Author Topic: Project Quercus - Control Panel 2  (Read 93805 times)
wilno45
  • Last login:January 31, 2017, 06:22:42 am
Re: Project Quercus - Control Panel 2
« Reply #280 on: February 21, 2011, 04:44:24 pm »
Thanks BurgerKingDiamond,
Update - Changed my mind again and have replaced the back panel (itself a replacement) with a
less obtrusive narrower one.
The problem was that it would have to sit at each end on two supports and be bevelled to match
the mitres that hold the CP in place. This is fine but the errors in construction have well established
themselves by now and everything's  a little off.
The Whale Cut.
The Hammerhead.
Used the router and a chisel and finished off with the mitre saw. Went OK.  :o
Hinges next - found some lovely ones called Soss - German I think.
Hope there is enough clearance when it flips up or I will have to move the monitor up a bit.
Cheers
Bender
« Reply #281 on: February 21, 2011, 08:17:46 pm »
Looing Great, I love this project! :cheers:
those Sogg hinges are awesome, but they take a bit of work to route out to install, well worth the effort though
wilno45
« Reply #282 on: February 22, 2011, 05:57:51 pm »
Thanks Bender  :cheers:
Got the Leaf Switches routed out at last. They take up a LOT of room on the
underside and I had to be careful with the placement.
The lighting wasn't romantic like the picture makes out.  :o
Chipped a bit.
Also I managed to get hold of some uninsulated connectors that drventure suggested earlier that look a lot better
than the pinky/red ones. Good suggestion drventure.
Cheers
Pixelhugger
  • Last login:March 05, 2026, 11:55:53 pm
« Reply #283 on: February 22, 2011, 06:18:26 pm »
Niiiiice. Looks very mechanical.
Project mega thread HERE
Woodshop Flunky
« Reply #284 on: February 23, 2011, 09:11:53 am »
Looks nice!
I've never seen leaf switches before.  Is there an advantage to these types of switches?
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
  • I want to Build My Own Arcade Controls!!
« Reply #285 on: February 23, 2011, 02:01:11 pm »
No clicky click, more authentic feel, some say better response.
wilno45
« Reply #286 on: February 26, 2011, 12:31:49 pm »
Thanks guys
Woodshop Flunky - My favourite game is Track and field. Which used leaf
switches I believe.
Ordered the wrong hinges - so some more on the way that will suit a 24mm
panel. Nickel plated this time not brass. Will make up a template for them out
of scrap wood, much easier to screw up a template and redo....
Cheers
wilno45
« Reply #287 on: March 31, 2011, 02:55:27 pm »
Figured out how to mount the hinges at last and also made a small change to the design.
The template is not pretty but it's worked well so far.
Used a 9mm flush trim bit and 13mm forstner bit and finished with a chisel.
Practice bit vvvvv
Had to find some verrry short inserts to mount the joysticks.
« Last Edit: March 31, 2011, 03:04:17 pm by wilno45 »
wilno45
« Reply #288 on: March 31, 2011, 02:59:51 pm »
Original inserts replaced with headed version which I think looks a little neater.
2 down 2 to go.
Cheers.
  • Last login:Today at 05:01:03 pm
« Reply #289 on: March 31, 2011, 03:38:37 pm »
 :applaud: That is incredibly cool. Well done, man.
wilno45
« Reply #290 on: April 02, 2011, 05:28:59 am »
Thanks emphatic,
Hopefully get the top bit done sunday evening.
wilno45
« Reply #291 on: April 03, 2011, 05:38:41 pm »
Re jigged the jig and got the top panel mounted.
Just need to get some slightly shorter screws to fix the hinges to the top panel.
Cheers
« Reply #292 on: April 03, 2011, 07:40:41 pm »
So does it hit the monitor?
« Reply #293 on: April 03, 2011, 09:00:58 pm »
You really need to finish out the underside of the CP, and light the inside of the box. That all is way too nice to shut up inside never to be seen!
wilno45
« Reply #294 on: April 04, 2011, 02:24:05 am »
Nephasth - P2 start button hits the monitor at about 80 degrees. Raising the monitor a bit should stop this I
hope.
drventure - Thanks, I hope to have some time next week to do exactly that.
Ps. It seems really stable just sitting on its own weight, not sure I have to fasten it down at all.
« Reply #295 on: April 04, 2011, 07:13:52 am »
Will there be kids playing this? ;)
wilno45
« Reply #296 on: April 04, 2011, 08:35:32 pm »
Nephasth - Good point  :o
wilno45
« Reply #297 on: April 27, 2011, 05:57:03 pm »
Bit more progress, now almost all the woodwork is done.
Will route out the perspex panels outside that's for sure.
Cheers
« Reply #298 on: April 27, 2011, 06:55:15 pm »
This is one of my favourite projects, the rolled off edge of the CP looks very nice, loving the black, red and white controls with the timber CP also.
« Reply #299 on: April 27, 2011, 09:38:54 pm »
Nice stuff!
wilno45
« Reply #300 on: May 02, 2011, 05:14:26 pm »
Thanks guys, and sorry for not getting back sooner.
Crazy busy here.....
Have added some beeswax to the finish. Will post some pics in a day or two.
wilno45
« Reply #301 on: June 01, 2011, 08:35:46 am »
Small update...
Panel inserts added and some more dowels.
Found some stickers.
Woodshop Flunky
« Reply #302 on: June 01, 2011, 10:53:55 am »
Wow!  Your angled panel insert brackets are insane!  Good job.  :applaud:
BurgerKingDiamond
« Reply #303 on: June 01, 2011, 12:17:17 pm »
dude, please finish this already! I want to see the final product alread.
-Welcome to the Fantasy Zone.
wilno45
« Reply #304 on: June 02, 2011, 03:37:42 pm »
Thanks guy's - can't wait to actually play the damn thing myself.
Encryptor
  • Trade Count: (+34)
« Reply #305 on: December 11, 2011, 06:10:30 am »
Any updates?
Thamanator
  • Last login:January 26, 2012, 01:36:32 pm
« Reply #306 on: December 12, 2011, 12:35:10 am »
Very nice work sir!
ARTIFACT
« Reply #307 on: December 12, 2011, 12:50:38 am »
however that really kick started things for me. ARTIFACT's
brilliant sketchup plans and project log (which I have borrowed from here or there) are the reason I finally got round to starting anything in
the first place.
Thank you for using them!! I am so glad to see my design/plans used as inspiration and support for other folks on BYOAC!! That was the whole goal.
I have not been here in *years* and I am back :)
Looking forward to follow your build.
Arturius
  • Last login:February 13, 2016, 08:25:23 am
« Reply #308 on: November 05, 2012, 11:47:44 am »
Did this ever get finished?
Getting there, just rather slowly...
CoryBee
  • Bopity Boopy
« Reply #309 on: November 05, 2012, 06:02:12 pm »
Just went through the whole build, loving it. Sad to see builds like this unfinished - at least unfinished blogs of it.
« Reply #310 on: November 05, 2012, 09:17:25 pm »
Looks like wilno45 was last on in June.
I'm guessing life got in the way. But this was (is) an awesome build.
Here's hoping he's just taking the long way around!
wilno45
« Reply #311 on: November 13, 2012, 02:22:45 pm »
Sorry for no updates, project on hold for a bit while I do some house stuff etc.
Hopefully be back in a few months!
ATB
Wilno45
a1pharm
« Reply #312 on: July 07, 2013, 01:39:51 pm »
Please tell me this isn't dead  :cry:
Encryptor
« Reply #313 on: December 16, 2015, 10:41:51 pm »
What's the status of this build? Finished? Dead?
Encryptor
« Reply #314 on: March 16, 2016, 05:40:28 am »
wilno45,
Are you still working on this beautiful project? Please update us.
Encryptor
« Reply #315 on: March 16, 2016, 01:33:19 pm »
Last Active: May 25, 2013, 08:11:32 am
 :dunno
