Author Topic: MAME issue, cannot map player 1/player 2 start button  (Read 11016 times)
Jive
  • Last login:December 31, 2018, 11:59:31 am
« on: October 14, 2014, 08:00:37 am »
Hello!  After many years of lurking, I decided to join the forums after almost giving up on a MAME issue that is kicking my butt.
I have built two MAME cabinets in the past, all using Hyperspin, and have had very little issues. I decided to build another cabinet for a friend, and have never had so much trouble fixing one small thing, mapping the player 1 and 2 start buttons.
I'm using the Xin Mo USB controller (if that matters), as I've used on my other builds.  I go into the general inputs, and map the player start buttons as joystick button 0, and joystick button 1.   However, they do not work at all.  If I go into the game specific inputs, it shows that the start buttons are mapped as keyboard 1, and 2.  Isn't the general inputs supposed to override the game specific settings?
As a test, I loaded up Frogger, went to game specific inputs, and changed the mapping to my joystick button 0, and 1, and that works fine.  BUT, I can't do that for all 500 or so games.  I've also tried deleting the default.cfg file, but that did not work.   Any ideas?
Thenasty
  • Trade Count: (+17)
  • Last login:December 04, 2025, 11:40:37 am
Re: MAME issue, cannot map player 1/player 2 start button
« Reply #1 on: October 14, 2014, 08:14:19 am »
Start Buttons are not Joy 0 or Joy 1, its labeled as Start 1, Start 2 etc...and for coin insert are Coin 1 Coin 2 etc...
This should be defaults for Coins  5, 6 etc.. Starts are 1, 2 etc...
« Last Edit: October 14, 2014, 08:16:07 am by Thenasty »
Free VGA Breakout Cable
Jive
« Reply #2 on: October 14, 2014, 10:56:43 am »
Right, the Start 1 and 2 is defaulted to keyboard 1 and 2.  My start buttons on my MAME controls come up as joy button 0 and 1.  My issue is that when I map them as a general input, it does not change them in the game specific inputs, thus they do not work.
EDIT:  As a side note, I tried this in my MAME setup on my work computer, which is version 0.139.  No matter what you remap the start buttons to, they stay as keyboard 1 and 2.
« Last Edit: October 14, 2014, 11:27:18 am by Jive »
Thenasty
« Reply #3 on: October 14, 2014, 03:58:50 pm »
maybe missing INI/CFG or it's READ ONLY.
Jive
« Reply #4 on: October 14, 2014, 09:30:00 pm »
Not sure.  I had a friend of mine try it on his MAME setup, and his does the same thing.  Very weird.
Haze
    • MAME Development Blog
« Reply #5 on: October 15, 2014, 05:17:21 am »
maybe you're remapping the wrong things
the ones you want to remap are in
Inputs (General)
 -> Other Controls
1 Player Start
2 Player Start
if you remap the ones in
Inputs (General)
 -> Player 1 Controls
 P1 Start
it WILL NOT work, because that's for start buttons on Mahjong panels and such devices.
