Author Topic: Ring detection method  (Read 1040 times)
protokatie
« on: January 05, 2010, 03:00:10 am »
Maybe the "technician" can help here.
The details of my project are un-important, but is there an easy way to make a circuit that can differentiate a ring on a VOIP/landline from any other use of the line? I guess I could gut an old phone and use that, but I would rather use a more "polite" route.
And yes, this has to do with my Tardis. (damn roomate is too loud on my VOIP line, so anything to muffle the sound...and make a light blink at the top during rings...)
Re: Ring detection method
« Reply #1 on: January 05, 2010, 09:06:26 am »
BYORD (Build Your Own ring Detector):
This will work with regular land line phones, but I dont know about the VOIP. But if the VOIP will ring a regular phone, I dont see why it wouldnt work.
http://www.epanorama.net/circuits/telephone_ringer.html
I made something similar to this years ago to flash a lamp for my mom when the phone rang, she was going deaf at the time.
I cant find the schematic to it, but it is similar to the one linked, except instead of C1, D1, and D2, I used a small neon bulb. The neon bulb conducts at around 90 volts, so it worked very well.
I also used a triac compatible Opto Isolator and a triac to turn on the 120 volt lamp, but if you just want to blink an led you wont need a triac.
And if you would like to know when the phone line is being used by someone else, or a dial up modem, or fax machine, here is another circuit that will tell you that: (Thanks to Aberto Ricci) (again, not sure about VOIP usage)
http://www.riccibitti.com/quickdesigns.htm
