Author Topic: Can't Find Defender Parts!!?  (Read 2307 times)
zzaz3
  • Last login:May 12, 2012, 02:46:49 am
« on: May 10, 2010, 03:05:50 pm »
I'm trying to build a defender cocktail cabinet, but I can't find the parts for the control panel anywhere!  Does anybody know where I can find the parts or how I can build a control panel myself.
The control panel has limited space to work with, so I need to keep the underside short and simple.  Like this:
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
Re: Can't Find Defender Parts!!?
« Reply #1 on: May 10, 2010, 08:09:38 pm »
The control panel is just plywood, so with a router you could make your own.
You could check with Bob Roberts for the leaf buttons & switches:
http://homearcade.org/BBBB/buttons.html
If authenticity isn't an issue you could substitute GGG NovaGems or Happ translucent buttons; it would look the same but the button feel would be a little different.
The 2 way joystick is another issue; haven't seen those for sale. Keep an eye on eBay for them if you want to keep it authentic, or maybe substitute a 4 way? The standard Wico leaf sticks seem like they won't fit in there because of the lack of depth.
I have a Williams Moon Patrol cocktail (that was originally a Defender) awaiting restoration. The joystick is the same except horizontal instead of vertical, and it doesn't have the translucent buttons. Thankfully my control panels are intact.
"Some drink from the fountain of knowledge; I only gargle."
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #2 on: May 11, 2010, 10:23:40 pm »
I wouldn't call this cheap but here is a portion of the joystick.
http://www.quarterarcade.com/Game.aspx/5655
EDIT: Nevermind, should look at the picture before I post....
Next I'll be on fries, and that's when the big money starts rolling in.
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: May 11, 2010, 11:55:32 pm »
i have no idea what stick the defender cab originally had, and i dont know how well these match, but lizardlick carries seimitsu joysticks that can be set to 2way mode...
http://www.lizardlick.com/pages/joysticks.shtml
they also carry translucent pushbuttons..
http://www.lizardlick.com/pages/pushbuttons.shtml
i dont know if that helps or not
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: May 12, 2010, 07:00:44 am »
It looks like the Defender cocktail stick is like the Joust cocktail sticks -- REALLY, REALLY, REALLY short under the panel (e.g. none of those fancy brackets that the uprights used). No words of wisdom as to where to find similar sticks as nothing comes close to the depth of the original stick. AND you don't want a tall stick for Defender as that makes hitting reverse more of a pain.
eBay, WTBs on KLOV, CL, BYOAC, local boards are about the only suggestions that I have.  :dunno
Working: Not Enough
Projects: Too Many
Progress: None
Paladin
  • Mmmm llamaburgers!
« Reply #5 on: May 12, 2010, 11:29:52 am »
That picture of the Defender panels is from my restore:
http://home.comcast.net/~dark.paladin/defender
I still have the pair of sticks that I replaced with complete panels I got from someone, the sticks are the only thing I still have.  You can see in the pic that one of the ball tops has a chunk out of it.  They're both fairly rusty as well, but could be cleaned up.
Send me a PM if you're interested in the sticks.
Tom
