Author Topic: Discs of Mame - Discs of tron cab - Complete  (Read 22856 times)
Re: Discs of Mame - Discs of tron cab - CP Done
« Reply #40 on: May 01, 2012, 11:40:40 am »
That looks fantastic.  Retro and new all at the same time.  Nicely done.   :applaud:
Los Abrazos Rotos
Discs of Mame - Discs of tron cab - Its finished! Glowy pics!
« Reply #41 on: May 03, 2012, 05:13:51 pm »
Well, just about finished..  I got 3 UV lights on ebay for 99p and have installed  2 of them in the cab.  Everything is working as it should, the apache push/pull spinner is amazing.
It really has come out well, discs of tron feels exactly like the arcade version to play.  I kinda lucked out on the joystick, another ebay bargain - I think it might actually be a tron stick as it appears to be restricted in exactly the same way.
It was worth every penny to make this, I cant believe after 20 years I can play this game as it was meant to be played again.  Thanks to everyone who offered help and advice.  :applaud:
Santoro
  • Santoro
  • Trade Count: (+32)
  • Last login:December 17, 2025, 09:32:31 am
  • Boycott Quarters!!!
    • ArcadeReplay!
Re: Discs of Mame - Discs of tron cab - Its finished! Glowy pics!
« Reply #42 on: May 03, 2012, 07:43:25 pm »
*santoro drools.*
rockyrocket
« Reply #43 on: May 04, 2012, 10:56:33 am »
Man I love it well done!.
It just is not possible to overdo UV is it.
  • Last login:January 06, 2026, 11:02:04 am
« Reply #44 on: May 04, 2012, 10:57:17 am »
That cab looks great!
Good job!
 :applaud: :applaud: :applaud:
Los Abrazos Rotos
« Reply #45 on: May 04, 2012, 11:00:30 am »
Nope!  I'm on the cusp  :lol
« Reply #46 on: May 04, 2012, 11:13:02 am »
Holy crap, my childhood called, it wants that cab  :applaud:
Los Abrazos Rotos
« Reply #47 on: May 04, 2012, 12:14:51 pm »
Better start building then!  This is quite a simple one to build in some ways, the shape is pretty simple,,  The complex part was working out how to accommodate the UV part.  I like the solution I've come up with.
I know what you mean about the childhood thing - this game pretty much raised me!
Santoro
  • Santoro
    • ArcadeReplay!
« Reply #48 on: May 04, 2012, 12:23:04 pm »
How did you mount the bezel art behind the glass?
Los Abrazos Rotos
« Reply #49 on: May 04, 2012, 12:42:39 pm »
Its sticky back vinyl.  I stuck it to a piece of tinted 5mm acrylic sheet then carefully cut out the shapes with a craft knife. I then put a second layer of 5mm clear acrylic on top - this part can be lifted out easily and is held in place by the steel control panel & a screw at the top.
Los Abrazos Rotos
Re: Discs of Mame - Discs of tron cab - A few minor changes
« Reply #50 on: May 24, 2012, 04:08:45 am »
So, I've got this completely up and running with GameEx as the front end & windows completely hidden.  GameEx is absolutely superb by the way.
I ran into a few problems with my control panel - I knew I shouldn't have used it from the start...   I wasn't happy with the position of my spinner, It was just too close to the stick. Also the angle of the control panel wasn't exactly how I wanted it.
  I decided to move the spinner up a little & slightly left, that way its completely out of the way.  I then slightly altered my CPO and printed a new one out.
I dont know how I didn't see that problem coming when I drew it...
 After that I built a slightly altered copy of the Control Panel from MDF.  Its a million times better, more comfortable, lighter. The joysticks are fixed underneath with screw-in dynafix inserts.
I think I can call this thing finished now..
« Last Edit: May 24, 2012, 05:10:59 am by Los Abrazos Rotos »
JayB
  • Last login:January 25, 2013, 06:11:59 pm
« Reply #51 on: May 24, 2012, 05:06:29 am »
 :applaud: That's absolutely brilliant.  :cheers:
rockyrocket
« Reply #52 on: May 25, 2012, 03:44:41 am »
Nice, well done!
Hammerfist
  • Last login:May 21, 2013, 08:01:25 am
Re: Discs of Mame - Discs of tron cab - Complete
« Reply #53 on: October 02, 2012, 02:28:58 am »
Gotta bump this just to compliment the nice form of the cab (and everything else in it for that matter). If someone would present me with a sketch of that profile, I would be a bit doubtful but MAN that came out great!
My blood type: R
hannasp
  • Last login:February 11, 2018, 04:41:18 pm
« Reply #54 on: September 24, 2017, 03:00:28 pm »
I am starting a new build for Discs of Tron, but have had trouble sourcing artwork for the joystick insert.  Would you be willing to share your art files?  Thank you.
