Author Topic: lucisac's Model 2 setup guide  (Read 45871 times)
  • Last login:May 13, 2024, 10:10:04 am
« on: April 03, 2013, 10:14:30 pm »
This guide was originally posted on the old speksnk forums by lucisac.
It covers nearly everything, including networking.
I thought it was lost until coming accross it on a Japanese site that I couldn't copy and paste from.  :timebomb:
Thanks to Drnick for posting a plain text copy.
Here it is formatted:
https://docs.google.com/document/d/1KiKUFqyLXt-HcVD_3drWIy9xI-aIcdQsY07bPiy7T2g/edit?usp=sharing
EDIT: Seems it's been removed for violating google's terms of service.  Someone is a jerk.
IT IS ATTACHED AT THE BOTTOM OF THIS POST.
Not sure if both are needed, but if you're having trouble with it crashing when a game is launched, try installing both these runtimes:
http://www.microsoft.com/en-us/download/details.aspx?id=5555
https://www.microsoft.com/en-us/download/details.aspx?id=8109
(Although newer versions of DirectX support all the older versions, newer computers are usually missing these runtimes)
EDIT: Also attached
« Last Edit: April 23, 2018, 09:45:07 am by BadMouth »
Nuexzz
Re: lucisac's Model 2 setup guide
« Reply #1 on: April 04, 2013, 03:05:29 am »
 Daytona Online Tool (dev) User Guide for the M2 Emu :tool:
isamu
  • Last login:May 19, 2024, 03:54:10 am
« Reply #2 on: April 04, 2013, 02:52:17 pm »
Wow lucisac.... haven't heard from him in a while. That was my dude. Had some great discussions with  him on the old nebula forum. He was EXTREMELY passionate about posting various things on the forum. It was getting so bad Wesker had to silence him at one point! :lol Those were the days.  :burgerking:
Lucisac if you're out there reading this come in and say whaddup dude.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #3 on: May 30, 2013, 10:47:40 am »
Does anyone know if it's possible to get a Model 2 emulator setup to output to an actual Medium Res (24K) monitor? I have a Model 2 based Sega Twin unit with the original monitors, I'd like to continue using them without converting them to 15K or VGA monitors.
  • Last login:May 18, 2024, 03:07:49 pm
« Reply #4 on: May 30, 2013, 12:12:50 pm »
soft15 or an arcade VGA card, set custom full screen resolution in Model 2
Brian74
  • Last login:March 10, 2024, 01:55:58 pm
  • Yep... I built that!!
« Reply #5 on: May 30, 2013, 10:26:53 pm »
ok, I must be doing something wrong. I am trying to get this to work over lan..
Brian74
« Reply #6 on: May 30, 2013, 11:18:16 pm »
Ok got it going, one machine is really lagging.
Sent from my SGH-T989 using Tapatalk 2
twistedsymphony
    • solid-orange.com
« Reply #7 on: June 01, 2013, 03:59:36 pm »
Do either of those actually support 24K? Last time I looked into Arcade VGA it only did 15K...
EDIT: ok it appears that 24K has actually been added to ArcadeVGA, interesting, thanks!
« Last Edit: June 01, 2013, 04:03:19 pm by twistedsymphony »
goingcheapnow
  • Last login:June 25, 2013, 03:34:29 am
« Reply #8 on: June 07, 2013, 11:54:58 pm »
Hi Guys, I'm having issues trying to get sega model 2 daytona over LAN working. Keeps saying network board not present.. any ideas? I've modified the m2network.ini to include the below on each machine. Where xxx.xxx.xx.xx is the IP address that comes up in IPconfig. Is this right?
[network]
RxPort=1978
NextIP=xxx.xxx.xx.xx
NextPort=1978
So machine 1 has in the NextIP the IP address of the other PC. I've tried using a standard LAN cable and also a cross over cable. What am i doing wrong?
Mal
« Reply #9 on: June 08, 2013, 07:24:57 am »
can you ping each computer from the other? Did you turn off any firewalls that might be running?
« Reply #10 on: June 08, 2013, 12:31:36 pm »
HI've tried using a standard LAN cable and also a cross over cable. What am i doing wrong?
I haven't done it, but I'm pretty sure you need to connect both computers to a router, not just each other.
goingcheapnow
« Reply #11 on: June 08, 2013, 09:50:25 pm »
Hi Malenko, i've set IPs for both machines and can now Ping to each, originally it was 1 way but now both ping to each other. all firewalls are off.
Badmouth, havent tried a router. might have to do that as nothing else is working, it doesnt seem to be searching for connection, just does the cancelled network board not present.
hmmm .. .frustrating :)
Brian74
« Reply #12 on: June 08, 2013, 11:08:52 pm »
Example IP on PC 1 is 192.161.1.4 & PC 2 is 192.168.1.7 make PC 1 network ini 192.168.1.7 and PC 2 192.168.1.4 that is the loop. Make each on look for each other. I did it over wifi and there was bad lag.
« Reply #13 on: June 08, 2013, 11:41:02 pm »
^This is the next step. If they can ping each other, then they can talk to each other. Set the ini's right and you should be good to go.
goingcheapnow
« Reply #14 on: June 09, 2013, 12:42:17 am »
we have success :) woohoo .... daytona work, sega rally works (Steering in menus vibrates way too much) but others having issues with working so will keep working on those...
Brian74
« Reply #15 on: June 09, 2013, 12:54:40 am »
Good, glad I could help :))
goingcheapnow
« Reply #16 on: June 09, 2013, 01:14:05 am »
Thanks, now just to see if can iron out the few bugs :)
AMG KC
  • Last login:June 29, 2022, 05:33:52 am
« Reply #17 on: March 22, 2014, 04:20:49 am »
Yes had many a race with Lucisac back in the day, almost every night for quite a while. He wasnt too bad at driving either, he got into playing RPGs and lost interest in Daytona, which was unfortunate. That was probably 5 years ago now.
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« Reply #18 on: October 24, 2014, 03:53:00 am »
Goingcheapnow
Just setting up 2 machines now.
Did you need a router to make this work, or just a network cable between the 2 LAN ports??
Would you mind posting your setup, what folders required on each computer etc
Many thanks
« Reply #19 on: January 29, 2015, 04:54:42 pm »
Goingcheapnow
Many thanks
if you manually configure IPs and use a cross over cable you can do it without a router, however, given the choice I'd use a cheapie POS 10/100 router before I used a cross over cable.
lucisac
  • Last login:October 30, 2021, 07:42:00 am
« Reply #20 on: July 01, 2021, 09:28:25 am »
whaddup dude.
Aww man your post made me smile so thanks for saying that.  I miss all you guys, playing on that shobby 256k connection, can't believe they called that broadband back then.  Do we still need byblo's tool to network over the internet, I lost it, but I think it's now in the latest version of the emu right?  After seeing multiple releases online on the PS3, championship, the texture pack...and WOW, the community has given Daytona the love it deserves.  It brings joy to me to see that Daytona USA is still popular to this day due to the impact it left on us back in the old days, those 3D graphics coupled with the high frame rate is something we still struggle to see today in some games.  I see you're still active Isamu so hope you see this, and glad my documentation has helped so many people, not sure if they still play the emu since the ps3 version released but I still believe that the emu edition is ultimate and most true to the original hardware and experience of gameplay.
PS: I've recovered my YT account so you can verify me viewing a recent comment on my latest video after a decade.
Keep spreading the LOVE for Daytona USA! <3
« Last Edit: July 01, 2021, 09:38:06 am by lucisac »
isamu
« Reply #21 on: July 02, 2021, 07:57:59 pm »
HOLY ---steaming pile of meadow muffin--- HE'S ALIVE!!!!!!!!!!!  :woot :droid :cheers:
Good to hear from you buddy! Glad you're doing well. Yeah Daytona has come a long way thanks to the community.  There's still a small group of people that play the PS3 version online every now and then. Thunderwing has some friends that are still playing which I hope to jojn soon. I recently completed the endurance race in 1st place on 777 Speedway and Dinosaur Canyon via Model 2 emu. Now I'm balls deep into Scud Race trying to place 1st in the Advance stage. Fun times :)
Anyway stay in touch mate.  :cheers:
lucisac
« Reply #22 on: July 02, 2021, 10:33:54 pm »
Will do! I'll monitor this thread so if you need anything drop a post.
bsoder52
  • Last login:March 03, 2024, 08:57:04 am
« Reply #23 on: August 22, 2023, 04:20:52 am »
Thanks for posting this tutorial. Much appreciated. I was able to link up Daytona USA.  :)
