Author Topic: N64 ROMS....which to use  (Read 2003 times)
mike boss
« on: January 08, 2010, 10:53:27 pm »
I'm in the process of FINALLY turning my XBOX into the XBOX I always wanted.
All the emulators I could think of with full &/or custom ROM sets (depending on size).
A whole slew of games, MAME, and MUGEN, just to name of few of the token gems I'd like installed.
For N64 I decided to go with a custom ROM set of the select few favorites I had.
I just dont know which version of the ROM I should be using, any help ?
For example some ROMS end if V64, others Z64, some even N64. Most have the (U) which I assume is for U.S version ?
And then you have (!) and [!]
I dont know if they all work, if it doesnt matter, or should I be looking for something specific ?
I ended up installing multiple ROMS for various titles, but obviously I would like to clean this up, I dont need two WWF Wrestlemania for example.
(that for example ends in (U) (!) N64 and (U) [!] Z64
I'm confused help a NOOB out !
thanks
Ginsu Victim
  • Comanche, OK -- USA
Re: N64 ROMS....which to use
« Reply #1 on: January 08, 2010, 11:01:05 pm »
To my knowledge, those extensions should all work fine. There is a filename length limit on xbox of 38 characters plus the extension. The ! means that it's the proper rom and best known version of that rom that exists.
mike boss
« Reply #2 on: January 08, 2010, 11:16:19 pm »
I'm just going thru my ROM folder and every ROM has the ! in some form or another, be it surrounded with () OR [].
I guess what I will do is keep the ROMs with the shortest name and delete the rest.
No need for duplicates ! I just need one working ROM for each select game.
thanks !
Ginsu Victim
« Reply #3 on: January 08, 2010, 11:20:11 pm »
You could just rename any of the ones that are too long.
