Author Topic: pga golf vr-gobal  (Read 215039 times)
simonw
  • Last login:January 11, 2019, 07:12:12 pm
  • Save my PGA machine
Re: pga golf vr-gobal
« Reply #1000 on: February 24, 2013, 05:08:47 pm »
Hi Ed
I'm more than willing to give it a try.
What do I need to do now?
I've installed the recovery disc.
Do I need to delete pga\hercules\gvrdongle.exe from the recovery disc and reinstall on a clean hard drive?
here are the step's
COPY RESCUE DISK INTO IT'S OWN .DIR ON A ACTIVE HARDDRIVE
LET'S USE THIS AS AN EXAMPLE C:\RESCUE
OPEN IT
LOOK FOR HERCULE'S
OPEN IT
LOOK FOR GVRDONGLE.EXE
KILL THAT .CMD
Will this sort the missing drivers, or does it matter?
Cheers
Simon
« Last Edit: February 24, 2013, 08:17:13 pm by simonw »
ed12
« Reply #1001 on: February 24, 2013, 08:04:01 pm »
hi
yes u are on the right track,that is correct
there is a few other's to kill also..
but hold tight i may have your rescue
i am canada bound,so it could be a odd # build
let me boo at them,if i go back that far i will foward to a up-load site
ed
simonw
« Reply #1002 on: February 24, 2013, 08:19:50 pm »
Great.
I look forward to your solution  :)
Cheers
ed12
« Reply #1003 on: February 24, 2013, 08:53:36 pm »
hi
in this statment
>Hi Ed
here are the step's
OPEN IT
>LOOK FOR HERCULE'S
OPEN IT
KILL THAT .CMD<
!u will kill the gvrdongle.cmd totaly
it will walk right around the dongle call
and carry on loading as pre normal!
>>U MUST THEN RE-BURN THE NEW RESCUE DISK<<,and use it
but as i stated there is a few other .cmd's to kill  or edit
i have found the call in some of the setup disk's #1 and #3
ed
ed12
« Reply #1004 on: February 24, 2013, 11:04:55 pm »
hi
ok simonw
u have a total of 3 disk's correct ? this will inculde the system rescue disk
if so 1/2 are the exact same
both of which i have
in championship 3 they changed the key for the dongle
hence the massive edit's to kill the dang cmd
now go to gobalvr tech ref site and make sure
this > pn:050-002401< match's what u need,and i will get it up there
if u have to call them ref the ^^^^^ # so they can cross ref it for u
they will give u a proper part # if mine is wrong
we can then move foward for u the easy way
ed
simonw
« Reply #1005 on: February 25, 2013, 04:02:49 am »
Yes 3 discs including the rescue disc.
Looking here:
http://service.globalvr.com/reference/default.htm
It would be pn:050-0055-01 as I have a Nytric 1.5 installed.
VER 050-0024-01 REV B (causes a blue screen)
Reading the UK document below:
http://service.globalvr.com/downloads/international/040-0126-CVA_PGA_TEAM_CHALLENGE_UPGRADE_CVA-WEB.pdf
I believe the original Recovery disc would have been pn:050-0101-01 at it is a Maygay/Enta system not DRI. (would this matter now there's a different motherboard?)
I can't wait to play the game!
Simon
« Last Edit: February 25, 2013, 10:19:45 am by simonw »
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #1006 on: February 25, 2013, 06:18:59 am »
Hi Simon, what were the steps u used to make the rescue disk bootable?
Thx Spitfire
simonw
« Reply #1007 on: February 25, 2013, 06:39:19 am »
Hi Spitfire
I used Imgburn to add the files, selected make bootable and added a Windows98_SE.img for the boot file.
Once the system boots from the CD. I type D:(CD Drive letter) enter, then: PQDOTASK.BAT enter which loads the recovery disc.
Cheers
Simon
« Last Edit: February 25, 2013, 06:46:12 am by simonw »
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« Reply #1008 on: February 25, 2013, 08:31:21 am »
I may have a Championship II rescue.  Let me check today.  If I have it I will upload it to Dropbox for you.
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
stpcore
« Reply #1009 on: February 25, 2013, 08:38:51 am »
OK so I have the following:
EMERGENCY RECOVERY DISK
CHAMPIONSHIP II
PATCH DISK
CHAMPIONSHIP II
PATCHES FROM VER 2.1.0 to 2.1.1
INSTALL DISKS
CHAMPIONSHIP II
Not sure what you need but let me know and I can upload them for you if need be.
simonw
« Reply #1010 on: February 25, 2013, 08:43:27 am »
Hi Stpcore
That's great news!
Please could you upload the recovery disc to the Dropbox folder?
stpcore
« Reply #1011 on: February 25, 2013, 08:46:40 am »
Absolutely.  I will do it for you now.  Look for it in a few minutes.
simonw
« Reply #1012 on: February 25, 2013, 08:55:01 am »
Thank you so much! :)
Is there anyway that you could upload the install discs too? (just in case mine have a problem like my recovery disc did causing the pain of BLOD)
stpcore
« Reply #1013 on: February 25, 2013, 09:00:27 am »
Sure.  I will upload those with the patch disks in about 20 minutes.  I'm getting my son ready for school at the moment.
« Last Edit: February 25, 2013, 09:12:09 am by stpcore »
simonw
« Reply #1014 on: February 25, 2013, 09:15:33 am »
Thank you.
Championship 2/NEW is only showing 3 files (are they all still uploading?)
Cheers
Simon
stpcore
« Reply #1015 on: February 25, 2013, 09:17:48 am »
Yes.  The largest of the files is in the middle of uploading right now.  I will let you know when it's complete.
stpcore
« Reply #1016 on: February 25, 2013, 09:38:17 am »
OK, Rescue should be uploaded and complete.  I will now upload install 1, 2, and the patch disk.
simonw
« Reply #1017 on: February 25, 2013, 10:23:04 am »
Hi
Recovery CDs so far:
Interestingly the VER 050-0024-01 REV B causes a BLOD on boot up.
PGA Golf Team Challenge recovery disc install fine and loads up XPE but states the dongle isn't valid when trying to install Champ 2.1.3.0
Stpcore: I'll try the new game install disc once it has uploaded.
Simon
« Last Edit: February 25, 2013, 10:27:15 am by simonw »
stpcore
« Reply #1018 on: February 25, 2013, 10:31:45 am »
Maybe a fresh install is the way to go?  Surprised its so finicky!  I was able to use the recovery CD for "Challenge" to install "Team Challenge" without any problems but who knows?  I will let you know as soon as everything is uploaded.  It's taking some time so maybe 2 hours or less?
simonw
« Reply #1019 on: February 25, 2013, 10:41:00 am »
Same with a fresh install. It's so difficult trying to work with the original dongle! if I could remove the need for it I'd install the team challenge as the recovery CD works and bin my championship 2 dongle!
It'd be great to eventually play PGA globally, maybe just fix it first  :D
Thank you for helping!
stpcore
« Reply #1020 on: February 25, 2013, 10:43:36 am »
I agree.  We've been anticipating the dongle kill for quite a long time.  It will be nice if it happens!
I wonder if you tried the rescue for Championship III with a fresh install of the Championship II disks that I'm uploading if that would work?  Did you want to give it a try?
simonw
« Reply #1021 on: February 25, 2013, 10:54:08 am »
I don't have the Championship 3 rescue CD.
Only PGA Golf Team Challenge and championship 2/2.1
Cheers
stpcore
« Reply #1022 on: February 25, 2013, 10:59:49 am »
I have the rescue for Championship III.  I will upload it now.
simonw
« Reply #1023 on: February 25, 2013, 11:02:58 am »
Excellent! :)
I'm running out of CDs  :D
stpcore
« Reply #1024 on: February 25, 2013, 11:06:07 am »
Well the Rescue Disks I have for Championship versions are
Ver 8.26.2003
050-0024-01 Rev B
(Came with Championship III)
Ver 8.26.2003
050-0024-01 Rev B
(Came with Championship II)
*Uploaded this to you*
Version 8.25.03
050-0024-01 Rev B
(Came with Championship I)
I also have the "Challenge"
Version 3.0.0
050-0072-01
Team Challenge is in Dropbox and you tried that already with the most success.
Which one(s) did you want to try?
**EDITS MADE TO CORRECT VERSION NUMBERS***
« Last Edit: February 25, 2013, 11:13:18 am by stpcore »
simonw
« Reply #1025 on: February 25, 2013, 11:13:27 am »
Thank you for the quick replies.
All three if possible because I have no idea which will work as you said Team challenge recovery installs while champ2 doesn't!
I'd be very grateful if you could! :cheers:
Simon
« Last Edit: February 25, 2013, 11:16:22 am by simonw »
stpcore
« Reply #1026 on: February 25, 2013, 11:16:16 am »
I updated those version numbers in my last post as I accidentally mixed and matched the rescue versions with install versions.  So with that being said it looks like Championship II and III where using the same Rescue version.  I can upload Championship I and Challenge Rescues to see if that will make any difference for you.  You have to be getting close I'm assuming.  If that dongle kill gets released you will be golden.
« Last Edit: February 25, 2013, 11:19:28 am by stpcore »
simonw
« Reply #1027 on: February 25, 2013, 11:42:47 am »
Yes please.
I feel like it's making progress.
I've just tried to install the Team challenge CDs out of interest and they show the following errors:
Cannot find:
D:\_setup\feedkeys.wsf
D:\_setup\killgame.wsf
D:\_setup\deleteshort.wsf
D:\_setup\stopautoplay.wsf
but it continues to install the 3 CDs  ???
Once all 3 Cd are installed:
It shows the following error messages:
Cannot find:
D:\_setup\SetupCabinet.wsf
D:\_setup\InstallCertificate.wsf
Installation failed
Further than my championship install!
Please let me know when they are all uploaded.
« Last Edit: February 25, 2013, 01:14:53 pm by simonw »
ed12
« Reply #1028 on: February 25, 2013, 01:19:01 pm »
hi
simonw
that is all hercule's and gvr error's
the kill cmd is the 1 of interest
>D:\_setup\killgame.wsf<
the rest are perty normal
u must have your load set to display ?
as that is mostly background noise
wfs is a wack format,it was written for gobalvr
if u convert it in wordpad
u can clearly see what it is doing
ie this is a dos32  program must be run under window's >u shake your head at that statment<,but thats what they did to confuse the mud
stpcore i am going to try my patch this afternoon
i truly hope it work's >live< ie > a running machine<
and not a disk pre say
ed
simonw
« Reply #1029 on: February 25, 2013, 01:36:18 pm »
Hi Ed
What would you recommend that I do moving forward?
Progress so far:
The only recovery disc to install so far is the team challenge.
Champ 2 states the dongle is invalid.
Team challenge will install with the errors above that you replied to.
Cheers
Simon
ed12
« Reply #1030 on: February 25, 2013, 02:00:13 pm »
hi
let it run through
all the way
if it went  by the dongle call >key<
it is on it's merry way
here are thing's u should know by now
a=mobo is good
b=u have a proper mbr on a harddrive
c=u have a good video card
the rest is perty easy
no fear's now
ed
simonw
« Reply #1031 on: February 25, 2013, 02:08:25 pm »
That's good news.
Please could you let me know what I need to do once it has installed.
Simon
ed12
« Reply #1032 on: February 25, 2013, 03:03:38 pm »
hi
a few answer's here in order
stpcore
the smart card reader take's care of itself :ie: no driver's are loaded for it
to prove this to yourself
window's key on the keyboard-device manger-smartcard reader's
it will be blank :ie-no driver's:
rember u may have to kill hercules
smart key >window's< logo,kill hercules
u may need to do it a few time's
at the top of the screen should read  >gvr00012909f43< or such
this btw is your key code
now onto the patch
trickey at the moment
but it can be done
LET ME TEST FIRST
>>floppy is on through seek on boot<<
>>in advaned bios we turn it to :enabled:<<
>>this of course should be floppy :a:=3.1/5 inch's<<
>>we then load our patch<<
>>with the machine on a REBOOT<<
>>it will kill the dongle cmd<<
i am just trying to patch so u ppl can do it easy like,no fuss no muss as it is said
with that said  IF  it work's the way i want?
the next patch will be your PLAYER-CARD-KILL-CMD
i truly encourage all pl to turn on the ethernet
on board 1
again bios advanced >enable<
now these patch's HAVE NO HKEY >WINBLOW'S< ERROR'S SO THEY ARE SAFE TO USE
mind u this is used real time on a running box
to do it from a fresh load i may need to edit the main file >rescue< disk and such
i am going to let this thing run for a byte
then i am going after turney
again,it should load here as a floppy patch
u can of course burn to disk if u like
ed
stpcore
« Reply #1033 on: February 25, 2013, 03:14:29 pm »
OK, so no drivers for the card reader.  I must have two card readers that aren't functioning.  If anyone has an extra they would like to sell let me know.
With that being said, Ed...I don't want to bother you with anything else so that you can dedicate your time to getting your patches up and running.  If it's something we must do step by step that's fine.  Let me know if I can help in any way as I would certainly be willing to do so.
ed12
« Reply #1034 on: February 25, 2013, 04:54:50 pm »
hi
tust me here u ppl are not REPEAT NOT  TAKEING UP MY TIME
i have learned as much as u ppl have AND i thank-u all...
am testing to usb thumb drive now
let me see how this goes
as boot will be even simpler
now that not with standing,
once gobalvr load's hercule's is basicly locked out
so i need to give gvr an attuide fix
i do think we can do this by WINDOWS/START/RUN WE FIND HERCULES
we then
will kill a few cmd's
ed
stpcore
« Reply #1035 on: February 25, 2013, 05:07:07 pm »
Sounds like you have it figured out for the most part.  When will we be able to test with you?
simonw
« Reply #1036 on: February 25, 2013, 06:14:57 pm »
Thank you for the help so far!
I'm only able to install the Team Challenge recovery and game discs.
Once the install completes I see the loading screen and these errors:
Cannot find:
Winxpe keeps asking for the following drivers:
PCI simple communications controller
Multimedia Audio Controller
Sisagp.sys
Interestingly it has changed the text on the LED display to the Team Challenge text.
How can I make this work without the correct dongle? (Mine is Champ 2)
Cheers
Simon
« Last Edit: February 25, 2013, 06:19:31 pm by simonw »
stpcore
« Reply #1037 on: February 25, 2013, 06:29:44 pm »
You can't make it work without the correct dongle yet (if you are referring to playing Team Challenge without a Team Challenge dongle).  Ed is currently working on a software patch that will allow you to do so.  You may want to hang tight and see where he leads us.  If that LED topper is displaying Team Challenge info then the game is most likely installed correctly but without a Team Challenge dongle that's not going to do you any good for right now.
ed12
« Reply #1038 on: February 25, 2013, 08:12:01 pm »
hi
yes hold tight
i am testing the patch's now
i am off tommrow >just booked it off<
so we can play...eh-ha
ed
ed12
« Reply #1039 on: February 25, 2013, 08:53:53 pm »
hi
ok with a running game
WINDOWS HOT KEY
GVRSTOP
START
from run  type >cmd< >exactley how it look's< without the ><
from cmd
c:\.
to go to the Root of the drive
cd\.
this takes u right into pure root
from there
cd\hercules
dir/w
u are in hercules
cmds will  read
gvrboot.exe
gvrinsound.exe
gvrlogger >we want this cmd as i use it<
herculestest.exe
stopall.bat >we want this .bat file as i add to it<
gvrcatchwarmer.exe >for your tube monitor<
gvrcrashmonitor.exe >if the game hang's it is to restart< and u have seen it on refresh
gvrpreload.exe >call's hercules.dat/\.bat files<
herculiesui.exe >the one we change to change out the dam i/o board<
pgapreload.exe >used for house keeping,sign's/card-reader etc<
us2_dismiss.wks >usb2 call if u use the usb2 card<
coin_drop.wav >perty much self explantore<
gvrcoinmonitor.exe need i say more >delete it if u do not want to here a coin drop<
gvrdongelmonitor.exe>the biatch we want to kill ie get rid of it<
ie c:\hercules del gvrdonglemonitor.exe >just how that cmd look's<
gvrstallmonitor.exe >this is for refresh rate< >nice to know if u are going to run a lcd
killapps.exe
pgapreload.exe >just what it sound's like<
vssver.scc >windows sequiel server<
so as u see we kill 1 cmd in the hercule's moudel
and u no longer have to fear dongle call
this of course apply's to running machine's
let me load a blank and kill it in the first stage
ed
