Author Topic: Nora's Neo-Geo MVS Mini (5/12/14 UPDATE)  (Read 53133 times)
  • Last login:Today at 02:32:05 pm
Re: Nora's Neo-Geo MVS Mini (8/17/12 - Controller Port Question)
« Reply #40 on: August 17, 2012, 12:30:22 pm »
You can wire it directly to the encoder.
This page shows the pinout at the bottom and has the controller schematic, too.
Here is a Neo-Geo extender cable that might work well for you.
CWorley
  • Last login:August 09, 2019, 07:44:36 pm
« Reply #41 on: August 17, 2012, 02:43:25 pm »
That extender cable should work great.  Thanks!  Now the question is how do I mount it on the cab so that it looks nice and clean?
« Reply #42 on: August 17, 2012, 06:03:44 pm »
Do you know where on the cab you want the connector to be?
Method#1 -
Get a strain relief boot the size of the cable.
Drill the proper size hole through the panel.
Push boot through from inside.
Feed cable through boot from outside until connector is snug against it.
Securely tighten several zip ties around the cable and against the inside of the panel to keep the cable from pulling back out.
Method #2 - embed connector body in panel
Drill a hole large enough for the cable and widen it enough to wedge the connector in place.  (Put a clamp on the back to keep it from pulling forward)
Flat sides before the taper appear to be around .6" long, so you might want to leave it sticking out a bit.
.   \              /   panel
.       \       /      clamp
CWorley
« Reply #43 on: August 17, 2012, 06:43:22 pm »
Thanks Scott!  I'm definitely interested in doing something more like method#1.
Right now, I'm thinking the connector will either go on the right side of the front panel near the top or on the side of the cab by the control panel.
« Last Edit: August 17, 2012, 06:51:44 pm by CWorley »
« Reply #44 on: August 18, 2012, 04:11:31 am »
Looking closer at your cab plans, it occurred to me that you might be able to use method #1 to come out the back (maybe on the 45 degree inset?) and have a couple of hooks to hang the controller on when not in use.  Add two velcro cable wraps -- 1 on the extender cable and one on the controller cable -- to keep the controller from unplugging  accidently.
CWorley
« Reply #45 on: August 19, 2012, 09:47:37 am »
Received some more parts the other day from divemaster:
GoldLeaf Pushbuttons
Coin Door
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (8/19/12)
« Reply #46 on: September 02, 2012, 09:04:40 pm »
Construction has begun...
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (9/2/12 - Sawdust!)
« Reply #47 on: September 03, 2012, 10:35:23 pm »
Side panels cut...
Cheers!
Yvan256
    • Yvan256
« Reply #48 on: September 04, 2012, 08:23:46 am »
Side panels cut...
The Neo-Geo profile really is a classic!  :cheers:
CWorley
Re: Nora's Neo-Geo MVS Mini (9/3/12 - Sides finished!)
« Reply #49 on: September 13, 2012, 03:01:38 pm »
What do you guys think?  Black or white for the joystick ball top?
« Reply #50 on: September 13, 2012, 03:12:23 pm »
White!
Yvan256
    • Yvan256
« Reply #51 on: September 15, 2012, 08:12:35 pm »
Neo-Geo had black bat tops.  ;)
Unstupid
Re: Nora's Neo-Geo MVS Mini (9/13/12 - Black or white ball top?)
« Reply #52 on: September 16, 2012, 08:35:40 am »
I'd vote for bat tops in whatever color you are going to use for your t-molding...
CWorley
« Reply #53 on: September 19, 2012, 08:13:13 pm »
:::UPDATE:::
T-molding slots have been cut...
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (9/19/12 - T-Molding Slots Cut)
« Reply #54 on: October 02, 2012, 09:38:37 am »
The base for the cabinet has been completed.
Most of the support pieces have also been put into place.  Still need to decide the best way to mount the monitor.  The two support pieces by the marquee area also need to be modified.
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (10/2/12 - Base n Supports)
« Reply #55 on: October 10, 2012, 11:41:09 pm »
More progress being made...
Cheers!
« Last Edit: October 11, 2012, 08:11:18 am by CWorley »
CWorley
Re: Nora's Neo-Geo MVS Mini (10/10/12 - More Progress)
« Reply #56 on: October 12, 2012, 09:22:44 am »
I have a few questions for you guys:
First, I'm planning on purchasing a GGG NovaMatrix for the marquee.  Is the "standard" set of 6 (18 LEDs) enough to light my 18.5" x 6" marquee?
Second, what do you guys think about corner protectors for the front bottom corner of cabinets?  I've seen a lot of Neo Geo cabinets with them.
Finally, any thoughts on the progress so far?  Do you guys see any red flags in the construction?
Cheers!
  • Last login:January 29, 2026, 12:04:48 pm
« Reply #57 on: October 12, 2012, 11:04:10 am »
It will be plenty.  I'm using one to light a 30.5 x 4.5" marquee.
I think it will look better without them, especially since the cab is scaled down and the protectors won't be.
However, if you think the front corners might get damaged by a vacuum cleaner or toys banging against them, definitely include them.
(of course you can always add them to hide the damage after it has happened)
I thought hard about them for my current build, but I needed them on the back since my corners were getting mushroomed by laying the cab back to work on it.
All the ones I've seen were on the front through, so decided against it.
Looking good to me.  Especially that you angled the framing in the marquee area to avoid shadows.  ;)
« Last Edit: October 12, 2012, 11:06:54 am by BadMouth »
CWorley
Re: Nora's Neo-Geo MVS Mini (10/11/12 - Progress n Questions)
« Reply #58 on: October 18, 2012, 09:17:30 am »
Regarding fans/airflow, my initial plan was to put two 120mm fans w/ dust filters on the bottom of the cab blowing up for intake and two 120mm fans on the top/slanted back of the cab for outtake.
Is that too much?  Should I go with just one intake and one outtake?
Re: Nora's Neo-Geo MVS Mini (10/18/12 - Fans/Airflow Question)
« Reply #59 on: October 18, 2012, 09:33:45 am »
Way too much.
On my current build, I have two 120mm fans in the bottom and another one on the cpu cooler.
It feels like a friggin house fan.  I plan to add a fan controller to slow them down.
A single fan at the top would probably be enough.
I put the fans on the bottom because the back of my cab sits flush with the wall.
Not sure I've seen it done that way before and there's probably a reason.  :P
The bottom of yours won't be against the wall, so why not put the vent on the bottom of the back?
CWorley
« Reply #60 on: October 18, 2012, 10:02:40 am »
Way too much.
:::UPDATE::
Sorry, read that wrong the first time around.  Putting the fan at the bottom of the back is a possibility.  I like the idea of putting it in the bottom base because then it blows up through the cab.
« Last Edit: October 18, 2012, 03:07:45 pm by CWorley »
« Reply #61 on: October 18, 2012, 02:58:57 pm »
The main reason that comes to mind is that you'll probably pick up a lot more dust.
Also makes cleaning dust bunnies off an intake filter a real pain.   ;D
CWorley
« Reply #62 on: October 19, 2012, 02:36:43 pm »
Alright, I'll definitley just go with one outtake fan then on the top incline.
Is an intake fan needed?
This isn't a full upright, but it's not a small bartop either.
eds1275
  • Rock and Roll!
Re: Nora's Neo-Geo MVS Mini (10/19/12 - Fans/Airflow Question)
« Reply #63 on: October 19, 2012, 03:34:58 pm »
Random question. Is your daughter's name Nora because you are a huge batman fan and that's Mr. Freeze's wife's' name? If so, how long could you hide it before your wife found out?
« Reply #64 on: October 19, 2012, 04:57:40 pm »
I don't think it's needed as long as the thing isn't full of leaks that will prevent air from being sucked in from the lower vent.
Heat rises, so even if the cab is leaky, the heat will go to the top and be removed by the exhaust fan.
On the other hand, it's not going to hurt anything and would be extra insurance to have it.
I put a single 80mm fan in the top and a long, large vent in the bottom of a 3/4 scale pacman style cabinet that I built for my nephew last year.
CWorley
« Reply #65 on: October 22, 2012, 03:53:42 pm »
Sorry, this isn't the case.  While I do consider myself a Batman fan, I don't care much for Mr. Freeze.  Going with 'Nora' was my idea, but there's no interesting (geeky) story behind it.  For all you George R. R. Martin fans, we did consider 'Arya' though.
CWorley
« Reply #66 on: October 24, 2012, 08:23:41 pm »
The top/back panel is cut with holes for an exhaust fan and power button.
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (10/24/12 Update)
« Reply #67 on: November 08, 2012, 02:55:00 pm »
Trying to decide if should go with black or white t-molding.  What do you guys think?
Also, what do you guys think about adding a kick plate?
« Last Edit: November 08, 2012, 03:52:15 pm by CWorley »
TPA5
  • Last login:May 30, 2017, 10:25:16 pm
  • Wanting A Cab
Nora's Neo-Geo MVS Mini (11/8/12 Update: T-Molding Color?)
« Reply #68 on: November 08, 2012, 10:43:27 pm »
I lurk mostly and don't know jack about arcade builds...But I'm a sucker for white t molding. It looks super good in my opinion.
Unstupid
Re: Nora's Neo-Geo MVS Mini (11/8/12 Update: T-Molding Color?)
« Reply #69 on: November 08, 2012, 10:46:26 pm »
T-Molding matches your joysticks....  What color are your joysticks?
« Reply #70 on: November 09, 2012, 07:35:43 am »
I never thought about it that way.....you're absolutely right!
CWorley
« Reply #71 on: November 09, 2012, 08:35:18 am »
Well, the joystick ball top will be white, so there ya go.  White it is!
Any thoughts on a kick plate?
CWorley
« Reply #72 on: November 13, 2012, 08:16:15 am »
The monitor is now mounted...
What do you guys think about the location of the monitor (height/depth)?
Cheers!
Unstupid
Re: Nora's Neo-Geo MVS Mini (11/13/12 - Monitor Mounted)
« Reply #73 on: November 13, 2012, 11:07:57 am »
Hard to tell cause your speaker panel and control panel are not there, but I would have put them in the middle of them.  That way you bezel is even on the top and bottom.
CWorley
« Reply #74 on: November 16, 2012, 08:41:26 am »
Ended up raising the monitor about an inch.  The bezel will be a little bit bigger on top than on the bottom, but I don't think it'll be that noticable.  The whole bezel itself will be really thin due to the screen taking up almost the entire space.  I'll be using tinted grey glass which will make it even less noticable.
Cheers!
Woodshop Flunky
« Reply #75 on: November 17, 2012, 09:20:18 am »
Just stumbled onto your build.  Looking really great.  Love this style cab.  :cheers:
CWorley
« Reply #76 on: November 19, 2012, 09:26:59 am »
Thanks Woodshop!  Your American Ace cab definitely helped set the idea for this cab in motion.
CWorley
« Reply #77 on: December 03, 2012, 11:04:13 am »
This is the current state of the cab.  Here you can see the mount for the lcd monitor.
Working on the speaker shelf, bezel, and back panels at the moment.
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (12/03/12 - Update)
« Reply #78 on: December 23, 2012, 08:42:16 pm »
Slowly but surely...
I've attached some pics of the speaker shelf.  The width of the shelf will need to be trimmed down later.
Will be working on the bezel and control panel next.
Cheers!
CWorley
Re: Nora's Neo-Geo MVS Mini (12/23/12 - Speaker Shelf Completed)
« Reply #79 on: December 31, 2012, 11:33:49 am »
Progress has been slow lately because the work room is not heated and it's cold in Wisconsin.
Here are some pictures of how the connector for the Neo Geo controller will be held in place:
This panel is not cut to size yet, but it will be at the bottom of the back of the cabinet.  It will have the controller connector, an intake fan, and the outlet for the power cord.
Cheers!
