Author Topic: Restore of a nice Donkey Kong - COMPLETE  (Read 62722 times)
Maximus
  • Plans are for fools!!!!
    • Arcade Icons
Re: A faithful restore of a nice Donkey Kong
« Reply #200 on: April 16, 2013, 02:18:03 pm »
Something isn't adding up about the labeling of that diode, I can't find it anywhere in that 3-leg form factor, as it's 10a 45v can we sub it out for a higher ampage?
Maximus
    • Arcade Icons
« Reply #201 on: April 16, 2013, 02:22:29 pm »
Here's the proper PP7B schematic
Maximus
    • Arcade Icons
« Reply #202 on: April 16, 2013, 02:26:06 pm »
So yep according to this too the part should be CTB-33S a 12A 35V SDPR, not sure what the hell that is that's in there now then.
« Last Edit: April 16, 2013, 02:45:59 pm by Maximus »
Maximus
    • Arcade Icons
« Reply #203 on: April 16, 2013, 03:01:57 pm »
Will this do the job, I can get this on the way home... http://www.nteinc.com/specs/6000to6099/pdf/nte6085.pdf
« Last Edit: April 16, 2013, 03:11:49 pm by Maximus »
g0pkh
  • Last login:June 25, 2013, 04:47:24 pm
« Reply #204 on: April 16, 2013, 04:08:25 pm »
Hi
Assuming the package is a TO220
Then yes that would certainly be worth a try.
The CTB33S is rated less than that. So an overrated part is better in most cases.
I couldn't find any info about the c10p048 either.
Obviously be certain you use the original insulators when mounting it.
Pete
Maximus
    • Arcade Icons
« Reply #205 on: April 16, 2013, 04:11:05 pm »
Sounds good I will grab them on the way home.
I'm assuming you are in the UK, so you may be in the land of Nod by the time I start on this tonight. So when I pop all these confirmed components back in place (although I've still yet to properly test SCR1) what should I do from there?
Thanks for all the help, I'm sure I must be absorbing some of this as I go along
g0pkh
« Reply #206 on: April 16, 2013, 04:22:31 pm »
Hi
Be careful I have just checked the package style for ctb33s it seems to be a TO247 rather than TO220
Does your supplier have any other diodes in this package of a similar rating?
Yeah I am in the UK it's 9:21 here so not in the land of nod just yet   :D
Maximus
    • Arcade Icons
« Reply #207 on: April 16, 2013, 04:25:00 pm »
Cool, I'm originally from Chester, live in San Diego now though.
http://www.nteinc.com/specs/6000to6099/pdf/nte6091.pdf this seems to be the closest
g0pkh
« Reply #208 on: April 16, 2013, 04:38:09 pm »
The things  to check once all the parts are back in.
The insulation of all devices from the heatsink (particularly the centre tag)
Check for a short circuit across the HT rail (R1 to Gnd)
The collectors of both switching transistors to ground.
Collector to emitter of both switching transistors again looking for short circuits.
I would be surprised if the Scr is faulty but just check it pin to pin all round looking for shorts.
I would actually advise the first test of the PSU be done disconnected from the game board.
If you could connect a lamp across the 5v rail as a load instead. say a car tail lamp bulb
The last thing you want is for a fault to risk adage to the logic board.
From the circuit there appears to be an over voltage trip which will shut down the 5v rail if it goes much above 5.6v
Good luck
Pete
EDIT
Yeah that diode should handle it with ease.
g0pkh
« Reply #209 on: April 16, 2013, 04:39:45 pm »
Chester eh?
Just north of London for me on the Hertfordshire Essex border
Stansted
Maximus
    • Arcade Icons
« Reply #210 on: April 16, 2013, 04:40:53 pm »
Something I don't understand now that I understand the layout a little.
Why didn't i get any power on any of the pins even 24v 12v and -5v if it was just the +5v rail that was nuked, was that because nothing got past R1?
g0pkh
« Reply #211 on: April 16, 2013, 04:42:19 pm »
You guys are so lucky over there.
I would kill for the source of Arcade machines you guys have.
I have restored a Rockola jukebox though which was a nice challenge
Pete
g0pkh
« Reply #212 on: April 16, 2013, 04:46:37 pm »
That s a good question
I think t likely that R1 failed before the SCR had chance to fire.
Once R1 was open of course then no power would reach either switching transistor.
It's almost as if R1 is there to protect the fuse lol
« Last Edit: April 16, 2013, 04:48:29 pm by g0pkh »
Maximus
    • Arcade Icons
« Reply #213 on: April 16, 2013, 04:48:50 pm »
ok cool, that's what I was thinking, see I may be learning something  :applaud: ok well i'll put it all together and test it all tonight and see what happens. If you don;t hear from we again I'll probably be found lying on my garage floor with a chunk of solder shot through my left eyeball.
g0pkh
« Reply #214 on: April 16, 2013, 04:59:43 pm »
Please be careful
Remember a golden rule about working with electricity. One hand in your pocket.
That was drummed into me many years ago.
Beware bits of flying plastic lol
Been there,done that got the T shirt.
Things seems to go wrong a lot quicker over here with twice the mains voltage though.  :o
Maximus
    • Arcade Icons
« Reply #215 on: April 16, 2013, 05:00:38 pm »
And all the rain  :laugh2:
g0pkh
« Reply #216 on: April 16, 2013, 05:03:56 pm »
That's true.
Been a lovely warm day today though
Maximus
    • Arcade Icons
« Reply #217 on: April 16, 2013, 11:20:58 pm »
No joy at Fry's they only had the Nte 6090 which was the T022 package and they were all out of the C2325 clone so I'm going to have to order online
Sanded down the heavy fill primer tonight and then did two coats of regular white primer. Not very exciting stuff
g0pkh
« Reply #218 on: April 17, 2013, 03:40:24 am »
That's a shame  :(
Hopefully the bits wont take too long.
Maximus
    • Arcade Icons
« Reply #219 on: April 17, 2013, 10:18:00 am »
Final sanding done for the sides. New blue vinyl is arriving today so hopefully by tonight all cab cosmetics will be complete. The black marks on the back of the panel edge are paint from blacking out the back of the cab, not horrible chips lol
« Last Edit: April 17, 2013, 11:53:50 am by Maximus »
« Reply #220 on: April 17, 2013, 11:08:52 am »
wanna send me the blue that was too short?
Maximus
    • Arcade Icons
« Reply #221 on: April 17, 2013, 11:53:01 am »
What would you use it for?
« Reply #222 on: April 17, 2013, 11:54:12 am »
Blue Screen Skin Suit.
« Reply #223 on: April 17, 2013, 12:11:37 pm »
 :laugh2:
Green Man's nemesis!
« Last Edit: April 17, 2013, 12:14:35 pm by Nephasth »
Maximus
    • Arcade Icons
« Reply #224 on: April 17, 2013, 12:53:54 pm »
Hey Pete,
I was going to order that D9 replacement from Digikey or mouser, having trouble finding a none NTE alternative to the 2sc2535, would be nice if I could get them all at the same place, can you advise on that.
Maybe this for 2sc2535???
http://www.mouser.com/ProductDetail/STMicroelectronics/BUL89/?qs=sGAEpiMZZMutXGli8Ay4kAuOt55Alb1Hn0BvgJit9GA%3d
and this for the CTB-33S replacement?
http://www.mouser.com/ProductDetail/Vishay-Semiconductors/VS-MBR4045WTPBF/?qs=sGAEpiMZZMtQ8nqTKtFS%2fJSNqGZMTeJU2xdAUbkQHOc%3d
and this for the 2w020 R1
http://www.mouser.com/Search/ProductDetail.aspx?R=12FR020Evirtualkey58810000virtualkey588-12FR020E
« Last Edit: April 17, 2013, 01:24:56 pm by Maximus »
g0pkh
« Reply #225 on: April 17, 2013, 03:51:57 pm »
Hi
Transistor looks good
Diode looks good ( a bit overkill on the current lol)
Resistor you listed was 0.02 ohms oooops
Look at this one instead
They  don't seem to stock 20 ohms but 18 would do
Mouser Part No:
660-PCF2C180K
« Reply #226 on: April 17, 2013, 03:54:26 pm »
I'd use it on my "Weecade" kit I got from Haruman. Its currently blank melamine, but I thought abbout wrapping it in the blue and going with white molding and buttons/stick.
Maximus
    • Arcade Icons
« Reply #227 on: April 17, 2013, 04:01:14 pm »
Sure PM me your shipping info and I'll send whatever I have left over when the build is finished.
Maximus
    • Arcade Icons
« Reply #228 on: April 17, 2013, 04:03:09 pm »
Hi
Mouser Part No:
660-PCF2C180K
Thanks Pete, parts ordered, will take a few days.
g0pkh
« Reply #229 on: April 17, 2013, 04:03:40 pm »
On that resistor. You might be wise to beef it up a little and go for the 3w one
Mouser Part No:
660-HPC3C180K
18ohm 3w flameproof
Maximus
    • Arcade Icons
« Reply #230 on: April 17, 2013, 04:04:38 pm »
Mouser Part No:
660-HPC3C180K
18ohm 3w flameproof
too late, already ordered, oh well we'll see
g0pkh
« Reply #231 on: April 17, 2013, 04:05:27 pm »
Never mind I was too late lol
Should be ok though
Maximus
    • Arcade Icons
« Reply #232 on: April 17, 2013, 06:51:22 pm »
Vinyl going on. Thanks Rich for the speedy replacement
Maximus
    • Arcade Icons
« Reply #233 on: April 17, 2013, 08:21:55 pm »
Now if only it played Donkey Kong
Maximus
    • Arcade Icons
« Reply #234 on: April 17, 2013, 10:42:06 pm »
Here's the fancy shots....
mcseforsale
  • Creepy Mario Dude
« Reply #235 on: April 18, 2013, 12:14:35 pm »
Wow.  That looks awesome.  How's the electronical stuff coming?
AJ
Maximus
    • Arcade Icons
« Reply #236 on: April 18, 2013, 12:16:54 pm »
Thanks man, I'm still waiting on a replacement supply I bought, or the components to come from Mouser with the hope of fixing the one I assploded.  :dizzy:
« Reply #237 on: April 18, 2013, 01:41:45 pm »
looks so good it almost looks fake.  :applaud:
Maximus
    • Arcade Icons
« Reply #238 on: April 18, 2013, 01:45:09 pm »
Ha that's what I love about these Nintendo cabs, they look like real life cartoon characters themselves
Maximus
    • Arcade Icons
« Reply #239 on: April 18, 2013, 02:07:33 pm »
Looks like the power supply is on the truck for delivery today, so with a little luck we can power everything up and hope that blowing up the last supply didn't do any damage to the boards, also we'll see if all the reseating and cleaning of the socket chips has solved our crashing problem - fingers crossed.
