Author Topic: Popeye CRT Nintendo Bartop !!!! FINISHED !!!!!!!  (Read 84112 times)
Superfrog
    • My YouTube Channel
« on: April 05, 2013, 06:39:09 am »
Hi there,
I'm new to this forum so this will be my first w.i.p. trip here.
After 2 VerticCade ( Koenigs.dk) I will go for a classic cab theme in bartop size.
This one will have a crt and a xbox .. so 2 things I'm new with... before I used the Lcd an pc stuff...
So, I hope to see you soon and I insert some pictures from my prev. build
Greetings
« Last Edit: August 23, 2014, 05:56:29 am by Superfrog »
Superfrog
Re: The rise of my new CRT Bartop
« Reply #1 on: April 08, 2013, 06:14:02 pm »
First I have to deal with the Xbox to softmode it and get al the games working....
So if that's ready, I'm going to build the cab that I have in mind for it....
So, nothing special going on right now, but we keep on posting ;)
Unstupid
« Reply #2 on: April 08, 2013, 06:47:56 pm »
Cool... Don't electrocute yourself!
Superfrog
« Reply #3 on: April 09, 2013, 12:39:33 am »
Thanks Unstupid,
I discharge the tv, so it must be save now, I hope  ::)
Are you working on a project at the moment?
Dekieon
  • Last login:January 07, 2025, 03:17:55 pm
« Reply #4 on: April 09, 2013, 12:55:47 am »
Thanks Unstupid,
It is usually a good idea after discharging a tv, to wait 20 mintues or so and and then discharge again, just to be sure.
Superfrog
« Reply #5 on: April 09, 2013, 03:39:33 pm »
Thanks for the tip Dekieon,
Safety first  ;)
TonyWatto
  • Last login:May 29, 2013, 06:08:55 pm
  • I'm a retro loving geek !
« Reply #6 on: April 11, 2013, 09:21:11 pm »
Good to see you Superfrog. I look forward to following your progress :)
Superfrog
« Reply #7 on: April 12, 2013, 06:30:22 am »
Nice to see you to Tony.
I softmode the Xbox yesterday, so now I have to put coinops on IT.
First I wanne try to put some games on the basic 5gb harddrive. Maybe a lite version of coinops?
After struggle with usb sticks to softmode the xbox, I had to order a memorycard for it.
When it was arrived, I made a action replay card, to solder a usb cord on it.
Now the softmode was done very quickly
Yesterday was a struggle with a harddrive to replace ... the whole process worked fine, till a error came up at fatx format of the 30 gb drive.
I checked the compatible list of harddrives and I order 2 drives ( 40 and 80 gb  for a total 12,50 euro   still a Dutch basterd
So I did also the Coinops5 reduce to a level that it will fit on a 40 gb drive... and delete the psx and other console stuff.
When I can pickup Tuesday the harddrives, I can finish this and finally starting with the building part...
greetings.
« Last Edit: April 15, 2013, 11:32:52 am by Superfrog »
Superfrog
« Reply #8 on: April 15, 2013, 11:35:33 am »
So finally I past the test on Install Mame and some roms, to test things out.
You can see that a Horizontal game looks better than a Vertical game on this small tv.
But I like it to be a small cab, after two big screens ( 15 and 19 inch
I'm just not sure if I only put Mame on the cab or the whole deal with Coinops5 ?
It's gonna be a classic theme bartop... so, i think that only arcade games suit the best?
What do you guys think?
Seith
« Reply #9 on: April 15, 2013, 11:38:00 am »
Keep the game count low and groom it well for the bartop.  It will be much more enjoyable that way.
Superfrog
« Reply #10 on: April 17, 2013, 04:45:04 pm »
Bigger harddrive installed and Visionary 2 up and running.
I think now it's time for ACTION  8)
Only thing I'm struggle with is.... How many buttons ? I want keeping it simpel, but, if you wanna play all the games, maybe I don't get enough buttons....   :banghead:
I was planning to use 3 action buttons... the original theme has one button, so I have to redesign the cp a bit..
Now on my MameCade I have 6 buttons, and I don't even use them all....
Superfrog
« Reply #11 on: April 21, 2013, 05:32:28 pm »
As you can see in my prev. pictures I took, I love the popeye theme.
So this will be my next Bartop build and Nintendo cab transform into a Bartop model.
Small crt vs small bartop I hope  >:D
Superfrog
Re: Popeye CRT Nintendo Bartop
« Reply #12 on: April 21, 2013, 05:52:45 pm »
Lots of ideas for this one.
In my mind it's 99% done, but the only thing I'm not sure of is the controlepanel   :banghead:
Specially the buttons layout  :hissy:
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #13 on: April 25, 2013, 02:20:55 pm »
I just depends on what you want to play.  I just got done with my DK machine and I used 3 buttons.  I can play about 99% of what I want to play on it.  I think one of the shmups uses 6 buttons.  I don't play fighters though and I have a NeoGeo cabinet, so I don't need to play those on it ;)
retrostark
  • Last login:February 06, 2017, 03:48:51 pm
  • Indie Dev/Custom Arcade Cabinet Hobbyist
    • RetroStarkCustomCabs.com
« Reply #14 on: April 25, 2013, 03:01:00 pm »
were did you get those buttons? i really like them, could fit the style of one of my cabinets.
Superfrog
« Reply #15 on: April 25, 2013, 04:46:08 pm »
That's the same thing I was thinking about.
My first cab had 4 buttons and I used only 3  ::)
My last one had 6 and I never used them all, because I don't play fighters, But I got a lot of questions on the first build, if I got one with 6 buttons....  :banghead:
So I think that I go for the 3 button setup, NeoGeo games are mostly played with max 3 buttons, so this cab can handle that to...  :cheers:
Thanks and Greetings
Superfrog
« Reply #16 on: April 25, 2013, 04:49:02 pm »
Hi,
Which buttons do you like? the first cab with the 4 button layout or the 6 button layout?
Superfrog
« Reply #17 on: April 25, 2013, 04:52:35 pm »
A little update here:
Scale the whole thing down to Height 75cm .. but it has to be a little bit bigger ...    :banghead:
The crt is to big for it, so it's gonna be a big bartop    :hissy:
Tomorrow I make a bigger one, it's almost a full cab
What do you guys think of the concept, I like the shape this way, but do I need to cut the bottom part a bit? Last 2 pictures are cut at the bottom..
retrostark
« Reply #18 on: April 25, 2013, 04:56:12 pm »
both, and try to not do multiple posts in a row, you can answer everyone's question in one, cuts back on wasteful and longer threads than needed.
Superfrog
« Reply #19 on: April 25, 2013, 05:35:07 pm »
Sorry, I'm not so use to it  :dizzy: I'll keep it in mind  ;)
First cab: These are from a dutch website.
http://www.arcadewinkel.nl/drukknoppen-verlicht/LP-convex-classic-LED-drukknop-wit
Second cab is from a german site:
These are the small menu buttons:
http://www.arcadeshop.de/Seimitsu-Buttons-Seimitsu-PS-14-DNK-smoke_1052.html
These are the Action buttons:
http://www.arcadeshop.de/Seimitsu-Buttons-Seimitsu-PS-14-KN-smoke_1051.html
I printed the text and icons on glossy paper.
Greetings
jmike
« Reply #20 on: April 25, 2013, 05:35:48 pm »
 ??? Wasteful long threads  ???
No such thing.
Love the scale down Superfrog. Keep at it.
Can't wait to see more pics.
« Last Edit: April 25, 2013, 05:39:14 pm by jmike »
retrostark
« Reply #21 on: April 25, 2013, 05:44:00 pm »
ok thanks for the fast responses.
« Reply #22 on: April 25, 2013, 05:46:13 pm »
Too bad Konkey Dong's no longer around. Creepy build, yes, but an excellent Nintendo bartop. It WAS LCD though...
retrostark
« Reply #23 on: April 25, 2013, 05:51:40 pm »
yotsuya can you show me what you are talking about.
« Reply #24 on: April 25, 2013, 06:19:31 pm »
I would, but the head Konkey Donger himself, Pinball Jim, deleted all his posts and simply disappeared. He basically built a Donkey Kong bartop using the top half of a DK cabinet. It came out really nice, except that the theme was somewhat....rapey.
« Reply #25 on: April 25, 2013, 06:23:54 pm »
Can't even pull up Konkey Dong with the Wayback Machine... :'(
« Reply #26 on: April 25, 2013, 06:34:07 pm »
There's one photo of it with in the archives, but it's a spinner shot and doesn't show the cab.  :(
  • Last login:Today at 04:52:49 am
« Reply #27 on: April 25, 2013, 06:56:38 pm »
I thought the proper title for PBJ was the King of Dong.   :lol
Not to be confused with the King of Kong.   ;D
Jigenjuke
« Reply #28 on: April 25, 2013, 07:01:55 pm »
Here are a few Nintendo Bartops
These guys did a great job!
http://forum.arcadecontrols.com/index.php/topic,122793.msg1310811.html#msg1310811
http://forum.arcadecontrols.com/index.php/topic,94311.msg992012.html#msg992012
And there are the three that I made a few years back...
http://forum.arcadecontrols.com/index.php/topic,85596.0.html
Hope these help.  They were a blast to build and even more fun to play!
Jigenjuke
Superfrog
« Reply #29 on: April 29, 2013, 02:09:24 pm »
It's a combination of the 2 side concepts.
In my spare time this week, I have one side done.
Compares to my MameCade, it's a BEAST    >:D
I love the shape already    8)
ron310
  • Last login:July 18, 2016, 06:30:13 pm
« Reply #30 on: April 29, 2013, 07:44:02 pm »
I thought about doing a nes bartop with a playchoice 10 control panel. I can't wait to see how this turns out.
stefano
  • Last login:October 24, 2023, 10:30:05 am
« Reply #31 on: April 29, 2013, 09:16:57 pm »
Looking on the last picture, we can easily compare the width of a LCD Weecade design to a Nintendo themed bartop...
I'm amazed that both have almost the same footprint.
I was wondering that what really counts is the table space, or even a stand space. And the footprint is the most important measure here...
Damn... I still couldn't decide the design of my first cab: if I go to a ultra slim full height, or a bartop vertical weecade or a nintendo or galaga themed bartop...
BTW, congratulations for your design...
Superfrog
« Reply #32 on: April 30, 2013, 12:54:23 pm »
Thanks,
I made a copy of the Verticade,  I like that more than a weecade... And there are plenty of weecades already  ;)
My first build was a 15inch Verticade, than a 19inch Verticade and now the nintendo Because I like the shapes of it.
So go for the shapes you like the most and size depends on whats type of monitor you gonna use.
Good luck
Superfrog
« Reply #33 on: May 01, 2013, 04:12:37 pm »
Small update,
I didn't had the right size for my router, so I had to jigsaw the second side and after sandpaper a lot ( I'm very accurate  :angel: )It was finally done.
I had a lot in mind for today, but it was more time consuming then I had planned.
Superfrog
« Reply #34 on: May 03, 2013, 11:48:18 am »
Little steps to the finish    8)
Superfrog
« Reply #35 on: May 04, 2013, 01:49:38 pm »
After finding 1,5 hour of free time, the basic shape is coming along very well  :muhahahah:
Next: Control panel.
danny_galaga
  • Last login:Yesterday at 05:45:42 am
    • dans cocktail lounge
« Reply #36 on: May 04, 2013, 09:43:23 pm »
Nice work so far (",)
Superfrog
« Reply #37 on: May 06, 2013, 05:33:14 pm »
Almost done working with the jigsaw.
Crt is in position and just waiting for his new home, to shine like a new baby
Speaker hole is just a raw demo, not finished jet
Trebeck
  • "The Arcade" - Build #4
« Reply #38 on: May 06, 2013, 07:12:32 pm »
That's going to look really neat.  Was always a fan of the Popeye cab.
Looking forward to it!
Superfrog
« Reply #39 on: May 07, 2013, 03:37:18 am »
Thanks,
Me to, I like the cab and the game. First time played the game on a Philips videopac.
2 blocks of white sprites Where popeye an 2 big green sprites Where brutus ( BLUTO I think its in us )
I feel always bad that popeye cabs transform into donkey kongs... That's why I do a popeye ;)
Here a picture of the stunning graphics back in the days where I had to deal with, but what a great fun and gameplay .
« Last Edit: May 07, 2013, 04:20:03 pm by Superfrog »
