Author Topic: Button sharing?  (Read 1360 times)
Samart
  • Last login:June 07, 2012, 11:03:51 am
Button sharing?
« on: February 16, 2012, 03:17:07 pm »
I did a search but couldn't find the answer. I'm sure its basic question. I would like a spinner and 4 way joystick to be next to each other on the control panel with 3 buttons. Can they both share the same three buttons? Is this a wiring issue or software mapping? Thanks for any help.
05SRT4
  • Check out my Pow Pow
Re: Button sharing?
« Reply #1 on: February 16, 2012, 03:19:34 pm »
Sounds like software mapping if your using MAME you can setup the controls to whatever you want.
Re: Button sharing?
« Reply #2 on: February 16, 2012, 03:23:28 pm »
Yes they can.  Wire everything normally and assign the required values from the emulator or FE setup menu.
Samart
Re: Button sharing?
« Reply #3 on: February 16, 2012, 03:30:29 pm »
Thanks guys. I figured it was as simple as that. I guess I was confused because I've seen plenty of CPs where different controllers were close to each other but had their own buttons. Thanks again!  :cheers:
Re: Button sharing?
« Reply #4 on: February 16, 2012, 03:33:53 pm »
Oh, those cps... don't look at those cps ;D
Best of luck!
paigeoliver
  • Awesome face!
Re: Button sharing?
« Reply #5 on: February 20, 2012, 05:48:24 pm »
You may only need two buttons. IIRC the only 4-way game to use more than 2 buttons is Mouse Trap and it uses 4. While I can't think of any spinner games that use 3.
