Author Topic: Aimtrak recoil overheating?  (Read 1554 times)
sublimejhn
  • Last login:December 25, 2015, 02:47:23 am
« on: August 12, 2014, 01:48:39 am »
For those out there with recoil kits in their Aimtrak guns, I am looking for some suggestions as to what might be going wrong with mine. I have recently installed a recoil kit, and I am using a kodak 36v 3a power supply, which seems to be a common choice on this forum and others for the recoil kit. Everything works fine, but my recoil solenoid is getting EXTREMELY hot when playing games that involve a lot or rapid shooting. For example, I was just playing through House of the Dead, and by the time I killed the second boss (the one with the bats), the section of my gun with the solenoid was actually too hot to touch, and I could smell the burning plastic. I opened it up and saw that the plastic on the inside was in fact starting to melt a bit in a couple spots.
I haven't seen anyone else having this issue. I did notice a couple threads where people have added a machine gun mode to their gun and have noted the solenoid was getting hot, but that is firing much faster than mine is so it is understandable. I don't feel I hooked anything up wrong, the instructions were pretty straight forward and everything works fine otherwise so I would assume it is connected properly, but I'm open to suggestions. I have also made very certain there is nothing in the way of the plunger, and it slides in and out of the solenoid freely.
Anyone have any ideas?
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
Re: Aimtrak recoil overheating?
« Reply #1 on: August 12, 2014, 07:01:34 pm »
Turn your recoil strength down, and use a DMM to see if the PSU is actually holding up 36v under peak load.
sublimejhn
« Reply #2 on: August 13, 2014, 01:25:40 am »
Wow, I feel kinda stupid. For some reason it never even crossed my mind to drop the recoil strength (kinda forgot I could). Dropped it down about 1/5 of the way and no more heat issues, and I can't even feel a noticeable difference in the recoil. Thanks!!
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
« Reply #3 on: August 17, 2014, 06:07:32 am »
TURN IT BACK UP AND SHOOT THROUGH THE PAIN!!!
