Author Topic: Mame and Aim-Trak Help  (Read 2040 times)
JZSlenker
  • Last login:April 20, 2014, 10:06:50 pm
« on: December 14, 2009, 08:28:41 pm »
I'm running Mame 0.135 and can't seem to get Aim-Trak setup correctly.  I can get the trigger and aux contacts to register in games, but moving the gun does not move the cross hairs.  Aim-Trak works fine in windows as far as moving the mouse.  What settings in MAME do I need.  I've tried operation wolf, operation thunderbolt and duck hunt and get the same issue.  I can fire, but my attached mouse is the only thing (besides keyboard) that moves the crosshairs.  I've tried resetting preferences and numerous combination in the controller mapping window of mame.  I rest mame to default, enabled mouse and checked the  multiple mouse button.    What am I missing?  I have the ID of the AimTrak set to #2 although I also tried ID#1 with the same results.  Any help is most appreciated.
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: Mame and Aim-Trak Help
« Reply #1 on: December 14, 2009, 08:37:23 pm »
In the mame.ini you need to set Lightgun = 1
Loafmeister
  • Last login:June 03, 2025, 01:49:49 am
« Reply #2 on: December 15, 2009, 01:17:24 pm »
I'm not 100% sure but If you have a mouse connected and the lightgun is also seen as a mouse, then that means you are running a multi-mouse system; thus you may also need to enable "multimouse".  I'm at work, can't verify the wording but it's something like that, give it a try.
Friends: please correct me if I'm wrong...
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: December 15, 2009, 01:29:18 pm »
Yeah, need multimouse on if you don't already.
kjbalto
  • Last login:January 20, 2018, 12:33:06 pm
« Reply #4 on: January 22, 2010, 12:23:36 am »
I'm having the exact same problem and I have multimouse turned on. What should my aimtrak configuration look like? What should the trigger and P1 bet set to? I'm testing it on Police Trainer right now, so if I change the controls on the game, what do I want to make the settings to? I'm totally lost here.  I had it working when I tested the aimtrak on my pc, but once I connected it to my arcade it doesn't work.
rlehm
  • Last login:September 30, 2010, 09:04:25 pm
« Reply #5 on: January 22, 2010, 12:55:43 am »
Trig mouse left [box checked] GP mouse r [box checked]
after making changes click send
