Author Topic: Dimensions for this pedestal cabinet (funglo?)  (Read 12380 times)
Nohup
  • Last login:May 08, 2010, 10:31:38 pm
  • This is taking longer than I thought
« on: April 05, 2010, 10:44:50 pm »
It might not suit everyone's tastes, but I really like the looks of it.  8)
http://www.funcomfg.com/cabinet-funglo/
Problem is, I've never seen one in person.   And starting to plan a cut-list for one without any measurements is proving a bit tough.
Has anyone out there ever taken a tape-measure to a cab like this?  Or have one available that they could get a few measurements from?
Even a picture of one next to something I could scale it to would help.
Thanks in advance.
Gatt
  • Last login:February 04, 2020, 08:24:38 pm
Re: Dimensions for this pedestal cabinet (funglo?)
« Reply #1 on: April 06, 2010, 02:54:45 am »
Couldn't you use the coin doors as reference?  Those are fairly standard,  so if you know the dimensions of the doors then you should be able to get a reasonably accurate set of estimates from the picture.  Should give you height easily,  and width looks to be about 1.25 or 1.5 times the width of the coin door.
Looks like you should be able to get very close to the correct measurements if you know the dimensions of the coin door,  everything looks like it's proportioned in relation to the doors there.
YoGaBaR
  • Yeah im in the club
« Reply #2 on: April 06, 2010, 09:20:50 am »
37″ tall, 34″ wide, 27″ deep and 145 lbs.
right off the website. this should get you going in the right direction.
Nohup
« Reply #3 on: April 06, 2010, 10:07:43 am »
Gatt:
I hadn't thought of scaling the dimensions from the coin door.  That's a really good idea.
I found one on happs that is looks like the one shown.  It measures about 10x20.  I think I should be able to get close from those.  At least for the height and width pieces.
YoGaBar:
I did see the HxWxD measurements on the site, probably should have mentioned those in my post.  they got me started, but weren't enough to figure out some of the interior pieces.  I'll definitly use them to double-check the coin-door scaled measurements.
If I get measurements that look good in a mock-up, I'll be sure to post them.  I like the look of this cabinet, but have a feeling that if I don't get the ratios very close to the original, it won't look good at all.
Thanks for all the help and advice.
Brian74
  • Yep... I built that!!
« Reply #4 on: June 09, 2014, 10:40:58 am »
I am also looking for these plans!
« Reply #5 on: June 09, 2014, 10:48:59 am »
I know it sounds silly, but grab some cardboard and build a mock up.  Cut those to size and then simply measure the pieces you made.   :applaud:
Also, have you considered using Sketch Up to design something.  Or perhaps someone who's really adept at using it can help you here?
Good luck!
DeLuSioNaL29
ark_ader
  • I glow in the dark.
« Reply #6 on: June 09, 2014, 06:49:14 pm »
Make sure you make it tall enough for you to play in comfort.  Nothing worse than hunched over a build giving you backache.
Brian74
« Reply #7 on: June 25, 2014, 12:33:29 pm »
What size tv should a person use with this?
Drnick
  • Plodding Through Life
« Reply #8 on: June 25, 2014, 12:55:01 pm »
37-55" Hung on the wall or similar  :laugh:
37-55" I suppose it depends on if you will hang the TV on the wall or not  :laugh:
Brian74
« Reply #9 on: June 25, 2014, 05:08:22 pm »
I was looking at the website, they offer it with a 42, think I will go with that. Im going to "try" to sketch this out tonight. I wanna get building this thing. Only thing I plan to change is the side supports. I cant afford that thick of plexi. Sorry for the hi-jack, carry on  :cheers:
xtconcepts
  • Last login:September 19, 2014, 10:49:55 pm
« Reply #10 on: August 04, 2014, 11:55:39 pm »
Any updates :)
Paul Olson
    • Paul's Arcade
« Reply #11 on: August 05, 2014, 12:02:23 pm »
If you plan on using the bezel artwork in MAME (which looks nice on an HDTV, I think), you should consider going with a bigger TV. I went with a 47", and with the artwork, I can get really close to the original size of the game inside the bezel.
eds1275
  • Rock and Roll!
« Reply #12 on: August 05, 2014, 01:19:17 pm »
Drop the photo in sketchup, aling the axis, then measure a dimension you know. Should be able to trace the shape of hte cab and get measurements that way!
http://help.sketchup.com/en/article/94920
thestobbster
  • Last login:February 16, 2021, 10:44:01 pm
« Reply #13 on: June 10, 2019, 08:03:19 pm »
Here's a link to a PDF I found with measurements. I plan to start building one of these in the near future.  :D
https://stobbs.us/documents/Mame%20Pedestal%20Funglo%20v5.pdf
THeSToBBSTeR
Baezl
  • Last login:August 24, 2024, 07:11:26 am
« Reply #14 on: January 15, 2022, 11:13:11 am »
Does anyone have this PDF that can re-share?
mame pedestal funglo v5.pdf
Luis
  • Last login:Today at 05:02:13 am
« Reply #15 on: January 15, 2022, 11:50:50 am »
You're in luck.   ;D
The Internet Wayback Machine archived a copy at https://web.archive.org/web/20210809162831/https://www.stobbs.us/documents/Mame%20Pedestal%20Funglo%20v5.pdf.
Baezl
« Reply #16 on: January 18, 2022, 03:28:49 pm »
Thank you a ton!!
v/r
Luis
bobbyb13
  • Last login:February 21, 2026, 01:34:49 am
« Reply #17 on: January 19, 2022, 01:05:55 am »
And Scott strikes again  :laugh:
That pedestal design is the one I have wanted to build since I got the 36" Trini.
I think I'm quoting javeryh when I say this hobby may be the death of me?!
Added to the que-
 :lol
Baezl
« Reply #18 on: February 06, 2022, 06:58:40 pm »
Didn't realize there was a SketchUp file for the pedestal from DeeGor - http://forum.arcadecontrols.com/index.php?topic=155462.0
The file has all the measurements and angles.
v/r
Luis
