Author Topic: FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED  (Read 592630 times)
obsidianmystic
  • Last login:December 31, 2020, 04:51:49 pm
Re: FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED
« Reply #1000 on: December 31, 2020, 09:02:28 am »
Sorry I think my request got buried, would I be able to nab those plans? It looks beautiful!
ChanceKJ
« Reply #1001 on: December 31, 2020, 09:07:41 am »
« Last Edit: March 19, 2021, 02:03:49 am by ChanceKJ »
georg.hahn
  • Last login:January 09, 2021, 12:35:26 am
« Reply #1002 on: January 01, 2021, 05:53:10 pm »
Hey Chance!
Woow! Awesome build with real big love for the detail.
I've already downloaded the 2.0 - file from your earlier posts in this thread. This will be a big help for building my own one.
I'm not sure which additional information is in the "plans" everyone keeps asking. But if there are more infos inside it would be great to get them.
very thankful for your thread!
ChanceKJ
« Reply #1003 on: January 02, 2021, 12:50:08 pm »
« Last Edit: March 19, 2021, 02:03:53 am by ChanceKJ »
BigCaah
  • Last login:October 30, 2023, 02:58:01 pm
  • Learning new skills through old hobbies
« Reply #1004 on: January 03, 2021, 12:36:35 pm »
This build is FANTASTIC!!
I just received spousal approval myself.. "Honey, the kids will love it".. and have started doing research. It's going to take some time  :)
Would you be willing to share the plans that others have asked about?
fasteddy
  • Last login:September 12, 2023, 07:09:43 pm
« Reply #1005 on: January 08, 2021, 03:09:24 pm »
I joined the forum just so I could compliment your build and ask for plans (can't PM yet as I'm too new). I'm planning on building something very similar with my son and have only recently realized what a tall order that is. Your plans would go a long way towards helping. Of note, I'm planning on making the cab somewhat modular so it can be taken apart and moved more easily. I'm happy to send back my adjustments if you're interested. I've got a homemade CNC, so I plan on doing everything up as vector files.
ChanceKJ
« Reply #1006 on: January 08, 2021, 03:58:29 pm »
« Last Edit: March 19, 2021, 02:03:58 am by ChanceKJ »
deezdrama
  • Last login:January 25, 2024, 09:45:32 pm
    • forum.arcadecontrols.com/index.php/topic,146268.0.html
« Reply #1007 on: January 08, 2021, 04:29:59 pm »
Hey Chance..... Im probably one of many who copied your design and built a Mortal Kombat themed cab in 2015 but cheaped out on the buttons and used single color LED buttons originally.
Well my job closed because of this stupid covid crap and so have a bunch of time on my hands at the moment and I am building a new PC for the cab and doing a facelift on it and just ordered Ultimarc rgb buttons and 2x ledpac64's......
 Anyway, I originally had led lit balltops on my sanwa jlf's but decided to replace the balltops with white bat tops and stiffer springs and am thinking about just lighting the joystick shaft holes like you did. I ordered clear dust covers and rgb LED's with pigtails and connectors already installed, they will plug right into the pac64's and plan on just doing what you did with acrylic or polycarbonate tubing but have a question.....
Do you think a single RGB led would illuminate the clear tubing piece good enough if i scuffed the tubing up good to make it diffuse? I think you ended up using 2 per hole but I think you did some testing with a single rgb led at one point and wondered if you thought a single put out enough light to look decent?
I also thought about just angling a single rgb led up at the dust cover and just sanding the bottom of the dust covers to make them opaque/diffused, did you ever try that?
Thanks! :cheers:
ChanceKJ
« Reply #1008 on: January 08, 2021, 05:11:11 pm »
« Last Edit: March 19, 2021, 02:04:01 am by ChanceKJ »
deezdrama
« Reply #1009 on: January 08, 2021, 05:20:36 pm »
Yes, I definitely did some testing, but it wasn't on the count of the LED's in the stick, It was pretty much planned from Day 1 that I was going to have a pair on each stick and have them light from the left and right sides. Not really sure why I made that decision, just did. I'm sure you could use one LED, but I'd recommend positioning it between the player and the shaft of the stick, pointing away from the player towards the stick, and not from "above" pointing back at the player.  I'd also recommend scuffing up the plexi tube to help defuse the light better.
I never did try scuffing the dust washers, as I had planned for them to have the player number on each laser etched into them, plus I wanted to see down into the hole, and have a good amount of light come up and hit the smoke ball tops.
Ok, Ill have to do some testing. I think today im going to pull the whole control panel off and try to get my cab upstairs in my room  :dizzy: Im tired of it being used as an intable in the living room lol.
thanks for the quick reply!
disbudsfru
  • Last login:January 29, 2021, 07:41:25 pm
« Reply #1010 on: January 19, 2021, 05:17:24 pm »
Hi Chance, your project is awesome. The detail is incredible and I really like that it doesn't take up an insane amount of space. I've built a 2-player cabinet which easily fits through a standard doorway and looking to do a 4-player with removable control panel that will also be relatively easy to move.
I just created an account so can't DM, yet. Are you able share the plans via DM?
Thanks a bunch.
norttron
  • Last login:January 21, 2021, 02:19:53 pm
« Reply #1011 on: January 20, 2021, 01:42:22 pm »
Amazing build! I tried getting your pdfs and the link seems dead. Can you send me a pm with your plans? Thanks!
ChanceKJ
« Reply #1012 on: January 20, 2021, 06:07:56 pm »
« Last Edit: March 19, 2021, 02:04:07 am by ChanceKJ »
valdan
  • Last login:January 14, 2025, 01:33:14 pm
« Reply #1013 on: January 26, 2021, 02:57:43 pm »
Hey! I've been following your gallery and Deez's updates on Reddit. I'm hoping to find the control panel plans if possible! Everything else has been amazing and really got me going. Just looking at everything has been inspiring and really got me wanting to do the wiring (my favorite part) and learning the woodworking as I go!
My last question is I have a 47" TV that has been retired, would this work for that as well or would your recommend sticking to 32" to reduce bezel space?
Thanks again, this is truly fantastic work!
casey914
  • Last login:January 27, 2021, 09:08:15 am
« Reply #1014 on: January 27, 2021, 08:53:34 am »
Good morning!  Super high quality work.  I am new and apparently can't send PMs but could chance, the op please email me the side pdf to caseyparkin@gmail.com?
Thank you.
ChanceKJ
« Reply #1015 on: January 27, 2021, 01:46:04 pm »
« Last Edit: March 19, 2021, 02:04:11 am by ChanceKJ »
B0RGS
  • Last login:March 06, 2023, 07:55:07 pm
« Reply #1016 on: January 31, 2021, 11:41:07 pm »
Looking to build myself an arcade machine this year and I think yours checks all my boxes. Willing to share your design? Much obliged!
ChanceKJ
« Reply #1017 on: February 01, 2021, 10:23:11 am »
« Last Edit: March 19, 2021, 02:04:14 am by ChanceKJ »
Ohdukes
  • Last login:April 03, 2021, 08:05:20 am
« Reply #1018 on: February 05, 2021, 09:42:06 am »
Chance,
This is awesome! I'm going to start building one ASAP.
I would love to have those plans if your willing.
ChanceKJ
« Reply #1019 on: February 05, 2021, 11:57:23 am »
« Last Edit: March 19, 2021, 02:04:19 am by ChanceKJ »
dragon36
  • Last login:June 22, 2021, 07:04:14 pm
« Reply #1020 on: February 07, 2021, 02:28:09 pm »
I'd also love to see the plans for this. Very nice build, exactly what I would like to do.
ChanceKJ
« Reply #1021 on: February 08, 2021, 10:58:57 am »
« Last Edit: March 19, 2021, 02:04:22 am by ChanceKJ »
Blanchy
  • Last login:May 15, 2021, 06:37:03 pm
« Reply #1022 on: February 13, 2021, 03:01:46 am »
Been a lurker following and loving this thread and it's development.  The spousal approval has just been given after she finally got to see this thread, so I joined up to reply.  I'd love to give this a crack myself.  MayI also join the long list of PM's for the plans?
Thanks again!
ChanceKJ
« Reply #1023 on: February 13, 2021, 10:23:43 pm »
« Last Edit: March 19, 2021, 02:04:26 am by ChanceKJ »
Whaleman
  • Last login:March 09, 2021, 01:31:28 am
« Reply #1024 on: February 21, 2021, 06:48:12 pm »
Hi Chance!
Awesome job - this 4 player cabinet is incredibly impressive!!!
This spring once the snow melts I will be starting on my journey to build my first cabinet which has always been a dream of mine - and with your permission I would like to base it on yours, as the shape and size is exactly what I’m looking for!
As I seem to be unable to send PMs yet, as a new user, would you be so kind as to PM me your plans which would greatly help in my voyage?
The main thing that would help would be the dimensions of the wood including shelves and control panel, if possible!
Thanks!!
ragecagegroves
  • Last login:March 28, 2021, 03:20:25 pm
« Reply #1025 on: February 21, 2021, 07:37:47 pm »
Hi Chance! d00d amazing job.  :applaud: you are swaying me to go 4players.  I recently bought a 2 player control boards from GRS and its not enough. I need to build the whole cabinet. Can you send me your plans as well? Thank you
lebiduledunet74
  • Last login:February 27, 2021, 06:10:56 pm
« Reply #1026 on: February 26, 2021, 02:59:37 am »
Damn great job and exactly what i dream of.
Impossible to pm you to inquiry plan and other stuff ,youtube Channel link , shop ...
If you read me send me a PM or maybe someone else who have  those plans .
Thanks !!!!
cyberphox
  • Last login:March 17, 2025, 10:11:00 am
« Reply #1027 on: February 27, 2021, 02:19:18 pm »
Did I hear plans were available? :)
Can I get in on this train too!  Thanks!
ChanceKJ
« Reply #1028 on: February 27, 2021, 03:29:51 pm »
« Last Edit: March 19, 2021, 02:04:31 am by ChanceKJ »
Pilgor
  • Last login:March 20, 2021, 12:37:48 pm
« Reply #1029 on: March 02, 2021, 10:50:22 am »
Love the build.  Attention to detail was great and as someone is interested in building a 4 play cab, I learned a lot going this thread.  Would appreciate the plans if possible.
  • Last login:Yesterday at 12:46:16 pm
« Reply #1030 on: March 02, 2021, 01:31:15 pm »
Why don't you just post the plans in the thread?
Then people don't have to prostrate in front of you to get them...or is that the idea?
ChanceKJ
« Reply #1031 on: March 02, 2021, 05:05:22 pm »
« Last Edit: March 19, 2021, 01:45:04 am by ChanceKJ »
Lareau100
  • Last login:December 18, 2023, 05:28:15 pm
« Reply #1032 on: March 05, 2021, 09:37:59 am »
Hey ChanceKJ this is great, This build is great.  I see the "plans" everyone is going on about.  I am trying to get a build going anyway I can get a link to grab these.  Thx in advance for any help.
« Reply #1033 on: March 05, 2021, 11:40:24 am »
Wouldn't it be convenient if they were just posted on the forum?
« Reply #1034 on: March 07, 2021, 07:32:09 pm »
Then no one would bump the thread and this well crafted poorly designed cabinet would finally disappear into the ether.
« Reply #1035 on: March 07, 2021, 07:36:22 pm »
---smurfing--- Malenko. Awesome to hear from you.
  • Last login:February 20, 2026, 04:34:18 pm
« Reply #1036 on: March 07, 2021, 10:43:38 pm »
This. Right. Here.
cyberphox
« Reply #1037 on: March 09, 2021, 01:21:33 pm »
Because he's not giving them away, he's trying to sell them.
« Reply #1038 on: March 09, 2021, 01:28:08 pm »
Is that true?
Maybe that is why every person requesting is good for one or two posts here and then vapor.
« Last Edit: March 09, 2021, 01:37:18 pm by Mike A »
« Reply #1039 on: March 09, 2021, 05:42:29 pm »
So wait, let me get this straight: the dude comes to this forum, asks for help/tips/tricks/advice from the community here. Promises to "give back" to the forum... by charging people for the plans that he got help to make?
That is some scumb-bag stuff right there.
Well, I hope you'll all enjoy the horrible mess that i'm about to make. Hopefully i'll be able to get some tips and tricks along the way and contribute back to this place at least something since i've received so much great advice just reading about your builds thus far. Well, that and in hopes you'll bring solutions to me instead of me having to spend hours more using the search function on the site! ;D
