Author Topic: Groovy Arcade Linux Live-CD, based on Arch Linux (official update)  (Read 116667 times)
processor
  • Last login:June 18, 2018, 04:04:27 am
Re: Groovy Arcade Linux Live-CD, unofficial update
« Reply #40 on: April 03, 2012, 04:38:04 am »
Forgot that I had already download the 32bit release:
Downloadable here:
Groovy Arcade Linux - 25/03/2012 - 32Bit
--Processor
Calamity
  • Moderator
  • Last login:January 30, 2026, 08:05:28 am
  • Quote me with care
« Reply #41 on: April 03, 2012, 04:43:18 am »
That's great, thanks! I was missing the 32-bit iso. I'm uploading the 64-bit iso right now, then I'll upload this one to the ftp too.
Steps to create a log:
greginparis
  • Last login:May 29, 2012, 04:34:22 am
« Reply #42 on: April 05, 2012, 08:06:11 am »
Hi Everyone,
Like others I'm waiting for the link to download the 64 bits version.
If you want to create a torrent file, I will be happy to share my seedbox (100 mbps) to host the file...
Greg
Calamity
  • Moderator
« Reply #43 on: April 05, 2012, 08:40:59 am »
greginparis
« Reply #44 on: April 05, 2012, 09:39:26 am »
Thank you for the link, I didn't know this ftp address.
What about the soft to boot from USB ?
Thanx
maxpelle
  • Last login:January 03, 2014, 11:54:25 am
« Reply #45 on: April 06, 2012, 05:03:37 am »
Can someone explain how to apply the advmenu+ exit patch?
Can i edit the configuration files directly within the iso before installation?
I mean with softwares like UltraIso and similar...
Thanks.
Calamity
  • Moderator
« Reply #46 on: April 06, 2012, 04:28:43 pm »
Here is the patched 64-bit binary of AdvanceMenu+ as I have it in my installation, just copy it into /usr/games/bin/
Hunk_4TH
  • Last login:January 21, 2026, 09:48:13 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #47 on: May 08, 2012, 06:53:44 pm »
I hate to bump old threads. But is this still available? All the links seem dead :(
Calamity
  • Moderator
« Reply #48 on: May 08, 2012, 06:59:12 pm »
It will be available again soon, we just need to set up the new ftp.
Hunk_4TH
« Reply #49 on: May 08, 2012, 08:36:45 pm »
Oh ok man thanks! Looking forward to it :) Is there anywhere to grab the iso in the time being?
MonkeyJug
  • Last login:September 11, 2025, 04:54:07 pm
« Reply #50 on: May 29, 2012, 05:03:58 am »
ves, could you be so kind as to conjure up a 64-bit, 0.146 release, complete with the 'return to advmenu' patch?
many thanks!
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #51 on: June 02, 2012, 02:11:21 pm »
Very soon.....
Automatic mounting of partitions.
Automatic configuration directories roms.
Fix Grub when installed on pendrive.
Fix Advmenu +
etc...
MonkeyJug
« Reply #52 on: June 03, 2012, 06:15:33 am »
thanks!  :cheers:
ves
« Reply #53 on: June 07, 2012, 12:40:55 pm »
Hello,
Fix advmenu
Fix sound zsnes64bit
Add wahcade (you have to configure it)
Add packages for rotate picture video... to wahcade
Add Groovyume (you have to configure it)
Update Groovymame 146
Add automount usb etc. .. (mounts on /media)
Add autoconfig roms dir
Update UpdateGroovyMame UpdateAdvmenu+ UpdateMenu
Fix Grub installed on pendrive.
etc.....
Please check and report bugs
http://code.google.com/p/groovyarcade/
« Last Edit: June 07, 2012, 12:49:44 pm by ves »
Calamity
  • Moderator
« Reply #54 on: June 07, 2012, 03:34:06 pm »
This sounds great Ves, I'm downloading it now...
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #55 on: June 08, 2012, 04:53:16 am »
Nice update :) .
Earth could be the hell of another world
MonkeyJug
« Reply #56 on: June 08, 2012, 11:05:17 am »
when i try to boot from the 64-bit cd, i immediately get the error 'could not find kernel image: vesamenu.c32'
Calamity
  • Moderator
« Reply #57 on: June 08, 2012, 12:18:44 pm »
Same error here :(
(testing 64-bit cd)
Calamity
  • Moderator
« Reply #58 on: June 08, 2012, 01:56:47 pm »
A warning about the new versions of the live-cd: there seems to be a problem after installing the 32-bit version, the system will not boot, however it works when booting as live-cd. The 64-bit version just won't boot anyway. Ves is working to fix them. In the meanwhile I'm removing the links from the project's site.
ves
« Reply #59 on: June 09, 2012, 10:33:19 am »
Sorry!!!!!!!
New isos, I think it all resolved.
MonkeyJug
« Reply #60 on: June 09, 2012, 01:16:23 pm »
thanks for the quick fix - i'll let you know how it goes...
MonkeyJug
« Reply #61 on: June 09, 2012, 01:19:11 pm »
btw, just a quick question...
i currently have an ati 4350 card in the cabinet, running groovymame.  i have a spare hd5770 that is obviously alot more powerful, but would i see any benefit from installing that card into the machine to replace the 4350?
MonkeyJug
« Reply #62 on: June 09, 2012, 02:42:35 pm »
64-bit cd installs fine, but when it reboots, it gives an error:
Booting Groovy Arcade Linux.
Error 15: File not found...
Press any key to continue...
ves
« Reply #63 on: June 09, 2012, 03:11:18 pm »
Hello,  can you delete system partiton Gaboot and GA before to install?
MonkeyJug
« Reply #64 on: June 11, 2012, 09:35:02 am »
Clean install worked, but now i cant get my roms to appear...
Not sure if i'm doing it right, but i mount my roms drive and then point the mame rom directory (new feature) to the roms directory and nothing shows...
It appears to be listing the same path (that i chose in the mame roms option) in mame.ini and advance.rc files, but still not showing.
Of course it's possible that i'm doing it wrong, so maybe calamity can confirm this new feature is working correctly?
ves
« Reply #65 on: June 11, 2012, 09:44:26 am »
Hello MonkeyJug, Where is you path roms?
Proves the UpdateMenu and retry configuration roms.
MonkeyJug
« Reply #66 on: June 11, 2012, 11:16:16 am »
I have a seperate hdd with the folder structure /MAME/roms...
In the past, i just selected the roms drive and amended the path in the 2 files, /home/roms/MAME/roms and it worked...
Calamity
  • Moderator
« Reply #67 on: June 11, 2012, 11:25:08 am »
Hi MonkeyJug,
There was a bug in the previous "Change Dir Roms" option, now Ves has fixed it, run "Update Menu" with internet connection enabled, you'll see an error message, ignore it. Then exit gasetup and run it again, and the option should work fine. You may need to edit Advmenu.rc manually if it was modified by the previous option.
I'm afraid I haven't managed to install the new iso into a pendrive, it keeps failing during the autopartitioning process.
MonkeyJug
« Reply #68 on: June 11, 2012, 12:13:03 pm »
Aah, ok. Now i understand! I will try that...
Btw, calamity, do you know if i would benefit from installing an ATI HD5770 to replace my 4350 in my Cab?  Will it even work?
Calamity
  • Moderator
« Reply #69 on: June 11, 2012, 12:34:02 pm »
According to bitbytebit the Linux drivers do support 15 KHz for the HD 5000 family so it's a matter of trying but I guess it will work. You won't get better performance for MAME however, so only benefit may be in using other emulators that are 3D intensive.
MonkeyJug
« Reply #70 on: June 11, 2012, 02:26:43 pm »
Hi MonkeyJug,
All sorted now, thanks Calamity and special thanks to ves.  I can't believe more people aren't using this for mame!
Calamity
  • Moderator
« Reply #71 on: June 11, 2012, 03:06:00 pm »
Well, most people (me included) have a working Windows system that required hundreds of hours to setup and are reluctant to replace it with some uncertain new system or mess with a different hard drive. However, IMHO the possibilty of installing this system to a pendrive and thus have a dual boot machine will make many people decide to give it a try. This has been possible since long but required manual editing of some config files, which cuts the amount of potential users by 99%.
demetris
  • Last login:March 04, 2013, 07:15:50 am
« Reply #72 on: June 12, 2012, 07:56:43 am »
Registered to give my thanks to ves and all involved  for producing the best Mame OS ready for cabinets since advance cd era.
Keep Up the wonderful work.
A dream come true for me.
Thanks again
« Last Edit: June 12, 2012, 04:20:54 pm by demetris »
ves
« Reply #73 on: June 23, 2012, 07:09:30 am »
Hello, we have new update for linux 146u1
demetris
« Reply #74 on: June 23, 2012, 06:26:01 pm »
Ves,
Do you think a new iso soon with gasetup updated and new mame version?
Any test iso for nvidia? :)
ves
« Reply #75 on: July 08, 2012, 06:18:24 am »
Hello, update groovymame 146u2 linux , demetris new iso very soon, I have had may problems with my broken hardware.
demetris
« Reply #76 on: July 08, 2012, 09:06:01 am »
Great news ves,
Sorry hearing about broken hardware, i hope resolved soon.
Regards
blontic
  • Last login:December 21, 2020, 08:03:28 am
Re: Groovy Arcade Linux Live-CD, based on Arch Linux (official update)
« Reply #77 on: July 17, 2012, 02:22:01 am »
Is there any trick to get this booting off USB? I have tried unetbootin and lili USB Creator and both fail during the boot on
Waiting 30 seconds for device /dev/disk/by-label/None ...
Calamity
  • Moderator
« Reply #78 on: July 17, 2012, 08:29:53 am »
There were some files that needed to be replaced so it could boot from USB. I find it a better approach to actually burn a CD (you can use a RW CD) to boot from it, and then *install* the system into an USB pendrive.
blontic
« Reply #79 on: July 17, 2012, 07:30:55 pm »
Good Idea. Ill try that. Thank you.
