Author Topic: MaLa v 1.73 Released  (Read 41797 times)
loadman
  • Moderator
    • MaLa
« on: August 28, 2010, 01:21:37 am »
Download from the MaLa website: http://www.malafe.net
Thank you to all the beta testers and the MaLa great user base who answer forum support questions
Please put suggestions or possible bugs in a separate post rather than add to this one
Release Notes can be found on website under 'Version History' and below:
v1.73 (Nov 2010)
 Improvements
• Major compiler change. IDE being used is Delphi 2007 (no longer Delphi5).
Bugfixes
• Fixed bug with Auto key repeat (using next letter or x skip)
• Bug Fixes for Audio Fade rate and triggering
• Bug Fix for Audio triggering when using Tree and Audio with Layout
v1.72 (Oct 2010)
Improvements
• Put workarounds and logging in code to better handle failed graphic load attempts
• PluginSDK - Added better plug-in configuration window example-
• PluginSDK - Added Arzoo's MaLa stub tool
• PluginSDK - Is now packaged with the standard MaLa download to encourage Plug-in development.
• Removed the Unsupported Checkboxes on the Plugin list
• Extra Logging
• Added code to stop more than one instance of MaLa being opened at a time (only works with 1.719 and above)
• Added comments to Mame.ini editor to advise if may not cover all options
• Added extra logging for Playlist loading
•  Added auto pause to BG music if Video Screen saver is triggered with sound enabled Added hi info page and improved the way Most Played lists are configured
• Removed Extra video check code. I think new Video Engine handles this better on it's own.  :-)
Bugfixes
• Fixed Bug with 'remove brackets on the fly' option. MaLa could get hung in a endless loop if brackets unpaired.
• Fixed bug where selected game in list would jump up/down one item after orientation change (really fixed it this time)
• Fixed BG Muzac for Layouts (I hope)
v1.71 (Sep 2010)
Improvements
• Video - Made MaLa more tolerant of video types and now will also release handles on files if not playing.
Bugfixes
• Fixed bug where marquess, control panel and definables where not being displayed if delay set and first item in game list selected
v1.70 (Aug 2010)
Improvements
• Better errors if mame fails to create mame.ini when requested.
• Dialog will now pop up if MaLa is not allowed to write to Windows registry rather than crash. This is for 'MaLa Start with windows' option.
• Changed and hopefully improved the way audio volume is handled
•  Made even MORE changes to help 'rotate mame with MaLa.
•   Added 'Show Game Metadata' screen via right click.•  MaLa 1.654 - MaLa . Enhanced MaLa to auto up convert old 'Other emu' file formats. (eg *.mle)
• Added optional delay for Game starting picture
• Added Shift Keys for Joystick control
• Muzac/ Jukebox finally finished transition to new Engine.  No More bass.dll required.
• Improved native USB hardware (LED & LCD) handling and setup. Still more work to do here as there is a minor bug where if you have two of the same types of hardware connected the item with the highest id get discovered and assigned first even if in MaLa you have it configured to be Hardware #2.
•  Gamelist Editor  - Updated to allow correctly  load older versions of emu file (like MaLa does)
•  . Made changes to help 'rotate mame with mala' with 'other' flavours of Mame
•  Added auto key repeat for 1-up/down to support older iPacs
• Added 'Windows Focus' command .
• Added memory usage logging on Game List loading and Game Start / Quit/ (to find potential memory leak?)
• Added option to launch game with left mouse button
• Added Plug-in Events. Configure Start/Stop Events.
• Added option not to loop video (play once)
• Enabled Layout Video options to include animated gif's (not just avi's)
• Layout Editor: Added 5th definable... I need to add this to MaLa later otherwise I just wasted my time adding it to the editor ;-)
• Improved the logic with the 'skip to next letter' when dealing with games starting with numbers, also if partial way through a group of letters skip back to the first of it's type rather than the next letter.
• Video2/layout video option implementation finished (I Hope)
• Layout. More 'polish' work to handle Video2/Layout videos
• Windows 7. Got startup routine to recognize if being run on this new OS
• Layout Editor.  Second Video window option added
• Config. Added more verbose descriptions and logging for custom Layout options, and Other EMU MaLaHook loading.
• Some collection options now shown in display box when refreshing game list for Mame.
• Dreamcast (Nulldc) preset added
• Config defaults changed to something I feel is a better starting point ;-)
- Applied new Icon to the MaLa suite from HERE
• Logging - Now can be set at Normal or Verbose Levels
• Jukebox. Better labeling on config window to make operation more intuitive
• Added hotkeys to switch to various orientations• MaLa - Improved messages and logging when creating game lists and reminders in various places about the requirement to use mame >0.84 to produce XML files.
• Added Definable images option of EMU's (other than mame) FINALLY!
• Added Extra logging (in verbose mode) to show event info passed to the plugins
• Number of buttons on a joystick supported increased to 32 (previously 12)
• Hardware: Expanded to support the IOWarrior24 Chip to drive a LCD display
• Video Engine replaced to improve overall MaLa stability and increase playback compatibility with a wider range of video types. This has taken several weeks of development/testing with a lot of help from a great group of beta testers.
• Added MaLa Messages ability to switch to various orientations• MaLa: When mame.exe is specified in options the user is asked if they wish to create a new mame.xml even if one exists.
Bugfixes
• Fixed jump up item in gamelist when mouse enabled and ori change or MaLa start.
• Possibly fixed bug where MaLa would crash if switching game lists faster that the configured display delay interval(s).
• Fixed bug blocking MaLa messages feature from external apps and plugins since beta 1.658
• Fixed Other Emu zero size game list bugs
•  Fixed bug when loading/refreshing mame game lists using nplayers.ini with roms without matching master entries.•  MaLa 1.661 - MaLa . Fixed 'white line' bug on snaps when rotated 270 deg
• Fixed scrolling after rotation bug
• Fixed stupid bug in menu.
•  Fixed wrong gamelist loaded bug on startup
•  Minor 'resume from Standby' display refresh Bug
•  Fixed - other Joystick setting was not saving to ini file.
•  Fixed polling / display delay bug.
•  Fixed tab key select order on config screen
•  Fixed bug in Audio menu if Audio was disabled
•  Fixed bug where selected game in list may jump up or down one item if mouse was moved during game play (if mouse enabled)
•  Fixed bug/crash when option to launch Application on exit was enabled and Sound was enabled.
• Joystick Control- Fixed bugs preventing button use over 16 and in some menus over 12
• Fixed Menu control via Joystick
• Fixed time display for Layouts and LCD
• Fixed Minor bug with tree display
• Added 5th definable for Mame and 'other Emu',
• Fixed bug/crash with zero lengths game list
• Stopped MaLa crashing when disabling Audio
• Fixed some bugs with Definable images on EMU's
• Fixed orientation that was incorrectly reported for non mame. EMU's
• Only one press of start button now required after rotate
• MaLa now re-enables mouse (if required) after resuming from standby
• Stop MaLa crashing if gamelist empty and MaLa Hardware leds were enabled
• JukeBox Disabled 'brackets removed on the fly' in Jukebox mode
• JukeBox. Fixed bug where songs that were read only were getting shown twice in the list
• Stopped mala crashing with delayed layout items if game lists are empty (in some circumstances including rom directory change).
• LED Hardware override files also are used when game is launched
• Stopped delayed layout video playing in background behind a running game in some scenarios. This did sometimes result in performance and Windows focus issues.
• Stopped delayed layout video playing when options window opened.
• Fixed incorrect cocktail command line mapping allocations on 90deg and 270deg
• Fixed flash of default text before Layout loads (in some cases).
• Background music will not start until Startup Video is finished.
• Switching to and from Jukebox from any list now works correctly.
• Fixed bug switching between custom game list with custom layout. Elements switching is now synchronized.
« Last Edit: March 13, 2011, 12:45:04 am by loadman »
headkaze
  • 0x2b|~0x2b?
Re: MaLa v 1.70 Released
« Reply #1 on: August 28, 2010, 04:38:15 pm »
Great work as always Loadman  :cheers:
BKahuna
  • Last login:November 04, 2011, 12:51:11 am
« Reply #2 on: August 28, 2010, 07:29:13 pm »
Wow. That's quite a list of changes.
If I upgrade to this new version, is it possible to retain the old configuration. or do I need to start over?
loadman
  • Moderator
    • MaLa
« Reply #3 on: August 28, 2010, 08:04:35 pm »
The old config should still work.
I would keep your old a copy of your existing MaLa setup in a separate folder until you are happy with the upgrade
Tazmania67
  • Last login:September 03, 2010, 09:25:55 am
« Reply #4 on: August 29, 2010, 06:41:13 am »
Works like a charm!
Mouse problems are gone.
ini problem still exists, it just doesn't see the ini file, but you can create one by running mame.
Now for my question:
I run MAME and Daphne. for MAME i have a horizontal and a vertical game list. For Daphne there is a third list with 3 games.
Would it be possible to add my 3 Daphne games in the horizontal list somehow?
loadman
  • Moderator
    • MaLa
« Reply #5 on: August 29, 2010, 06:52:05 am »
I think the problem is that MaLa is not failing to find the mame.ini but that the mame.ini is not being created.
Can you try what I suggest here please, and get back to me about what is required:
http://forum.arcadecontrols.com/index.php?topic=103178.msg1115423#msg1115423
With a workaround suggested here:
http://forum.arcadecontrols.com/index.php?topic=68419.0
« Last Edit: August 29, 2010, 06:53:41 am by loadman »
Tazmania67
« Reply #6 on: August 29, 2010, 08:41:51 am »
'mame.exe -createconfig' creates a mame.ini file. But when I start Mala, go to the menu and click on config, it still says can't find the ini. When I click on create, it comes with a warning that the creation failed.
I hope this helps.
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
« Reply #7 on: August 29, 2010, 02:43:55 pm »
 :notworthy: LoadMan
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
« Reply #8 on: August 29, 2010, 03:14:45 pm »
Eddie, you are right!
Loadman, you are a CRACK!!
Thanks for MALA!
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
« Reply #9 on: August 30, 2010, 07:15:23 pm »
Seems to be a fine piece of code
« Last Edit: August 30, 2010, 07:30:51 pm by Henrik68000 »
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #10 on: August 31, 2010, 03:56:19 pm »
Thanks for your hard work, loadman!
cabecita
  • Last login:January 16, 2012, 11:06:21 am
« Reply #11 on: September 01, 2010, 03:41:48 am »
Thank you Loadman
Great work!  :applaud: :applaud: :applaud: :applaud:    :cheers: :cheers: :cheers: :notworthy: :notworthy: :notworthy:
loadman
  • Moderator
    • MaLa
Re: MaLa v 1.71 Released
« Reply #12 on: September 03, 2010, 11:37:51 pm »
1.71 - Released  ;D
See first post for details
« Last Edit: September 04, 2010, 02:17:46 am by loadman »
andrewbean90
  • Last login:October 04, 2012, 05:55:56 am
  • do you like it?
« Reply #13 on: September 05, 2010, 01:17:16 am »
had to turn down fading cuz it turned down the volume but never turned it back up or even start the song when ever i tried to start a new song this would happen plus more then half the time i go  to my mame list and mame clears my playlist or something so my music doesnt keep playing even when i tell it to play
loadman
  • Moderator
    • MaLa
« Reply #14 on: September 05, 2010, 01:35:10 am »
OK I will do some more tests with BG Muzac and fades
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« Reply #15 on: September 05, 2010, 06:56:43 am »
Thanks for the great job. There aren't many new features that I need for my layout, but I'm sure many users will appreciate them. Thanx for the starting screen delay option. That's one of the features I had been longing for. Also, the animated gifs is something that I could implement if I decide to so some improvements to my layout design in the future.
I have been testing this version and I'm afraid I'm experiencing now something that I've never noticed before with older builds: focus problems. Everytime I exit a game from MAME, I can browse the game list with my joystick but none of the buttons work. If I click my mouse button, joystick buttons are active again. I suppose this is a focus problem. You mention 'Added 'Windows Focus' command' in the news list, but I've not found this anywhere. What do I need to do?
PD: Just a suggestion for the layout editor in future releases, which would be very handy for working with precission, and specially for those that make low res layouts: a zoom option, something like 2X, 3X, 4X, which would duplicate the pixels on screen. This way it would be easier to work. I sometimes had to resort to some zooming tools for windows when editing my layout. Just imagine how small a 320x240 screen is displayed in 1600x1200 in a 19" monitor.
« Last Edit: September 05, 2010, 07:01:05 am by Stormrider »
kako121
  • Last login:August 18, 2022, 01:54:05 pm
« Reply #16 on: September 06, 2010, 01:45:40 pm »
I believe that my problem with the videosnaps and the screensaver of Mala have remained resolved with this version 1.71. ;D
Functioned 2.5 hours perfect!  Never had lasted so much without being closed Mala.
Thanks Loadman, You are the best!   :notworthy:
r_fagundes
  • Last login:October 26, 2010, 08:52:30 am
« Reply #17 on: September 10, 2010, 06:45:14 pm »
Thank you Loadman!!!
MaLa is perfect !!!  :applaud: :applaud:
loadman
  • Moderator
    • MaLa
« Reply #18 on: September 10, 2010, 08:24:07 pm »
Yeah I think it is pretty good now.
I couple of known bugs with 'background Muzac (particularly if using Music set with layouts).
I will get to this in the next week or so.
Stormrider
« Reply #19 on: September 12, 2010, 08:14:27 am »
I think I will keep the previous version for now. 1.71 has some loss of focus issues in both my computers. I've tried with the plugins but they have no effect. I'll investigate this. Maybe it has to do with my layout.
loadman
  • Moderator
    • MaLa
« Reply #20 on: September 12, 2010, 07:36:38 pm »
If you could raise (in a new separate thread) at what stages the focus issies occor and on what emu.
And how these issues differ between MaLa version.
The frustrating thing is I have some reports of but I have never had a focus issue, hence there is something on your system that I have not got.
What I need is detail please
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #21 on: September 15, 2010, 03:39:05 pm »
Loadman-
I've been watching your Herculean development efforts from the sidelines for the last few months & wish I had time to try out your new revs & provide you w/ feedback.
As I'm swamped w/ work, though, I'm stuck w/ an older MaLa rev for a while, until work slows down & I can take some time off to upgrade MaLa...and install my Aimtrak guns...and configure my steering wheel...and clean up my CPWizard...and sort through the boxes of games I bought in Korea & Japan in May...
In any case,  :applaud: for your efforts!
-Jason
Stormrider
« Reply #22 on: September 18, 2010, 04:47:08 am »
Loadman, I'll tell you more about my problem of focus with the new release. In order to make test and discard possibilities, I've used a clean version, using the standard layout and a new configuration. The only thing I've configured is the path to my MAME and roms. Everything works fine, I can move through the list of games and launch them with key 1. When I quit MAME, I still can move and launch games. I have found the problem very soon. When I select hidden dos window state, the problem arises. When I launch a game and quit MAME, the program looses focus. After a second, when the gamelist appears, I can see the windows taskbar and then no response from my keys, unless I click a mouse button. If I set the dos state to normal, no problem at all. Strangely the loss of focus with hidden dos window doesn't happen in all cases. I've been trying and it seems it happens with some games and not with others. Maybe this has to do with a problem changing resolutions. I've tried, however, with games using stretch and 720x480 (the same res on my desktop) and the problem is still there. To make this even more strange, I can tell you that this happens when I launch MaLa from Windows, not when I load it prior to explorer (launched from userinit in the registry). Also, the lack of control after quiting MAME only happens with my keyboard, not with my joystick, which could mean this has not to do with focus, so maybe the problem is somewhere else.
loadman
  • Moderator
    • MaLa
« Reply #23 on: September 18, 2010, 06:24:07 am »
Thanks for your testing time. Works fine for me.
*) The only thing I added was a force focus command sent after a game is quit.  I don't know if that helped or made it worse for others as it never happens to me.
 *)If you use the focus plug-in you should at least be able to see what is stealing focus?
*) Have you tried on another PC to see if it something you have installed that is stealing focus?
http://www.malafe.net/index.php?page=plugins#malafocuslogger
« Last Edit: September 18, 2010, 06:32:59 am by loadman »
Stormrider
« Reply #24 on: September 18, 2010, 10:37:28 am »
I've been manually closing processes until I've found the problem: CTFMON.exe. Once it's killed, no more focus loss. That's the reason I do not have any problem when MaLa loads at startup before explorer, because there are no processes in memory. When I launch MaLa from Windows, if ctfmon is running, the problem of focus is there. I have tried with the focus logger plugin. Is this plugin supposed to do something or it just writes information in the log file? the log file says that no window has focus, and failed to set focus to MaLa. I've tried putting all the files in the plugin folder as well as in the MaLa root folder. Anyway, I can fix the problem, either but removing the ctfmon program from the registry, or automatically killing it when MaLa is launched from Windows (I run a MaLa-launcher.exe in this case which uses AutoHotkey commands to hide and restore mouse pointers on the fly). I'll just have to add a line: process, close, ctfmon.exe
« Last Edit: September 18, 2010, 08:15:36 pm by loadman »
loadman
  • Moderator
    • MaLa
« Reply #25 on: September 18, 2010, 08:09:58 pm »
I will see if others have this issue.
http://www.pchell.com/support/ctfmon.shtml
Gray_Area
  • -Banned-
  • -Banned-
« Reply #26 on: September 19, 2010, 02:59:04 am »
I have not seen focus issues with any build of Mala on any (XP) computer.
« Last Edit: September 19, 2010, 03:01:45 am by Gray_Area »
-Banned-
loadman
  • Moderator
    • MaLa
« Reply #27 on: September 19, 2010, 06:58:47 am »
As have I  ;)   But a few have.
There must be some combination of factors that cause this for some others. As I can't reproduce I am trying to encourage others to try and work out what the details are.
kernelpanic
  • Last login:December 12, 2010, 04:01:00 pm
« Reply #28 on: September 19, 2010, 02:42:21 pm »
removing ctfmon solved my focus problems as well.
thanks for this - nice catch :cheers:
kagaden
  • Last login:September 10, 2022, 10:58:37 pm
« Reply #29 on: September 19, 2010, 09:19:02 pm »
Thank you Loadman for your hard work and dedication to this project.
I've donated $15 to you today as an expression of gratitude, and in hopes that others who use this great FE regularly will do the same. I've been using it for almost 2 years now and I feel it's far overdue for me to show my thanks to your hard work.
-K
loadman
  • Moderator
    • MaLa
« Reply #30 on: September 19, 2010, 10:11:50 pm »
-K
Wahooo More Beer!   :cheers: :cheers: :cheers: :cheers: :cheers: :cheers:
Henrik68000
« Reply #31 on: September 20, 2010, 10:59:17 am »
First. Thanks for the update. I will donate next week when i go too the Postoffice sending the Harddrive to you. I have a Stiff plastic cab on my top torso and neck due to a carcrash (not my fault!), and i was the only one that was really hurt.
I have two things would hope to see in the next update. These are small things, but for me they are essential. First; There's no longer a Mala logo screen appering on start up. Great!! I want thing's to be as classic & autentic as they can be.
Then a request; Would it be possible to have user supplied start up picture and also a closedown picture. They should be independent.  So that you can have one but not the other one if this is what you want. Also there should be  the possiblity to have two different pictures, one for start up and one for closing.If it's not posiible to have a closing picture then the start up pic is of most importance but i would hope for both. Since this is a feature you can tick on and off they would not upset anyone. Then maybe a timer to count how long they appear . This would be great!
The other thing is really not for my sake more for beginners.
Under commandline emu presets theres a listing of known emulator's:
SNES   not good> ZSNESW  (This one should be taken of the Mala preset the sooner the better if you ask me).
             (Won't respond to esc hook, wont go to full screen automatically. Who wants to mouse around on a cab.
 It's hopeless in an Frontend. Some people who don't know better, will spend night after night on this, trying to get it ti mke sense.
SNES   This is a good Nintendo Snes emu: SNEX9 requires esc hook and nothing more
SNES   Mess 1.7, runs perfect, although there's a warning that there could be sound/video color suff to be sorted.
             I've used for a long time in both 1.6 & 1.7 and have had ZERO problems. Needs no hook.
MSX    emu  BLUEMSX      This is an outstanding emulator. Can be configuret as one pleases, and no headscratcing
MSX 2  emu  BLUEMSX  There's some good games for this machine. They came on cartridge from Activision many of them. I owned an Yamaha
The following should if possible be put in as a choice (as I've nothing against the ones allready listed, But these Mess emu's are SO easy to handle.
Atari2600  MESS
Atari5200  MESS
Atari7800 MESS
Atari Lynx  Handyhack
Intellivision MESS
PhilipsVideoPac o2emhack
Magnavox Odyssey 2 o2emhack
Please note that I've put in the right info into Lynx/Videopac/Odyssey2. People need to get hold of the right 'hack'ed' versions if things are to work.
Thanks.
Henrik
« Last Edit: September 21, 2010, 06:09:15 am by loadman »
snatex
  • Last login:September 22, 2014, 11:32:11 pm
« Reply #32 on: September 20, 2010, 08:49:08 pm »
I'm having a problem when I press the "letter down"  button several times fast it is sometimes starts rotating the screen over and over.  I have no buttons set for any of the rotation functions in the advanced controller configuration tab.  Any ideas?
loadman
  • Moderator
    • MaLa
« Reply #33 on: September 20, 2010, 09:36:33 pm »
Never heard of that one. Do you have Controller Mapping on ???
If no post the section of log (set to debug level log ) and your mala.ini
snatex
« Reply #34 on: September 20, 2010, 10:05:11 pm »
I am a bit of newbie.  I don't have controller mapping on.  I am not sure what the log you mentioned below is and I couldn't find an ini file.  I found the txt file below which looks helpful.  That might be it.  Let me know.  Also, is there a way to add and delete games from my favorites list in Mala?  Or do I have to use the gamelist editor? Thanks for your help and great work.
« Last Edit: September 21, 2010, 05:54:25 am by loadman »
loadman
  • Moderator
    • MaLa
« Reply #35 on: September 21, 2010, 05:57:06 am »
Hi, Yes that was the mala.ini file.  Better to attach the file (in aditional options) rather than dump file into the post next time. I had a look but nothing setting auto rotate in there. ?
FYI you turn on ldebug logging in the 'Credits,, help and Logging' tab
Sounds like you need a bit of help with all theis in general and I don't have time to exchange from the beginning. Just start a new post if you get stuck Try looking at the wiki. You may need to post in the general software section as well. Plenty of nice people willing to help in the forums if you really get stuck.
I would start with looking at the wiki, then search posts here for more help.
If you still have issues start a new post  ... Have FUN!
« Last Edit: September 21, 2010, 06:10:59 am by loadman »
loadman
  • Moderator
    • MaLa
« Reply #36 on: September 21, 2010, 06:05:03 am »
The 'Splash Screen' is optional (and has always been) . Gui - Display - Misc
Do you mean before and after a game? If so you can already specify a game start picture
If yoiu mean start MaLa then would you not get the same effect setting putting the picture on the Windows wallpaper. In any case how many time do you start and stop MaLa on a cab?
Atari2600  MESS
Atari5200  MESS
Atari7800 MESS
Intellivision MESS
Thanks.
Henrik
They are made in 'selection.ini'. You should be able to edit that yourself and post it here. I will include with the next release
Henrik68000
« Reply #37 on: September 22, 2010, 06:24:18 am »
OK!  (I allways wondered what that 'splash screen' was :-) I dont use windows when running Mama in cab and i've made my own start and end  pic's but the pallette is very restricted on those system pic's you know. That was why i was hoping for at start and end pic but i see your point. Sometimes my imagination runs wild.
« Last Edit: September 23, 2010, 12:36:59 pm by Henrik68000 »
loadman
  • Moderator
    • MaLa
« Reply #38 on: September 22, 2010, 09:20:54 pm »
;D  Yeah just a name for a smaller loading screen
http://en.wikipedia.org/wiki/Splash_screen
« Last Edit: September 22, 2010, 09:22:44 pm by loadman »
Henrik68000
« Reply #39 on: September 23, 2010, 01:21:33 pm »
Loadman if the new gif animations shall be of any interest on the layouts then there should be atleast 4 or possible more (besides the original video box).
I want to use it to spice up my layouts with  more gif animations. One animation possibilty is simply to little to make any difference if used for small gif animations. If used for video screen I can see that one extra is more than enough.
In properties there should be a tick box called 'original size of chosen picture/gif' so that the chosen gif ani appears as clear as possible.
I hope this can be included in the next minor upgrade. A few gif animations (not many, since this looks disturbing on the eyes), will beef up the layouts a great deal).
I want my Phψnix bird to move its wings, my pacman to eat and possible Pingo to walk on the spot wile pushing the block in front of him. (See attach)
Henrik
« Last Edit: September 23, 2010, 01:32:07 pm by Henrik68000 »
