Author Topic: ArcadeVGA and WG4600  (Read 1380 times)
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« on: May 11, 2012, 09:24:15 am »
I have a vertical WG4600 that I recently recapped and replaced the flyback on.  It's working if I hook it up to my elevator action cabinet I get a picture but needs some adjusting.  When I hook this up to my Arcadevga2 AGP version I cannot get it to sync.  I have the prebuilt cable from ultimarc and double checked that last night to make sure it is pinned correctly and it is.  My WG4600 only has the positive sync pins no separate 3 pin negative sync connector.  The Arcadevga is putting out negative sync so I'm thinking that is the problem.  Is it possible to get this monitor to sync with an Arcadevga?  If so how?  I did find this http://arcadecontrols.com/BBBB/slanted.html but have not had a chance to try it yet.  Any other suggestions?
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 03:51:37 pm
Re: ArcadeVGA and WG4600
« Reply #1 on: May 11, 2012, 07:04:45 pm »
I think the WG4600 is RGB-GND-SYNC (Composite). You need to combine your H/V Sync (twist it together) and connect this to Composite.
Maybe an expert will chime in
Free VGA Breakout Cable
