Author Topic: An other rotating monitor  (Read 34207 times)
GORF000
  • Last login:December 29, 2015, 06:08:47 pm
« on: June 14, 2014, 02:30:14 pm »
Hi everyone
I'm working on this project for a while now. I take few time for me this afternoon to testing and tuning the screen rotation. It still need some adjustments but I cannot wait anymore to share it.
I'm using an hitec high torque servo with a maestro servo controller.
TopJimmyCooks
  • Last login:March 01, 2026, 03:28:53 pm
Re: An other rotating monitor
« Reply #1 on: June 15, 2014, 05:36:51 pm »
party on Gorf.
darthpaul
  • Last login:April 20, 2026, 01:24:27 pm
  • Join, It's your duty
« Reply #2 on: June 20, 2014, 11:17:36 pm »
 I really like the servo idea, can you supply a link to the type of servo you are using and please some pictures of the linkage you are using? Are you going to automated the rotation or just use a button for rotation?
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
GORF000
« Reply #3 on: June 22, 2014, 06:35:02 am »
Here the servo I'm using. It's really small but strong enough to spin my 24" 16:10 monitor.
http://www.canadarobotix.com/robot-parts/motors/servo-motors/hitec-premium-servos/hitec-hs-645mg
The rotation will be atomated, the frontend will handle when the monitor need to rotate.
I'm here if you need more informations or pics.
  • Moderator
  • Last login:April 19, 2026, 07:24:05 pm
« Reply #4 on: June 22, 2014, 12:20:23 pm »
I like.
Whats the threaded rods and washers for on the back? Counter weights?
GORF000
« Reply #5 on: June 22, 2014, 01:22:46 pm »
Exactly! I balanced my monitor to make the rotation smoother.
darthpaul
« Reply #6 on: June 27, 2014, 11:15:10 pm »
I love servos :applaud: Ken, could Controlchoose key on a games screen orientation like it does with it's controls?
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
  • Moderator
« Reply #7 on: June 28, 2014, 08:57:52 am »
No, control choose only looks at the game controls.
You could use startcom to call a program that would do pretty much anything you wanted, based on game orientation.
darthpaul
« Reply #8 on: June 28, 2014, 10:10:36 pm »
That was going to be my next question. Using a servo to rotate an LCD monitor to me seems to be a much easier solution than what myself and others have been doing. No limit switches, no motor drives to change the motor direction, no special gearing or linkages and you can still use startcom to automate rotation.
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
« Reply #9 on: June 30, 2014, 09:16:01 am »
I really need to stop thinking of servos as those cheap weak plastic things in the remote control cars I had as a kid.
bandit721
  • Last login:November 14, 2018, 11:53:15 am
« Reply #10 on: September 15, 2014, 10:14:52 am »
GORF,
This is great...very simple and in the same league from a cost standpoint as the popular fiction setups that DNA Dan/Top Jimmy pioneered (that's what I currently have).  So quick question, do you have the entire weight of the monitor on the shaft of the servo or is there a lazy susan bearing or something providing support that we can't see from the pictures?  If a 24" monitor is being supported (and rotated by just a direct connection to the shaft of a servo, we that's damn impressive.  Do you have any other pics of the linkage/mount that you fabricated?  Did you get this into a cab and if so how's it holding up?
Thanks and again, great work!
Les73gTx
  • Last login:August 26, 2015, 11:02:42 pm
« Reply #11 on: September 15, 2014, 01:00:35 pm »
I would like to see more pictures of the mounting and setup. I know the R/C servos are durable but I don't think you could mount the weight of the monitor directly to the servo. The picture posted looks like that is how it is ... long term daily use that way would for sure shorten the life.
GORF000
« Reply #12 on: September 15, 2014, 07:13:13 pm »
Arg! It's hard to take a good picture... I'm building a slim cabinet. So it does'nt have a lot of clearance. Hope it help.
The monitor is supported by a vertical bearing and a servo hub who fit perfectly in the bearing. It's not mounted at the moment but I will post pics when it does.
Ask if you need more detail.
bandit721
« Reply #13 on: September 16, 2014, 10:17:03 am »
Ahh...Now it makes more sense  ;D
Really cool!  Can you provide model/spec info for the bearing & hub or the source of it?  That would be great!
Thanks in advance,
Chris
GORF000
« Reply #14 on: September 16, 2014, 06:26:44 pm »
The servo hub come from there https://www.servocity.com/html/servo_shaft_hub___500__.html#.VBi2YcuV2Ag
I took the bearing on ebay. It was about 6$ and free shipping. Anyway, just find a bearing with an hole the size of the hub.
bandit721
« Reply #15 on: September 17, 2014, 09:58:58 am »
Cool, thanks!
I had actually found the shaft/hub on the same site while researching on Google so thanks for the verification.  When I was poking around for the flange bearing I couldn't find anything that had a depth/thickness of less than 1" and my concern is that the shaft on the hub/shaft is only 7/8"...I guess I'll keep looking.
Thanks again for the info!
BorgDog
« Reply #16 on: January 11, 2015, 04:49:38 pm »
Bringing back a slightly old thread, but would this bearing, also from ServoCity work?  https://www.servocity.com/html/1_2__bore_flat_bearing_mount__.html#.VLLvadXF8n5
I'm just getting started on planning my little rotating project and am trying to gather all the parts/spec to get going.
My Projects:
RossG42
  • Last login:March 30, 2026, 12:15:18 pm
« Reply #17 on: February 14, 2026, 11:15:49 am »
I used the same bearings but wish I’d seen that splined hub! Ended up using a splined flange and shaft then marine-Tex epoxy to “set” everything when adjusted properly
