Tested the new version: the "out-of-track" rumble works great (like before), but the "collision with other cars" one is not working
on my wheel BUT
i must say that only one rumble output is connected to my wheel (i don't remember if it's the left or right ATM) so i cannot feel the one not connected. Another possibility is that you set a strenght <10000 which, in mamehooker, is not sufficient to rumble the motor i am using so probably it's not with OR2FXT too.
I also reactivated the windows "beeps and annoying loging logoff popup ---steaming pile of meadow muffin---", but i was not able to hear the jap tracks (nor the activation beep).
The horn is still not played.
I gave a check to the button press detection by the debug utility, and the button presses are not recorded untill the start of the race, then they are. So, in the mode/car/music selection menu they are not recorded but i can see a full brake press (255) while in game. The debug window shows the pressing of the horn (button "16" , right arrow) too, but only in-game.
The brake is mapped to the "2" keyboard button and the horn to the "RIGHT" arrow. Maybe the mixed configuration i am using (360 pad X-axis for wheel,
PS/2 keyboard for the digital buttons) makes things harder?
just that i am here, let me suggest a couple of things:
- possibility to control the rumble strenght (i know that this could be an easy task, i learned it from mamehooker advanced Xinput outputs
![Grin ;D](http://newforum.arcadecontrols.com/Smileys/default/grin.gif)
- possibility to send all the outputs to one single rumble motor...
Ah, almost forgot: the first time i launched the config utility (with the first exe i mean) the default resolution set was "0x640" ... not a big problem, you can change it easily, but for sure fixing this could avoid some "issue not issue" reported from the casual user that launches the main program straight forward
![Wink ;)](http://newforum.arcadecontrols.com/Smileys/default/wink.gif)
(don't ask me why i noticed that running it straight forward doesn't work
![LOL :lol](http://newforum.arcadecontrols.com/Smileys/default/lol.gif)
