Author Topic: help hiding a bat file  (Read 2185 times)
abispac
  • Last login:December 04, 2025, 01:12:34 am
« on: May 12, 2012, 02:40:58 am »
how do front ends hide the mame comand window?
Im testing some stuff up in hyperspin and it works like a charm now, but i get an ugly comand windows everytime i launch a bat file, so i wonder if is an easy way to hide that windows just as the front ends do, thanks for any help.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 11:56:58 pm
Re: help hiding a bat file
« Reply #1 on: May 12, 2012, 08:01:27 am »
the first line in your BAT file
@echo off
also you can add >nul at the end of command
ex:
Mame pacman >nul
hope that's what your looking for.
Free VGA Breakout Cable
elkameleon
« Reply #2 on: May 12, 2012, 07:21:08 pm »
echo off just doesnt print anything in the window, the window still pops up. There may be an option to run minimized though...
TopJimmyCooks
« Reply #3 on: May 12, 2012, 09:37:05 pm »
http://forum.arcadecontrols.com/index.php?topic=117963.0
See LeChuck's reply #1.  This is the only thing that worked for me.
elkameleon
« Reply #4 on: May 12, 2012, 11:02:02 pm »
I think you may be able to create a shortcut of the batch file, and within the shortcut properties, you can select to run it minimized. I'll check it out.
EDIT: going this route does indeed work, the only trace is the icon in the taskbar.
« Last Edit: May 13, 2012, 11:37:54 pm by elkameleon »
abispac
« Reply #5 on: May 13, 2012, 12:34:28 am »
Set WshShell = CreateObject("WScript.Shell")
WshShell.Run chr(34) & "C:\arcade\tronswitch\4way.bat" & Chr(34), 0
Set WshShell = Nothing
fixed mi issue thanks for the help.
