Author Topic: My first arcade cabinet. Scratch build. Way over my head.  (Read 4918 times)
Arc Kalocal
  • Last login:July 28, 2017, 08:42:23 pm
« on: July 30, 2013, 02:11:07 pm »
So I've decided to build my own arcade cabinet. I downloaded Sketchup and I've got a draft of what I'm thinking of using. It'll be a 4 player 6/4 button setup with a 27" LCD monitor.
I've set the width of the cabinet to fit the monitor almost flush for a built in look. Right now I'm stumped on what to do with the marquee and speaker mounting. Any ideas? Comments? Questions? Concerns?
I'm sure I'm forgetting some important details but here's a picture and the sketchup file for you to look at and critique.
  • Last login:November 19, 2025, 06:13:57 pm
Re: My first arcade cabinet. Scratch build. Way over my head.
« Reply #1 on: July 31, 2013, 04:26:37 am »
Looks good, that is something different on the marquee, but it could work. Maybe put the speakers in that same panel, between the monitor and the marquee (guessing you are going to put a marquee picture of some sort near the top of the panel?)
micahman33
  • Last login:September 04, 2024, 03:56:19 pm
« Reply #2 on: July 31, 2013, 09:12:18 am »
I agree with DaOldMan. Split the marquee section you have now in half, and make half of it speakers, and half of it your marquee picture/display.
dandro
  • Last login:July 20, 2014, 12:32:46 am
    • Link To project
« Reply #3 on: July 31, 2013, 10:56:27 am »
Yup, I think that would look nice... Would be very clean and smooth looking if you used one solid piece of plexi for the whole marquee/speaker area (paint the speaker section only from behind with speaker holes drilled out)
Arc Kalocal
« Reply #4 on: July 31, 2013, 12:18:41 pm »
I really had no idea just how close my design was to Gauntlet! Never crossed my mind, now I have a weird sense of excitement. I made a quick draft and took the Gauntlet legends CP and I think it might work better for a 4P 6/4 cab like I want. What do you think?
To clarify, you mean cutting holes through the plexi as well? I've never worked with plexi before so I'm not sure about its tolerances. I like the idea of splitting the marquee, or maybe a double sized marquee with the speakers behind it somehow. I'm horrible with photoshop though so I'm reserved here still. Maybe keep it simple. I don't know. I suppose I need to find the speakers before I worry about where they're going to fit. Has anyone had any luck with mounting the speakers outside the cabinet on the sides? I don't want them become a nuisance to P3 and P4 though, that may put them right in their face...
« Last Edit: July 31, 2013, 12:20:15 pm by Arc Kalocal »
dandro
    • Link To project
« Reply #5 on: July 31, 2013, 12:44:26 pm »
yeah, on second thought, might want to ignore my suggestion about drilling the plexi, that didn't go over well with mine (cracked)..
micahman33
« Reply #6 on: July 31, 2013, 12:46:53 pm »
I just used a set of PC speakers, pulled them out of their housing, then mounted them inside a 1.5" hole in my cabinet under my marquee...my cabinet looks more like a traditional cabinet where the marquee sticks out though. Judging by your drawings, you could do the same thing. Even if you didnt mount the speakers behind plexi, you could do a marquee frame like dandro drew to hold your plexi, and do speaker covers/grills for your speakers underneath.
mcseforsale
  • Last login:August 14, 2025, 10:40:54 am
  • Creepy Mario Dude
« Reply #7 on: July 31, 2013, 12:49:22 pm »
+1.  On the gunslinger, I just wrapped speaker cloth around the speaker panel a'la seat cushion and stapled it on the backside and mounted the speakers.  It looks pro if the holes for the speakers are well executed:
AJ
dandro
    • Link To project
« Reply #8 on: July 31, 2013, 01:13:41 pm »
LOL tis true!! My speakers are covered with a black t-shirt, but you can't tell the diff. you never know until you try ;)
mcseforsale
  • Creepy Mario Dude
« Reply #9 on: July 31, 2013, 01:21:54 pm »
That's actually a good idea.  Although all my t-shirts are sacred!
AJ
Arc Kalocal
« Reply #10 on: July 31, 2013, 01:37:46 pm »
That's an ingenious idea. I love it. Probably cheaper and easier to find than a real speaker grill cloth.
Arc Kalocal
« Reply #11 on: August 03, 2013, 05:31:18 am »
Final(?) draft. Added cup holders! I'm thinking cut out the space entirely and use a cloth cup, similar to like a pool table, if I can get it to look classy enough. Increased the angles on the CP to fit 4 players at comfortable angles. Going to try and start building next weekend!
Also, is there any way I can set up two buttons as volume control? I don't want a knob or dial, but rather I'd like two independent buttons for Volume Up and Volume Down.
« Last Edit: August 03, 2013, 05:33:58 am by Arc Kalocal »
EMDB
  • Project RetroCade
« Reply #12 on: August 03, 2013, 06:50:33 am »
An iPac has inputs for volume up and down. You can use dedicated buttons or shifted ones (I use shift-joystick up and down to control the Windows volume control myself.)
