Author Topic: Strange troubles with control panel  (Read 1217 times)
reptileink
  • An 8 bit hero
« on: July 26, 2010, 11:44:11 am »
I gutted my X-arcade to fit the existing control panel, and now the controls only work for the Xbox, no emulators  I traced my steps, and there is NO reason why they shouldn't work. I extended some wires for buttons to fit the larger footprint of the existing panel, but I see no problems there. I used the standard "hook up wire" from Radio Shack. Like I said, the control panel works fine when playing Xbox games, but not working for emulators......    :dunno
I did have a glimmer of hope when I could control my guy on Metal Slug, but could not shoot, only jump. Other than that, I gots nothing!
Please leave the X-arcade flaming for other posts, I am looking for some help here.
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
Re: Strange troubles with control panel
« Reply #1 on: July 26, 2010, 11:49:13 am »
Did you instal the x-arcade cfg? did you move x-arcade the selector switch to the proper setting?
severdhed
  • Last login:Today at 03:18:43 pm
  • RIP Dinosaur Hippo
« Reply #2 on: July 26, 2010, 05:32:34 pm »
yeah, it sounds like your emulators aren't configured properly to match the xarcade
reptileink
  • An 8 bit hero
« Reply #3 on: July 26, 2010, 05:35:17 pm »
The main problem is, I can't configure the emulators because the control panel doesn't work....lol
I attempted to do it with the regular Xbox control, and was able to switch the cfg to "X-Arcade" in the emulator, but that still didn't work....I am going nuts   :dizzy:
severdhed
« Reply #4 on: July 26, 2010, 05:56:50 pm »
on the PC, if you go into notepad and hit the buttons, does it start typing letters?
did you try the x-arcade test utility?
http://www.xgaming.com/support/questions/4/Test+Your+X-Arcade+First!+-+Download+the+X-Arcade%E2%84%A2+Test+Utility+Program
