Author Topic: ***Fixed***Electrohome G05-801 precap advice  (Read 2078 times)
Tenn_pin
  • Last login:January 01, 2014, 06:57:02 pm
« on: November 21, 2009, 09:50:48 pm »
I have a G05 with no glow and DOA.  The fuse F100 was blown.  I replaced the fuse and still no glow, but the fuse did not blow this time.  What part(s) should I be looking at?  This is the first 05 I have tried to repair, and I would like to do a shot gun repair of all usually bad parts.  Is there a flow chart available?
Thanks,
R
 ??? :applaud: :applaud: :applaud:
« Last Edit: November 27, 2009, 08:48:54 pm by Tenn_pin »
Tenn_pin
Re: Electrohome G05-801 precap advice
« Reply #1 on: November 27, 2009, 08:04:12 pm »
Well gang, it turned out to be a cold solder joint on R104 (leg going to P100-3). I reflowed the solder joint and still had not connection. So I got a piece of wire and jumpered the two connections and now it works.
R
