsed circuit to the opto
interrupt it and it the opto coupler is open
hence open/colsed >switch<
it is both electronic and isolated
about that simple,where a switch is by nature mechinical
so some thing has to "push" the switch to open or colse
by nature a actuater arm,and or a plunger
same dif
ed
