December 08, 2025, 05:26:07 am
you can definitely go much shallower - 6" from bottom to top clear inside is plenty for almost any controls. Older spinners are about the deepest components you are going to see.
Quote from: TopJimmyCooks on June 30, 2011, 09:55:31 amyou can definitely go much shallower - 6" from bottom to top clear inside is plenty for almost any controls. Older spinners are about the deepest components you are going to see. Ok cool so I will make the height a little shorter than. I guess 36" x 6 1/2"
