Author Topic: Who is a reputable PCB repair person  (Read 1823 times)
YoGaBaR
  • Yeah im in the club
« on: October 04, 2009, 08:14:34 pm »
I have checked the wiki and I have seen a few options. I NEED a person that can fix my
Bubble Bobble - repeats on the warning screen
Bubble Symphony - dead game and mobo
Bubble Memories - gets sound but frozen pic
I have had a guy locally fix them all and said they worked and had them on for an hour and said everything was fine. Now I test them and all these problems. Plus I am too pissed3d to check my other games to see if they are really working or not.
I want to know who would be the best to fix an old Taito and Taito f3 system. I need a reputable person, company, or member here who will really fix them and not screw me. I really need these done for they are part of a project I am in the midst of creating.
Thanks,
YoGaBaR
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Who is a reputable PCB repair person
« Reply #1 on: October 04, 2009, 08:54:24 pm »
My number one recommendation for JAMMA-based stuff would be BYOAC member channelmaniac, who can be found in the Vendors page of the wiki under ArcadeComponents.com.
I only have one of his repaired boards, but the repair is neat and clean and the board works great. I have ordered chips from him before and also read through his repair logs (here and here) a number of times and found them very helpful.
Before I would go that route, however, I would do the mandatory voltage and connector checks to make sure everything is OK (it isn't clear from your post how much troubleshooting you have done to date).
Working: Not Enough
Projects: Too Many
Progress: None
Kevin Mullins
    • Me on Myspace
« Reply #2 on: October 04, 2009, 10:37:18 pm »
Agreed.........
Do you have ANY boards that work in the same setup you are trying those three boards?
What's your power supply putting out when a board is plugged in ?
When I see or hear of that many boards said "working" and none of them work in the same setup, I question the setup first.
YoGaBaR
« Reply #3 on: October 05, 2009, 08:57:36 am »
I guess I did the basics of testing. I have put the boards in my TMNT cab I know its working. same problems.  I have also made a little jamma testing bartop top test boards. Same problems. I have tested other working boards on both cabs.
I even took the bubble symphony and bubble memory carts and put them on the others motherboard. They are both Japan version carts and motherboards so I know they are interchangeable.
Other than that all I can say is that the bartop I made is all new components and I know I have tested six working boards on it. Some jamma and some not.
Thanks for the replies, hope this info helps.
