Author Topic: help needed with setting up xbox360 in arcade cab  (Read 18603 times)
pudluther
  • Last login:December 24, 2012, 11:32:59 am
« on: April 09, 2012, 03:22:54 pm »
hey fellas...
i'm setting up an xbox360 in one of my existing arcade cabs...i'm going as simple as possible and will be bypassing the monitor, going with an LCD TV, and am using adapters between standard xbox360 controllers and my arcade control panel.
i purchased the J-PAC, ps2 controller adapter from ultimarc.com and then purchased an adapter for ps2 to xbox360 controller.  i have everything hooked up now and am in the process of testing.
so far, everything works great with no input lag whatsoever.  the only issue i'm having is that the controls were not all mapped correctly by default.  the arcade stick works perfectly and the 1P start button works as it should....but i think the only other buttons that are mapped are LB, RB, X, and Y (and not in the positions i'd like).
is there a way to map the controls the way you want them?  i noticed a mapping program of sorts on the disc that was included with my purchase, but it appears to be geared more towards mapping PC inputs.
surely someone out there has some experience with this and can provide some help....
thanks in advance.
Green Giant
Re: help needed with setting up xbox360 in arcade cab
« Reply #1 on: April 09, 2012, 04:47:52 pm »
I am confused here.  Why are you using a j-pac?
Wouldn't you just purchase the x-arcade xbox 360 adapter?  Wire the arcade controls directly to the adapter and use the ps2 adapter to connect it to your xbox 360?
Doesn't it have pinouts that you have to connect to for matching the xbox 360 controllers?
Toxic Arcade, my first build
pudluther
« Reply #2 on: April 09, 2012, 05:25:18 pm »
i'm confused as well.  which product are you talking about?
this?
http://www.xgaming.com/store/x-arcade-adapters/product/x-arcade-xbox-360-adapter/
i'm not using an x-arcade control panel.  i'm using an arcade cab (dynamo).  i've somehow gotta get the xbox controller to work with the buttons on my arcade control panel...hacking a controller is not an option for me.  i was told that using the adapters to run through my JAMMA would work.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: April 09, 2012, 08:05:28 pm »
why was hacking the controllers not an option?  Its easy to do, if you didn't want to do it yourself, you should just buy one of haruman's hacks.
pudluther
« Reply #4 on: April 09, 2012, 09:05:41 pm »
didn't want to do it myself.  i prefer this option.  plug 'n play is always my first choice.
Donkbaca
« Reply #5 on: April 10, 2012, 11:29:54 am »
why not just buy hacked pads from haruman?
pudluther
« Reply #6 on: April 10, 2012, 12:28:09 pm »
i didn't want hacked pads.  doing it this way, i can change the button setup any time i like...it takes about 2 minutes.
so yes, i've figured out the answer to my question in the OP.  lol.
« Reply #7 on: April 10, 2012, 12:52:45 pm »
Just as an FYI, with my hacked pads, you can change button setup at any time, with nothing more than a small flathead screwdriver.
Donkbaca
« Reply #8 on: April 10, 2012, 12:58:25 pm »
good luck, the only problem with adapters is that they tend to introduce lag.  let us know how it turns out.
pudluther
« Reply #9 on: April 10, 2012, 01:07:27 pm »
there's no lag at all.  i've heard that before though, so i must just be lucky...this is the second time i've done something with these types of controller adapters and there has never been any lag.  tested this one on MORTAL KOMBAT and NBA JAM....the inputs behaved flawlessly.
i will update the thread once i get it working fully......figured out the button mapping, just need to figure out how to make sure it saves.
pudluther
« Reply #10 on: April 10, 2012, 01:08:16 pm »
cool.
  • Last login:February 13, 2026, 05:20:07 pm
« Reply #11 on: April 10, 2012, 02:08:46 pm »
You can remap the controls by using the Ultimarc remap tool for your J-Pac. There's no info about PS2 controls on their site though, so it's trial and error.
pudluther
« Reply #12 on: April 10, 2012, 02:20:56 pm »
thanks.
yeah, that's what i've done.  i think i have a decent handle on how i want the controls mapped and i've got everything set up in the program right now....i'm having trouble getting it to save to the JPAC, but once i get that problem solved i'll be done with the controls.
MTPPC
« Reply #13 on: April 11, 2012, 12:38:47 am »
Using the WinIPAC, you have to choose your ultimarc device under the options button, IIRC.
http://pinballmd.com/
pudluther
« Reply #14 on: April 11, 2012, 12:17:04 pm »
that's right.
i've got the right device selected and everything, but i still keep getting a dang error message when i try to program the button configuration.
it's getting annoying.  :/
« Reply #15 on: April 11, 2012, 12:22:10 pm »
You know what's not annoying?  Hacked 360 controllers...   ;D
Sorry you're having issues.  Hopefully you find a solution.  Lots of people here with good ideas, maybe someone can help you out.
Donkbaca
« Reply #16 on: April 11, 2012, 12:25:42 pm »
Alternatively, you could have just got cheap xbox 360 joysticks, took apart the case, and crimped on spade connectors too.
« Reply #17 on: April 11, 2012, 01:23:52 pm »
If you're running Windows7 or Vista you might have to run the program as admin with winxp compability checked.
pudluther
« Reply #18 on: April 11, 2012, 01:59:35 pm »
yes, i'm running windows7.  i am running it as admin.
.....but what do you mean by "with winxp compatibility checked"??
P-chan
  • Last login:April 13, 2022, 12:39:40 am
« Reply #19 on: April 11, 2012, 03:23:03 pm »
If you right click on the .exe and go to properties, somewhere in there you can check a box to run it in XP compatibility mode.  Sometimes this helps if it's not running right.
pudluther
« Reply #20 on: April 11, 2012, 04:24:14 pm »
ok.  thanks.
still not working...i'm thinking maybe i've got the JPAC hooked up to my PC incorrectly when i'm trying to program it...
pudluther
« Reply #21 on: April 11, 2012, 08:03:11 pm »
ok.  thanks.
ok...figured out that i WAS hooking it up to the PC incorrectly...i've now remedied that (it is hooked directly into my PC via a ps/2 keyboard cable to USB adapter), but i STILL can't get the dang thing to program.
pudluther
« Reply #22 on: April 12, 2012, 04:23:48 pm »
picking up a ps/2 to USB adapter tomorrow...
this should remedy the problem and allow me to save the button configuration to the JPAC......finally.  :)
Donkbaca
« Reply #23 on: April 12, 2012, 04:34:01 pm »
Good luck, those things tend to work well for mice, but I could never get one to work with a keyboard input.
BTW - If you had hacked pads or a hori joystick, you would be gaming by now  ;)
pudluther
« Reply #24 on: April 12, 2012, 04:52:15 pm »
yeah...i like being different.  it seems to really get under people's skin that i chose not to hack....that sort of unrest appeals to me.  lol.   :afro:
Donkbaca
« Reply #25 on: April 12, 2012, 04:59:19 pm »
So what is your problem exactly?  You configure the buttons, and it interfaces fine with the Xbox 360, then you turn it off and turn it on and you have to remap the buttons?
« Reply #26 on: April 12, 2012, 05:01:44 pm »
Nice attitude. And you were asking for help?  :lame:
Donkbaca
« Reply #27 on: April 12, 2012, 05:03:42 pm »
Why do you have remap buttons?  Why not just wire it so the right buttons match up to the right inputs?
pudluther
« Reply #28 on: April 12, 2012, 05:35:22 pm »
k.  smilies rule.
pudluther
« Reply #29 on: April 12, 2012, 05:40:22 pm »
no...right now the only problem is i cannot get the JPAC to actually program.  it keeps giving me an error message.  i've been in contact with andy over at ultimarc and he has helped me identify the problem.  apparently the JPAC is rather finicky when it comes to getting it to communicate with the PC....only a specific type of adapter will do the trick.  i suspect that once i get that adapter tomorrow, i will be able to program it with no problems.
not all of the buttons are being used right now....the MAME pre-loaded button configuration just won't work.  so i've gotta remap the buttons the way i want them....i'm basing it off of a MORTAL KOMBAT layout and then going from there (high punch, block, high kick on top...low punch, throw, low kick on bottom.....or something to that effect).
pudluther
« Reply #30 on: April 12, 2012, 05:42:00 pm »
btw donk...i appreciate your help/suggestions/input.  also appreciate you not being a dick.
Donkbaca
« Reply #31 on: April 12, 2012, 05:51:17 pm »
Ok, let me back up a second here.  So are you trying to use the same joystick and buttons to control the PC AND the 360 at the same time? Or are you just putting a 360 in a cab and are just going to use the 360?
pudluther
« Reply #32 on: April 12, 2012, 05:58:17 pm »
yeah.....just putting a 360 in a cab and i'll be using the 360 as a multicade of sorts.  mainly playing the old arcade MK's, the new MK, MK vs. DC, NBA JAM, and any of the old arcade classics i can still find on LIVE....i know missile command, pac-man, mrs pac, dig dug, and quite a few others are on there now.  i don't really want anything that i can't download.
the only reason the PC comes into play is because i need to program the buttons on my arcade panel (via the JPAC hooked to my laptop).
Donkbaca
« Reply #33 on: April 12, 2012, 06:03:48 pm »
OKay, so why not just wire it differently?  For example if your late out is like this:
  A X Y RB
  B RT LB RB
and you want it to be:
  X Y RB RT
  A B LB LT
Why not just switch the wires around so you don't have to reprogram it?
pudluther
« Reply #34 on: April 12, 2012, 06:05:59 pm »
  A X Y RB
  B RT LB RB
  X Y RB RT
  A B LB LT
i thought about that too.....but there are only, i think, 4 of the 6 (main) buttons that are programmed by default.  i think LB, RB, X, and Y are currently working....oh, and the start button is working too.  lol.
but yeah, if they were all working and just out of order, i'd re-wire in 5 minutes and be done with it.  :)
Donkbaca
« Reply #35 on: April 12, 2012, 06:21:02 pm »
so how is this thing hooking up to the xbox 360?  by PS2 adapter, do you mean playstation 2? Or do you mean Ps/2 as in a Ps/2 keyboard or mouse input?
pudluther
« Reply #36 on: April 12, 2012, 06:43:27 pm »
there's a playstation to 360 adapter hooked into my actual 360 and a wired 360 controller is hooked into that adapter as well.  from there a playstation2 adapter is running in between that first adapter and the JPAC....the JPAC is hooked up via a ps/2 keyboard/mouse cable and then plugged into the JAMMA harness:
and no...even with all that, there's no lag.  ;)
MTPPC
« Reply #37 on: April 12, 2012, 09:39:25 pm »
I don't think he has the PC and output of the j-pac all hooked up right. But it's really hard to help someone who knows it all already and can't even explain in pictures how the devices (j-pac in particular) are connected.
« Reply #38 on: April 12, 2012, 10:43:00 pm »
He has a nice carpet though.
pudluther
« Reply #39 on: April 12, 2012, 11:11:34 pm »
what in god's holy name are you talking about?
oh, wait.....you must be another one that's butthurt over me not hacking a GD controller.  color me bored to tears with that.  :/
