Author Topic: How to auto-power on LCD  (Read 6579 times)
gryhnd
« on: April 19, 2010, 04:18:58 pm »
Perhaps my search foo is weak, but I only found one post about this and the responder took it to PM :-(
Unlike my other cabs with CRTs which always return to their previous power state when electricity is cut to them (IOW...once I turn it on, it will always turn back on when power is (re)applied), a small Viewsonic LCD I have does not do this. I was planning to use it for a bar/table top unit for my nephews, but I'm disliking the idea of having them need to push two buttons (even if only occasionally) to play the cab.
Is there an easy way to overcome this? Operative word being easy  :laugh:
I imagine if I was handier with circuits I could design some sort of relay hooked to a capacitor that bled off, but I don't know enough about it to do it.
How do others handle this?
If it matters, this is a Viewsonic VG150
TIA
Completed: No Name Upright
Blanka
Re: How to auto-power on LCD
« Reply #1 on: April 19, 2010, 04:21:38 pm »
I have had 5 types of LCD's last 2 year, and all resume to the previous state after putting the power back on. Guess you have to ditch the viewsonic.
gryhnd
« Reply #2 on: April 19, 2010, 05:21:16 pm »
Ok, I'll accept that I said "easy"...but that's one I could figure out on my own  8)
Not looking to do away with the monitor though. I like to recycle.
Any other suggestions that don't involve using a different monitor.
lilshawn
  • Last login:February 03, 2026, 06:10:43 pm
« Reply #3 on: April 20, 2010, 12:31:14 am »
Try shutting off power to your lcd and then hold the power button and apply the power. If it operates you can just open it up and solder a wire on the power button to short it out.
Try leaving the power on. Ie plugged in and on. If you cut the video signal (turn off computer) it should shut off and go to a standby mode.
If not, consider a different monitor.
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #4 on: April 20, 2010, 03:31:36 pm »
...Why not use an IR blaster and just set the computer to send the 'Power On' IR command on bootup of the OS?
MonMotha
« Reply #5 on: April 20, 2010, 04:31:57 pm »
If just holding the button won't work, try this:
If it's a low voltage momentary pushbutton for the power (pretty common - the microcontroller inside controls the actual power supplies) you can sometimes bridge the switch terminals with a capacitor (the value you need varies with circuit topology - start with like 10uF).  The cap looks like a closed switch when power is initially applied then transitions to looking like an open switch as the cap charges up.  Basically, it looks like you pressed the switch momentarily right as power was applied to the unit.
Of course, a small micro or analog timer circuit and a transistor can also accomplish this in an even more controlled method including with an initial delay if needed to let the MCU in the micro "start up" before it looks for a power button press.  Details upon request if needed.
gryhnd
« Reply #6 on: April 20, 2010, 05:57:28 pm »
@LilShawn: good thought...I had tried that (should have said so initially) and no dice  :angry:
@MonMotha: that's what I was expecting might be needed. If there's no other ideas, I'll try the cap route first and see what happens.
lilshawn
« Reply #7 on: April 20, 2010, 08:01:55 pm »
I don't think that will work on a monitor, since there would be no remote control.
Blanka
« Reply #8 on: April 21, 2010, 02:56:39 am »
Or program an arduino to switch it on.
MonMotha
« Reply #9 on: April 21, 2010, 09:12:21 am »
That was my suggestion...
kyoke
  • Last login:October 17, 2013, 11:50:44 am
« Reply #10 on: June 10, 2010, 03:35:40 am »
@gryhnd: You didn't by chance figure out which wire to short on the key controller board inside your ViewSonic monitor did you? I have a ViewSonic as well that turns on the moment I press and hold the power button. It does not require releasing the power button to turn it on which I would imagine means I can solder the wire to allow it to go on the moment power is applied from the mains.
Work in Progress: R-TYPE Themed Bartop - "R-CADE"
gryhnd
« Reply #11 on: June 10, 2010, 07:36:27 am »
Kyoke,
No, I didn't, but that's because mine doesn't work that way.
I've tabled this project for now, but will come back around to it later. Perhaps in the Fall.
I'm actually in the early stages of a touch screen jukebox built into a (censored for now in case this doesn't come out the way I like!).  I have about 80% of the parts either already here or arriving in the next few weeks.
kyoke
« Reply #12 on: June 10, 2010, 10:56:53 pm »
@gryhnd: That'll be awesome to see... Antique cabinet? Built into a bar? What could it be?!?
gryhnd
« Reply #13 on: June 10, 2010, 11:42:49 pm »
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 10:59:49 pm
« Reply #14 on: June 11, 2010, 12:30:39 pm »
build one of this
but have it so when you turn the CAB on, it reaches out and push the power button for you  ;D
Free VGA Breakout Cable
Franco B
« Reply #15 on: June 11, 2010, 12:51:22 pm »
I don't know why but the first 15 seconds of that cracks me up  :laugh2:
gryhnd
« Reply #16 on: June 11, 2010, 12:55:14 pm »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #17 on: June 19, 2010, 08:57:19 pm »
this should do the trick
gryhnd
« Reply #18 on: June 20, 2010, 08:36:01 am »
