Author Topic: potential enhancement suggestion  (Read 2064 times)
kernelpanic
  • Last login:December 12, 2010, 04:01:00 pm
« on: September 08, 2010, 11:52:32 am »
on the Options | Controller | Advanced tab, there are two options for use on the MaLa Info window - "Info open/close" and "Info select". I propose an additional 3rd choice for "Info left" and change "Info select" to "Info right" - that way the left/right commands could be mapped to those functions to navigate back and forth through the info screens rather than just being able to go "right" through the screens. Up and down already work on the History screen when it is too long to fit, so having the left/right choice seems logical.
loadman
  • Moderator
    • MaLa
Re: potential enhancement suggestion
« Reply #1 on: September 09, 2010, 07:33:43 am »
Yep sounds good. I have just added it. Look for it in next version
monami
  • Last login:September 09, 2010, 07:35:16 am
« Reply #2 on: September 09, 2010, 07:35:16 am »
+1
Cycling forward and backward through the info categories is simple and makes perfect sense.
