Author Topic: Keywiz Grounding  (Read 1127 times)
Tony555
  • Last login:April 27, 2019, 09:24:37 pm
Keywiz Grounding
« on: January 05, 2013, 08:42:33 am »
Hi everyone,
I have bought a Keywiz 40ST from GGG. I have a quick question...
As the instructions stated, I have daisy-chained all my switches COM to the GND (ground) terminal of the keywiz. Do I now need to run another cable from the GND and ground the Keywiz myself?? (or does it get grounded through the PS2 cable??)
  • Online Online
  • Last login:Today at 01:21:17 pm
Re: Keywiz Grounding
« Reply #1 on: January 05, 2013, 09:10:52 am »
Yes -- no additional grounding required.
Tony555
« Reply #2 on: January 05, 2013, 09:14:39 am »
Thanks for the fast reply Scott :applaud:
  • Last login:November 19, 2025, 06:13:57 pm
« Reply #3 on: January 05, 2013, 09:34:56 am »
Speaking of grounding, if you are using a coin door, make sure you ground the metal frame of the coin door. The keywiz dont like static, I had one quit working one time, could only figure out that it was static from people touching the coin door (it wasnt grounded, but is now.)
Just attach a wire to one of the mounting screws on the door, and attach the other end of the wire to the power supply box, or if you are using a PC in the case, just attach it to one of the metal screws on the back of the PC.
  • Online Online
« Reply #4 on: January 05, 2013, 10:04:03 am »
As long as we're talking grounding in general, don't forget to ground metal trackball frames, too.
They're succeptible to triboelectric charging.
