Author Topic: Mostly black marquee  (Read 1529 times)
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
« on: May 24, 2014, 09:04:13 pm »
My design is very minimal - 95% black with lettering in a white font with a few thin white lines - do I want light to be able to come through the black? I know this is partially personal preference, but not sure what the "done thing" is...
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
Re: Mostly black marquee
« Reply #1 on: May 25, 2014, 03:12:13 pm »
i would do it by masking off the parts that you want to the light to go through then spray with opaque black. should be enough to block off unwanted light.
ChanceKJ
« Reply #2 on: May 25, 2014, 04:31:26 pm »
I've been thinking about how to do this too. I'm gonna test with mine when I get it printed. I know exactly what your thinking here.  Maybe if I used a thin cellophane material behind my marquee plexi and sprayed that to test light bleed on black before spraying the actual plexi back first.
s_busby_uk
« Reply #3 on: May 25, 2014, 05:01:45 pm »
Hmm, I may not have been that clear in my OP. I'm asking if I'm supposed to let the light through or not or if I should block it out as much as I can. How to block it out would be a possible follow-up question!
ChanceKJ
« Reply #4 on: May 25, 2014, 05:21:40 pm »
I don't think you should or shouldn't do anything. It's going to be what you want overall.
Like my Marquee for my Flynn's build. the Left side of it is black. I'm wondering if i shouldn't black that out completely, or give it that dark backlit glow. Really depends on what will look better.
At the end of the day you can make your marquee look however you want. Backlit, non-lit. Hell, i'm currently trying to figure out if i can use Neon or Nixie tubes for the marque on one of my projects. And thats definitely not to anyones standards or rules but my own.
eds1275
  • Last login:August 26, 2025, 11:32:44 am
  • Rock and Roll!
« Reply #5 on: May 25, 2014, 05:50:56 pm »
Mine is also mostly black and it sort of glows a bit but you can't really tell because the whites are so bright. I wouldn't make this an issue unless you know for sure you want them black as night.
mgb
  • North East, US
« Reply #6 on: May 25, 2014, 09:28:11 pm »
It seems that some get a littke anal about the black in a marquee being true bkack and not letting light through and that's fine as its personal taste. But for me, my marquee has a god deal of black and I took no other action other than having the artwork printed from gameongrafix. The black glows a little but otherwise looks great.
« Reply #7 on: May 25, 2014, 10:24:18 pm »
On the back paint the black areas with adhesive and apply foil a bit at a time. Like you're doing gold leaf - only carefuller. No light shall bleed through evar!!
lol, just stick it in there, it'll look fine with some bleed
