Author Topic: Control panel size  (Read 2817 times)
jrock2004
  • Last login:March 29, 2013, 11:58:18 am
    • JC Web Concepts
Control panel size
« on: June 30, 2011, 07:34:42 am »
Have not nailed it together yet but was curious if the inside is too big. Thanks
Sjaak
Re: Control panel size
« Reply #1 on: June 30, 2011, 07:45:03 am »
If that is an airplane wheel, it is...
jrock2004
    • JC Web Concepts
« Reply #2 on: June 30, 2011, 08:26:42 am »
That is a stroller wheel. I am going to cut the length down to 36 inches. The height and depth of the box is 14"x14"
TopJimmyCooks
  • Last login:Yesterday at 03:28:53 pm
« Reply #3 on: June 30, 2011, 09:55:31 am »
you can definitely go much shallower - 6" from bottom to top clear inside is plenty for almost any controls.  Older spinners are about the deepest components you are going to see.
jrock2004
    • JC Web Concepts
« Reply #4 on: June 30, 2011, 10:13:10 am »
Ok cool so I will make the height a little shorter than. I guess 36" x 6 1/2"
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #5 on: July 04, 2011, 01:50:48 pm »
You should be good with those dimensions
Galaga... Was there any other game?
